Question about Nintendo DS Lite Console
Touch screen image double overlay
The image on my touch screen is being displayed twice, with the second occurence just a couple incremements above the first. Is there a way to fix this?
  • 26 Answers
Ermm it may be a software failure look for the nintendo ds software i'm not sure where to get it from google it it may help
Posted on Dec 10, 2009
HOW DO I CHANGE FONT SIZE IN WINDOWS 8.1? AND FONT SIZE IN AOL 9.7 FAVORITES.
Each version of windows does have an option to change the DPI
In effect that will make text larger, whilst not changing the size of the textboxes, and other controls on the form.
HOWEVER I strongly recommend that no one ever uses that setting, as it is an 'unclean' (not Kosher) solution to a problem.
Instead you should either -
- Get a bigger monitor
or
- Use a screen magnifier
The one I use is -
http://www.workerscollection.com/wcollect/english/html/mg_pro.html
It is not too expensive.
Once installed, tweak the settings so that it displays full screen, with no border.
I have been using this for years, and love it.
I have set the Scroll Lock key on my keyboard to turn it on and off
When I click it, the screen doubles in size. (2x magnification)
Thus everything is twice as big.
If you move your mouse to the top left of the screen, then you are seeing the top left 25% of the original screen.
Wherever you move your mouse, you are seeing that 25% of your original screen.
It is not an image, it is the actual screen magnified. So you can still click things, and type into boxes, etc.
I am 73, and refuse to wear glasses.
That program is invaluable to me.
If I were sent to Mars, and could only take 10 programs with me, that would be one of them.
Jan 15, 2015 | Computers & Internet
Canon touch screen stop working
If the copier still works but the touch display won't respond, you will need to have the touch screen panel overlay replaced. That is a very common problem that happens to those touch displays.
Sep 02, 2014 | Canon imageRUNNER 3035 Black and White...
How to reset touch screen
If the copier works but the touch display won't respond, you will need to have the touch screen panel overlay replaced. That is a very common problem that happens to those touch displays
Unlockmy lg microwave oven
As with most situations, it depends on the model number, but try this:
To set child lock:
1. Touch STOP/CLEAR pad.
2. Touch and hold 0 pad more than 4 seconds. LOCKED will appear in the display window and oven will beep twice.
To cancel child lock:
1. Touch and hold 0 pad for more than 4 seconds. LOCKED will disappear from the display and the oven will beep twice.
Sep 10, 2013 | Microwave Ovens
Treadmill touch screen display turns on then off
you may need a new display overlay. What is the make and model?
Jul 09, 2012 | Proform Power 1080 - Treadmills
How do i do a screen clabration on a brother pc-8200 sewing machine? Thanks for the help
try this
While pressing the start/stop, reverse stitch and needle position buttons, turn on the power to display the screen
for the touch panel adjustment mode.
2. While pressing the start/stop button, touch the touch panel at the positions marked by crosses (+) in order from 1 to
5.
(When touching the touch panel, use an object with a rounded tip such as a pencil or matchstick. Never use a
hard or sharp-pointed object.)
If the buzzer sounds once when cross number 5 is touched, the adjustment has been made correctly.
If the buzzer sounds twice when cross number 5 is touched, an error has occurred. In this case, touch the
crosses on the touch panel again in order from 1 to 5.
Never press the thread cutter button during this time. (Doing so may cause a malfunction.)
3. Turn the power off, then on again and check that the screen display and the touch panel positions are aligned
Jun 30, 2010 | Brother PS-1250 Pacesetter
Can you tell me how to access the front touch-screen full-keypad?
You can only have the front screen touch keypad when you touch twice (double click) in the area where you want to type. (for example when you browse on the internet, text messaging or adding contacts). If you can't use the touch keypad the phone will tell you (for example in MSN messenger, you have to work with the keypad inside the phone).
Apr 25, 2009 | LG VOYAGER VX10000 Cellular Phone
Convergence problem
This is out of the service manual
don't forget to write the setting to rom by hitting the pip button twice
Good luck and don't hesitate to ask questions
2.12.5 Convergence point adjustment
Adjustment preparation
(1) Select color to adjust.
“STATUS” - Green
“0” - Red
“ANT” - Blue
(2) Use 4, 6, 2, and 5 to move the cursor position
(dotted lines).
(3) Use thumb stick to move the convergence point.
(4) Three adjustment modes are available:
1. (3x3) Press “STATUS” 5 times (only works
when DCU is in uncorrected state)
2. (7x5) Press “0” 5 times
3. (13x9) Press “ANT” 5 times
For touch-up, only the (13x9) mode is necessary.
This will adjust every cross-hatch intersection point
on the screen.
For complete adjustment, start with (3x3) mode. This
will adjust center point and eight edge points only,
but will greatly reduce adjustment time. Then use
(7x5) mode, and finally (13x9) mode to finish
convergence.
If “S” distortion appears between cross-hatch lines
repeat (7x5) mode to change calculation process
while adjusting to remove distortion, then return to
(13x9) mode to finish touch-up convergence.
Adjustment procedure
(1) Receive any NTSC signal.
(2) Start adjustment at the center of the screen.
(3) Continue adjustment at next closest position.
(4) Adjust center area first, ending with edge sections.
(5) Press INFO button to perform calculation operation.
This process will take about 2 seconds and no
picture will be seen at this time.
(6) After interpolation, check convergence again and
repeat (1)-(5) if necessary.
(7) When convergence is acceptable, press PIP MODE
to write data to ROM memory. ROM WRITE? is
displayed to alarm system that ROM will be
overwritten with new data. Press the PIP MODE
button again to write displayed data to ROM.
(8) DATA WRITE TO ROM will take approximately 4
seconds and no picture will be displayed.
(9) Green dots will be displayed when operation is
completed.
(10) Press MUTE to return to convergence pattern, then
confirm again convergence is acceptable.
(11) Press PIP MODE (ROM WRITE) mode, then press
PIP CH to initialize sensor data positions.
(12) Input any 1080I signal.
(13)Press EXIT key 5 times to exit video mode.
(14) Select an input with 1080i signal.
(15)Access menu and select ASPECT 5 mode.
(16)Press the SERVICE SW. ONLY button to enter to
DCU crosshatch signal.
(17)Repeat steps 2~11 above.
Notes: (1) Display only green for easier adjustment and
match to jig screen. Press “MENU”, THEN
PRESS “STATUS”.
(2) Perform interpolation and data write to ROM
after green adjustment. Once green has been
confirmed to match jig screen, the jig screen can
be removed. Do not readjust the green color
after jig screen has been removed. This is now
your reference color.
(3) Display green and red only and match red to
green.
(4) Display all colors and match blue to green and
red. Touch-up red color if necessary.
(5) Existing DATA in ROM can be read by pressing
the SWAP button 2 times. This data can be used
after replacing a component (CRT, DY, etc.)
Where complete convergence adjustment is not
necessary, be careful not to overwrite this data.
DO NOT write cleared RAM data into ROM or a
complete convergence adjustment will be
necessary. Remember to try MAGIC FOCUS
before starting convergence adjustment to
minimize adjustment time.
Feb 01, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Screen is starting to look as if it has double vision
rear projection is just that usually 3 projectors overlayed ontop of each other each in a different color. one or more of your projectors needs to be aligned, there is an option in the set up to do this manually where x's or +'s are displayed in the different colors and you need to move them so they are all overlayed ontop of each other. then when a picture of a person is projected you should only see one of them. how to get to that set up screen to preform the alighnment will differ from brand and model but all projection tvs have this some have a program to do it automatically. this works great when the tv is new but as they age manually adjusting is better nothing is as delicate as the human touch.
Jan 05, 2009 | Hitachi Televison & Video
Korg triton Touchview screen not working properly
The Korg Triton touchscreen has two main parts - The LCD screen and the touch overlay. Between the two is a type of gasket. It is really just an adhesive, but it does help keep out moisture and dust. If you were to remove the screen, you could separate the two parts, clean it and use double-face tape or glue to reattach. You can also get a replacement LCD screen, touch overlay or touch-LCD assembly from a number of places on the internet. They are not cheap, unless you purchase a generic touch overlay or LCD and retrofit.
As for repair in your area... try contacting Korg at http://www.korg.com and look for authorized repair centers.
Jun 23, 2008 | Korg Legacy Collection
Nintendo DS Lite Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
