Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
The numbered keypad doesn't work - Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
    President:
  • 3,197 Answers
Check the battery.
Posted on Dec 10, 2009
SOURCE:
Sharp r-509fw Keypad problem?
You need to replace the control panel, the panel is all one piece buttons and all.
Jun 10, 2017 | Sharp R-520KS Microwave Oven
LG touchpad doesn't work
use the common sense,logically, fix it. God bless you
a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Aug 02, 2012 | LG Microwave Ovens
Inner keypad doesn't work
Your Phone Keypad Ic Deafult So Please Change keypad Ic
and keypad Problem Will Solved
Jul 24, 2012 | LG enV3 VX9200 Cell Phone
The letter keys amd number keys do not work
Could be a bad keypad or possibly a motherboard problem.I would try another keypad first if that doesn't work look to the motherboard.
Nov 16, 2011 | Acer Aspire One Netbook
The garage door opener inside the garage doesn't open or close the garage door. How do I diagnose? The model # is: 41A5389-1B
The model number you give is a part number for the logic board. Does your remotes work? Is it only the wall control that isn't working?
Sep 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
The garage door remotes and keypad works only when i,m very close to opener, will not work at more then 6 ft away from opener. sears hbw0777
How old are the batteries in the remotes and keypad? Replace the batteries. If that helps, then you have solved the problem.
If it doesn't help, then check the antenna wire of the opener. (Make sure it is extended down from the unit.) Note this doesn't apply to all garage door openers. (We have several models - some with the external antenna and some without.)
Does your garage have metal walls and metal doors? This can shorten the range between the receiver and the remotes or keypad. An antenna extension may be available.
I don't see the HBW077 as a model number at Sears Parts Direct or Manage My Life. Please check the model and let me know if I can provide any additional assistance. (Sears Parts Direct has parts for my garage door openers. Manage My Life has manuals for Craftsman and Sears appliances.)
I hope this helps.
Aug 04, 2011 | Garden
My number keypad has stopped responding how can i fix it please
Hello and Welcome to FixYa!
If your numeric keypad is not working please first make sure that the numeric lock button (may be a light too) are on. Try to press the numeric lock button once and then use the keypad. If this doesn't work try pressing it again.
If you have any further queries, please do not hesitate to comment again. If this solution was helpful to you, kindly rate it.
Regards, Waqar.
May 22, 2011 | Computers & Internet
Sharp Carousel Model R9H84B
I've attached the portion of the manual which shows how to lock & unlock this model.
If that doesn't work, unplug the oven for one minute, plug it back in aga9in, then try again.
If it still doesn;t work, then your keypad has failed, and they are no longer available for these model, so the oven would have to be retired.
Good luck.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Sharp R-230 Microwave Oven
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
55 people viewed this question
Top Sears Building Materials Experts
Mike
Steve Allison
Steve Allison
Are you a Sears Building Material Expert? Answer questions, earn points and help others
