Question about Canon PIXMA MP830 All-In-One InkJet Printer
I'm getting an error code of 6A00 on my Canon Pixma MP530
  • larry_d44ca May 11, 2010
    Did you press "Stop/Reset" then "On/Off" to reset the device?
  • 4,041 Answers
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
  • 18 Answers
SOURCE: canon pixma ip 3000 6A00 error
the error on this printer relates sheet feeder and or the logic board or the purge unit tin the printer if one of these items fails in the printer it causes this error the printer needs to be takewn to a canon service agent in your area for repairs the error can notbe fixed by the user. It class a a service error on the printer
Posted on Dec 04, 2007
SOURCE: canon mp530 getting error message 6a00
HI Guys 6A00 error usually cant't be fixed according to the service centre, I was lucky and actually bought an extended warranty, the service centre said that the MP530 are a good printer and worth fixing as they don't see many at all compared to other models and other brands. There was a broken piece of hardware that something to do with the print carriage. cheers vailey
Posted on Apr 18, 2008
komguy
  • 2306 Answers
SOURCE: canon pixma mp800 error code 6A00
6A00 means you need a new purge assembly. That's the unit that cleans the printhead. Part number is QM2-3032-000 around $30.00 but a shop should install it.
Posted on Jul 24, 2009
pineworks
  • 4041 Answers
SOURCE: My Canon MP530 printer has error code of 6A00. Can
Hi there
This answers with a titch more detail.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move.
And yes I have found all those things in a purge unit.
The offending item needs to be removed or the purge unit needs replacement.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model.
And it’s always a paper path error or purge unit.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Also clean the purge unit out make sure all is clean.
Posted on Mar 16, 2010
bschilz
  • 2049 Answers
SOURCE: Canon pixma all in one mp500 error code 6A00
6A00 is a problem with the sheet feed unit.
Manually move the print head left and right, and turn the printer on/off. I would also inspect the rollers for ANY debris... it can often be fixed by using "canned air" and blowing the interior out completely.
Posted on Apr 29, 2010
My Canon MP530 is giving 6A00 error message and alarm light is flashing along with copy button. i have replaced empty ink cartridges with new ones. Can anyone help, please?
Error code 6A00 indicates an error occurred in the AP motor during purging operation. You need to replace sheet feed unit, logic board assy and purge unit to fix it. Before replacement of the logic board assy, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or more, also replace the ink absorber kit when replacing the logic board assy.
Feb 09, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MP530 All-In-One InkJet Printer Canon mp530 error 6a00
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
Clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like
Dec 15, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Hello
Unfortunitly this is not an easy fix. IF you still have under warranty you can contact Canon and they will fix it. If its not under warranty they can refer you to the nearest Canon Service center.
The 6A00 error is an internal error which can be caused by one of the following things.
- Sheet feed unit - Logic board - Purge unit
Good Luck
6A00 error code
Unfortunitly this isnt an easy fix. IF you still have it under warranty you can contact Canon and the ywill fix it. If its not under warranty they can refer you to the nearest Canon repair center.
- Sheet feed unit
- Logic board
- Purge unit
Best of luck..
Nov 22, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Show the code 6A00 and the printer won't print. The lcd reads check printer then flashes 6A00
That error indicates a sheet feeder error, apparently its not something you can fix yourself and you will need to send it in for repair.
You will need to send it too an Canon approved repair center, calling Canon and asking them should reveal where to send it.
Aug 31, 2009 | Canon PIXMA MP530 All-In-One InkJet...
MP530 - Check Printer - 6A00 error
Hi
Hope it will work for you
Solution 1:
Solution 2:
Solution 3:
Dec 11, 2008 | Canon PIXMA MP530 All-In-One InkJet...
MP530 alarm and 6A00 error
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
ERROR 6A00
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=832&modelid=13371&keycode=2118&id=27509
this is a script error which can be fixed using this link i looked up the information for you.
just download from link this should help
May 07, 2008 | Canon PIXMA® MP530 All-In-One Printer
Canon mp530 getting error message 6a00
Jan 30, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
83 people viewed this question
old marine
old marine
