Question about Microsoft Xbox 360 Wireless Controller
Does not power on. Replaced batteries with known working batteries, still will not power on.
  • 26 Answers
Hmm it may have a lose conection theres not alot you can do i'm afraid bar buyin a new controller
Posted on Dec 10, 2009
Put in new known good bulb didnt work. replaced battery with known good battery didnt work. is it a bad switch. the switch seems to work perfectly.
Look at the inner spring it gets caked with corrosion, I am trying to find out how to disassemble the whole thing. Thats all I know.
Jun 10, 2011 | Stinger Streamlight Poly with 110V ACDC
Electricity spike computer wont start , AC adapter short circuit, computer computer crashed unable to power up is motherboard dead,is it possible to have computer checked out.
Some times the AC adapter and battery dies and saves your laptop motherboard.
Follow the following steps to check once again.
Remove the battery and the defective adapter and check if you can borrow a known good working adapter and see if your system works / turns on just by connecting the power adapter and turning it on (without the battery) if it works then repeat the check with the battery on.
If both the test works then your adapter is the only issue, get it replaced.
If both fails, you have to replace or service your motherboard.
Dec 09, 2010 | Toshiba (K000002020) Motherboard
I have an compaq presariov2000 laptop. the problem is battery not charging and the charging symbol is also in a hide and seek mood. I also try scan for hardware changes method but it won't work. plz help.
go to compaq's website, download the latest Bios Update, run the bios update while the power suply is connected on the laptop. after the update, the power adapter should be recognized by the laptop
Sep 07, 2010 | HP Compaq Presario V2000 Notebook
Will power up ;ights turn green but screen stays black then shuts down after a few seconds{please help}
I think it's the memory chips which should be causing this problem.
HAve your memory chips checked
Mar 29, 2010 | Computers & Internet
I have a hp pavilion dv6500 notebook pc which is having problems holding a charge. I recently replaced the power adapter with a 65 Watt power adapter and same problem. Not sure the wattage of the original...
start with removing the Microsoft ACPI Compliant Control Method Battery from device manager. Right click my computer > manage > device manager. right click unistall the Microsoft ACPI Compliant Control Method Battery.
If that doesn't work look for a BIOS update on the HP website. Known issue with this series.
Mar 12, 2010 | HP Computers & Internet
Phone was dead says battery charged...power off why wont it work
If the phone charges the battery as it is displayed on the screen when a charger is plugged in but does not power on, the power button/switch is faulty. Have it checked and replaced by a qualified technician.
If the phone doesn't charge the battery, the battery is probably drained or dead. To verify, grab a voltmeter and check the battery voltage. Set the selector knob to 10V DC. Voltage reading of less than 3 volts indicates the battery is drained or dead. Use a known good battery.
If the battery is good but the phone still does not turn on, it is dead and have it checked by a qualified technician.
Nov 26, 2009 | LG RUMOR Cellular Phone
HP Pavillion 6000 battery issues
Hi Steve, If you haven't gotten any batteries to work properly at all and the problems are different each time, I would say the motherboard is shorting out the batteries and causing weird problems. One last thing to try if possible..
Try a known good working battery, if that battery doesn't work then its verified that the motherboard is bad. If the known good working battery works in that laptop then you got a bad batch and it will be a battery problem.
Since your laptop turns on with the ac adaptor means that the ac adaptor is good.
Jun 02, 2009 | HP Pavilion dv6000z Notebook
Hp compaq nx7400 - battery died and power cord will not turn comp
Some laptops will not power up with a completely discharged or faulty battery. Remove the battery from the laptop, plug in the power cord and try to boot the system. If the system boots, your battery needs to be replaced. Replace your battery as soon as you can, it's not a good idea to run the laptop for extended periods with an open battery bay.
May 07, 2009 | HP Compaq Presario V2000 Notebook
R51 2887 NQ2 Thinkpad (not under warranty) not powering on. The problem appeared 3 months ago for the first time, but going through some forums, the problem got temporarily solved by removing the...
First, the simple things need to be checked. Is the power supply line, from the wall socket to the computer input socket, in good condition. Best test is to try it on a known working Thinkpad or with a multimeter if one is handy.
Second, connect to an outside monitor to rule out faulty laptop monitor. If the known working monitor paired with the R51 works perfectly then you know it is your screen.
Third, does moving or flexing the computer by its base when running exacerbate the problem?
That will get some preliminary data.
Jan 24, 2009 | IBM ThinkPad R51 Notebook
Microsoft Xbox 360 Wireless Controller Logo
60 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
