Question about IBM E74 17" CRT Monitor
Blinking Light Hi There, I've just installed a USB 2 PCI card. I've restarted my system but the monitor is not displaying anything and the front green light is flashing. I've reconnected the cables several times and nothing has changed. I tried hooking up the monitor to my laptop and it works fine. Any suggestions?
  • Ajemy  Rashid
    Ajemy Rashid May 11, 2010
    what do you mean by install a usb 2 pci card.?
  • 180 Answers
Or try to remove the card. Restart it back. If your system goes fine. It indicate that the card was not properly inserted or defected.
Posted on Apr 17, 2008
I think it is okey just go on....... hooking you own computer.......its nice bro......
My graphics card does not show up on my Device Manager
I had just run into the same problem while installing my new graphics card earlier today. This is what I did to fix it:
1. Uninstall the new driver for the new card, if you can, in control panel if it installed.
2. Reinstall the new driver.
3. Go to Device Manager and UNINSTALL, not disable, UNINSTALL the on-board card. Don't worry this won't kill anything. It will ask you to restart your computer. Click yes.
4. While the computer is restarting and on the shut down screen for windows unplug the monitor cord from the onboard card and plug it into the new card.
5. Wait for windows to boot up and load the new drivers. It should be working with the correct drivers.
If it takes more than 8 minutes for anything to come on the screen(icons, login screen, etc.) reboot your computer again.
Apr 08, 2013 | PowerColor Go Green AX5450 512MK3-SH...
My monitor no display and light is blinking
if the monitor light is blinking this suggests that, there is no display signal coming from the tower. This could be because of the following .
1. Bad video card 2. Bad video software
To check,where the problem is , power of the system tower and remove the power cord from the back of the tower. Press and hold the power buttoon for 10 seconds and the reconnect the power cord and turn the tower on. Check if there is any display or the status of the light changes from amber to green for even a small instance.
If the light changes to green and back to amber the video port on the tower is bad
Alternatively you can connect the monitor to another desktop or laptop to check if the same is working correctly.
Thanks for using fixya
Proton
Oct 13, 2012 | Computers & Internet
I have a compaq presario pc. Motherboard is Asus P5LP-LE : Lithium UL8E. I have 3 Gig of RAM installed, a 400w PSU. I have just purchased a new graphics card - Radeon HD5570. My MoBo has 1 PCI-E x16 and 3...
I think you have not connected power connector to your Radeon HD5570 .
This graphics card have 6pin power connector .
You need a 6pin power connector cable that comes with the graphics card box.
1.First connect your 6pin power connector to Graphics card.
2. Then connect other part of the cable to PSU.
Hope it will work for you.
Thanks for using FixYa.
May 14, 2011 | Computers & Internet
Display skcrin black but LED not blinking
First, connect this monitor to another computer, if you still do not get a Windows image on the Samsung LCD monitor then it is faulty. The fault could be a faulty inverter board that supplies high voltage to the CCFL lamp or the fault could be a faulty CCFL lamp.
Parts for this monitor could be avaiable from LCD Parts, theie WEB site is :-
www.lcdparts.net
Jun 23, 2010 | Samsung SyncMaster 510N (Silver) 15 inch...
Problem installation video card
Hello Virna, i have that exact graphics card and dell GX270 desktop here at home, tho it has been awhile since i removed the Nvidia PCI card for a more favorable AGP card. From what i remember, first check your BIOS (hit F2 on startup) and select integrated devices, scroll down and make sure your default video output is either PCI (if available) or AUTO) exit saving changes. If that yields no result. Plug in a second monitor to your old integrated video output, if you can view windows after bootup from there, then you can install the proper Nvidia display driver for windows Xp (available here: http://www.nvidia.com/object/winxp_175.19_whql.html ). After installing, right click on the desktop, select properties, display settings tab, and make sure the Geforce card is the main monitor and the desktop monitor. Click apply, unplug the integrated VGA output, and restart. Hope this helps.
Apr 03, 2009 | Evga nVIDIA GeForce FX5500 Video Card,...
MY MONITOR NOt WORK WHEN I USE MY NVIDIA PCI CARD ?
Most monitors made in the last decade will put some kind of warning on the screen if they are not receiving a video signal so if you get no on-screen display at all, regardless of whether the system is on or off, you probably have a monitor failure.
Try to borrow a monitor temporarily so you can try the following:
- If the borrowed monitor also shows nothing; your card has failed. - If it does give you a normal display, go to the Control Panel, open theSystem folder, select Hardware, then Device Manager. If there is no 'X' next to the Display adaptors, expand that entry and delete the monitor shown. Then go to the Monitor entry, if there is no 'X' next to the entry, expand it and delete the monitor listing.
- Power down the system.  - Disconnect the borrowed monitor and reconnect yours.  Make sure the standby or power LED is on your monitor. - Restart the system
If Windows has simply trashed the driver, it should 'find' a 'new device' and install some kind of basic driver.
If nothing has worked; then the card is dead. If it worked with the borrowed monitor, then your monitor is dead.
BTW; if you really have had the card only 'weeks,' it will still be covered by the manufacturer's warranty; most Palit cards I saw when searching had at least a one year warranty.
Nov 24, 2008 | Palit Microsystems PalitDaytona GeForce2...
Motherboard installation
Hello mecompe,
If you installed an AGP graphics card before your fist boot of the system, you will not receive display. By default the onboard graphics is set to boot display. (If this is the case, remove the AGP graphics card & boot the system). The Asus P4SGX-MX can only use a 4x AGP 1.5volt (only) card.
There is an order of sequences to perform before installing/ adding an AGP graphics card on to the board when the board also uses an integrated graphics card.
First, shut down the system & unplug the power supply from the PC. Connect your monitor to the VGA port at the rear of the board. Remove the AGP card. Re-connect the power supply & boot the system. You should have display? Re-boot the system. As the system starts up press the delete key on the keyboard every 2 seconds. The bios main menu will load. (Open your manual). Go to
section 2.4.3, page 2-20 under Advanced, PCI configuration. Set Primary VGA bios to
[AGP VGA Card]. Save the bios & exit. The system will auto restart. Press & hold the power on/ off button on the PC case until the system shuts off. Unplug the power cord from the PC. Insert the AGP card into the AGP slot. Connect your monitor to the AGP card.
Check all internal data & power cables, (Incase something came loose). Re-connect the power cord & boot the system. You should have display! Install your video software.
If your using the integrated VGA PCI graphics card, go over the bios settings page 2-18 & 2-20.
Need the Asus manual? Click this link;
http://support.asus.com/download/download.aspx?modelname=P4SGX-MX&SLanguage=en-us
To view the manual you'll also need Adobe PDF reader, click this next link for Adobe.
http://www.adobe.com/products/reader/
(The green led (light), means standby. The board is receiving 5volts DC.
If you still do not have display just let me know.
Good luck mecompe!
Mike
Oct 28, 2008 | ASUS P4SGX-MX Motherboard
AUS A7N8X -X Mother board AMDAthlon 27648 CPU No picture
if this is a built sustem out of the box with old monitor try another monitor oddly enough some arent compatible, you can check by looking at the prong patern.
May 10, 2008 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
Blinking Power LED ... no other action
Hi switchblade, Some of this will seem basic or even a rehash of what you?ve already done but please keep an open mind. The one thing I?ve learned over the years is never assume anything especially when things aren?t working like they?re supposed to. -The first thing I would do is to check each screw, card, connector and component you installed to make sure nothings being shorted out or is improperly connected. Common occurrences are screws touching capacitor or other component leads. -Check the power connectors to make sure everything is connected correctly and that all the contacts are still mounted in the plastic connector correctly. -Check the output on your power supply and verify it?s rated for your motherboard. It?s possible that whatever caused them to replace the motherboard could have been caused by a defective power supply or vice versa. -Make sure the motherboard is correctly grounded to the chassis per your instructions. Typically the mounting screws touch a grounding plane on the motherboard and in turn ground that to the chassis. If your using plastic mounting studs that might be a problem. -Verify the power switch is working correctly. -Make this as basic a machine as possible: remove and add in cards (except primary video card), remove all USB components, reduce the size of your memory (RAM) and if you have multiple hard drives remove all except your boot drive. -Try a more basic known good video card, a PCI if you have one. -Again whatever problem caused MSI to warranty replace your motherboard could have damaged your processor or memory. I would have expected a beep code but if you?ve gotten this far without resolving your problem we?re running out of possibilities. -If nothing changes can you tell us some more about the status of the computer or what led up to this? Did you just build it; just install a new part, power problems, anything? Let us know what you turn up and please don?t forget to rate the posting.
Jan 06, 2007 | MSI K8MM-V Motherboard
IBM E74 17" CRT Monitor Logo
225 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
