Question about Zanussi 24 in. DE6965 Built-in Dishwasher
My electrolux 6115 dishwasher will not drain, it beeps constantly. when i reset it nothing happens
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Dec 11, 2009
My electrolux Dishwasher model ei24id30qs is beeping 3 times every 4-5 seconds and the drain pump ( or some motor of sorts) continues to run with the door open. Have opened the trhwn the breaker for hours...
I appreciate your post, kris!
From what you have explained your Electrolux dishwasher is beeping three times every four to five seconds. This could be a possible issue with your control panel. It may need to be replaced and this may not be a simple DIY job. If you need assistance locating a professional I would recommend reviewing your manufacturer's website for help. I hope this information is helpful for you. -Matt
Feb 11, 2015 | Electrolux Dishwashers
How to fix faulty door latch
These door latches are really poorly designed and tend to disintegrate over time
The easiest thing to do is open the door, unscrew all the screws around the door to take the face plate off.
Remove the two screws that hold the latch. You can try to reset the latch and put it all back together, or spend the $100 to buy a new latch online and install it.
I realise this is an old question, but it may help others.
Jul 09, 2014 | Electrolux Dishwashers
How to fix electrolux el 6115 door latch is faulty and doesn't click shut
It happens to skip latch and is no longer possible to close the door and turn on the dishwasher. The latch is in plastic material in which a system of levers provides the mechanical action.
Solution: Remove control panel and put latch back into normal position with the slot forward. Look the picture.
Dado
Service number kuds301xbl2
I would find the electrical breaker for this unit and shut it off for a minute, then re set the breaker thus resetting your unit.
Apr 28, 2013 | Maytag MDBH975AWS Stainless Steel...
When i turn the dishwasher on nothing happens at all.
wait 15-20 minutes and see if it starts - chances are it's "warming" up, or trying to drain old water.
Mar 14, 2011 | Electrolux 23 in. ESL6114 Built-in...
Dishwasher dishlex, continues to drain, ECO light flashing
if your dishwasher is constantly draining then it is most likely trying to remove something either water or debris that is stuck in either the drain line or the pump you would have to pull the unit out and remove the drain pump as well as the drain line and assure that the water is flowing into the drain sometimes ive also seen this happen when the drain goes into the disposal it sometimes gets clogged going into the disposal first thing you should do is look down the drain while its trying to drain and see if its a steady stream going into your drain or just a trickle this is one of the first ways to tell if you have a clog Thanks again Rick
Jan 10, 2011 | Electrolux Dishwashers
Electrolux error code 1, how to reset.
Also got error code 01. Unplugged dishwasher, turned off water supply, disconnected water supply line at sink so it had slack to pull dishwasher out of built-in space, removed two wood screws holding dishwasher to counter, pulled it out onto floor, put it on blocks as reader suggested, tilted to side 45 degrees, water drained out onto rags. Then restored to upright, restored supply line and opened valve at sink, plugged back in, unit automatically reset, returned to built-in, reinstalled screws to counter. Worked like a charm. Took more time to read everyone's advice than to do the job (about 30 min.). Thanks.
May 20, 2010 | Dishwashers
Zanussi 24 in. DE6965 Built-in Dishwasher Logo
260 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Starnley Johnwells
Starnley Johnwells
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
