Question about Dell UltraSharp 1907FP 19" LCD Monitor
Power on. Only get white screen - Dell UltraSharp 1907FP 19" LCD Monitor
    Scholar:
  • 63 Answers
A white screen usually is an indication of a blown SMD fuse on the LCD driver board. This is the board that is actually part of the panel, and you'll need to remove the metal cover on the upper backside of the screen to see it. And by screen, I mean after the monitor has been disassembled and all that's left is the screen.
When this fuse blows, the rest of the monitor still operates fine, like the backlight which is making it white. But the LVDS video signal being sent to the LCD driver board isn't being interpreted and displayed, as it isn't receiving the +5 volts needed to do so.
This really is an easy fix, if you're up to tearing your monitor apart. You'll need a solder gun too. Don't tell anyone I told you this, but you can just place a drop of solder where the tiny fuse is, in order to complete the circuit (if you don't have a replacement for it)
Posted on Dec 29, 2009
  • Chris McLellen
    Chris McLellen Dec 29, 2009
    http://www.boiselcd.com
  • niek_de_jong
    niek_de_jong Sep 13, 2012
    hey. I have exact the same monitor as the OP, but i can't find the SMD fuse. Do you know the Code of it? tore it appart, but can't find the fuse itself.
WHY IS MY SCREEN STUCK ON WHITE?HOW DO I FIX IT?
move on to near by service center if u have valid warranty..
might b issue with the ROM OR DISPLAY problem..if its display, replace with the new one..if its ROM then they will flash and give u
Oct 17, 2017 | Cell Phones
Leapfrog ipad ultra black screen white dot
During a normal shut down, the screen image on a LeapPad will reduce to a white dot, which will disappear in five to ten seconds.
In rare circumstances, the white dot will not disappear and the LeapPad will not fully power down. If the LeapPad does not complete the shutdown process and the white dot remains on the screen for more than ten seconds, complete the shut down by pressing and holding the power button on the LeapPad for ten seconds. This will fully power the LeapPad down, and it will start up normally next time you power it on. For more information contact essay writing service reviews
Essaypaperreviews com Best Writing Services Reviews online
Dec 27, 2013 | LeapFrog Toys
For the last 3months,my dell vostro 1088 laptop has started giving a lot of trouble.While i'm doing working on it,the screen suddenly starts blinking and it all goes white within a second.This pro
  • Remove the battery and disconnect the power cord.
  • Press power button for a few second.
  • Connect the power cord. Press the power button to start and then dock the battery.
  • White screen on a laptop is a connection problem between the LCD screen and the video cable running from the motherboard. The issue can arise with the motherboard or the screen might contain a defect.
Aug 22, 2012 | Dell Vostro 1088
Sharp Lc-26sb24u white screen with sound
You will get a white screen when you unplug the t-con from the main board. Doing so removes power to the LCD panel. Verify that all of your voltages from the power supply are correct. If they are, I'd look at the t-con board. It sounds like there is a problem with the t-con that is pulling down the main board.
May 11, 2012 | Sharp LC Televison & Video
White screen 8530
Have you tried a reset or a reboot? Try these steps:
1. Power off the cell phone by holding down the power button for at least 5 seconds. The screen should turn black. Now, let go of the button and press it again until the screen lights up again.
2. If the screen is still white while holding down the power button, open up the back of the cell phone and remove the battery. Wait for 30 seconds before putting the battery back in, to allow the software to reset itself. Put the battery back in and press the power button until the screen lights up again.
3. If you removed the battery and you still have a white screen, you may have a software issue. Go to a local cell phone repair company and have it replaced or fixed.
Apr 18, 2012 | RIM Blackberry Curve 8520
Hello I have got suddenly a white screen after starting the 5 year old Dell inspiron 1300. In the background the typicall sound of the Windows XP startprocedure can be heard, but I dont get any readable...
Hi holm_fischer,
White screen often caused by a defective screen. The easiest way to determine if you have a hardware or software problem is by performing a power drain. Please follow the steps below for additional instructions.
Power Drain:
1. Turn off the computer.
2. Unplug the AC adapter from the power outlet and take out the battery from the system.
3. Now, press the power button for about 15-20 seconds.
4. Put back the battery in and plug the AC adapter.
5. Turn on the system and try observing it.
--> If power drain did not work, you need to consult a repairman to have your screen be checked for possible damage.
Hope it helps.
Thank you for using FixYa.
Nov 28, 2010 | Dell Inspiron 1300 Notebook
Power on screen white
lens assembly (barrel unit) struck up. slightly push lens while power off & pull the lens while power on. repeat this 2 to 3 times it will works. dont apply any oil in the barrel unit. but you may use body spray or room spray to solve this issue permanently
Feb 06, 2010 | Samsung Digimax A503 Digital Camera
Doesn't start
hi, if ur screen turns white, it could be any problem starting from ur LCD to motherboard or as u said a virus. to assist u in a right way i need to know what exactly is happening between that short duration between pressing the button and white screen. most importantly is anything else comming up on the screen before the white screen.
cheers
Oct 12, 2008 | HP OmniBook 500 Notebook
White Screen for Lenovo Y410
can you try and power up in safemode
by continuosly pressing f8 during startup
see if you can get in safemode
Aug 31, 2008 | Lenovo 3000 Y410 (59012354) PC Notebook
White screen
how do you flash the firmware using pc. can u tell the procedure
Apr 27, 2008 | Nokia 9300 Smartphone
Dell UltraSharp 1907FP 19" LCD Monitor Logo
714 people viewed this question
Alun Cox
