Question about JVC AV-36D302 36" TV
My kids were playing with the buttons on the tv, and itseems like the picture is now "stretched" vertically - the tops of heads are cut off, and it seems like some of the picture is missing from the sides. we've tried everything in the menus, nothing works.
  • 603 Answers
There should be a zoom, or strech, or even the letterbox option somewhere. What your describing is a enlarged picture that doesn't fir the screen, like if I select zoom on my remote.
Posted on Dec 10, 2009
The heads of the people are cut off the picture is to high
If the top of the picture is stretched and off the screen and the bottom appears normal, this is usually a vertical deflection problem and will need a repair tech to fix. If you continue to watch the set with this problem present it will only get worse and can cause more problems.
Nov 27, 2009 | RCA P52926 52" Rear Projection Television
I can't see the whole picture. the tops of everyone's heads are cut off. Normal, stretch, zoom format does not fix it
check to see if tv has a function call aspect ratio
that should take down the picture size not screen size
Aug 17, 2009 | RCA F32650 32" TV
Picture is stretched on top and compressed on bottom
the problem of your tv is in the vertical section,you need to replace the capasitor in vertical section .
Feb 18, 2009 | Konka FL2799U TV
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Vertical Stretch
You need to adjust "vertical height" in the service program. You need to put the set in "service mode" to do this adjustment. If you google "enter service mode RCA F32665" you should find the procedure. It will be listed in abbreviated letters such as VERT SIZE or VERT HT. Follow the instructions for entering service mode and saving the data closely!! The data you change will be listed as a number between 1 and 63. The number will only need to reduced by a small amount and you can still see the picture behind the data and watch it shrink as you adjust the number down.Always burn the new number to memory (if required) before exiting service mode. Good luck
barneyluc
Dec 01, 2008 | RCA F32665 32" TV
Picture is stretched on top and bottom of screen
you have a vertical linearity problem. change the vertical output and components.you need a qualified tv technician to solve this problem
Aug 15, 2008 | Emerson EWF2703 27" TV
Horizontal/Vertical Adjustment
Your XBox's User Manual should have details on this Settings & if you can't find it, you'll have to contact Customer Care.
May 12, 2008 | RCA 35V432T 35" TV
32" rca picture stretched
Before you fool around with this, it may be under warranty. Check that first. Second, does the picture stretch in both directions or just vertically? If just vertically is it more pronounced at the top?
Thanks,
Dan
Apr 03, 2008 | RCA 32V420T 32" TV
Top of screen is stretched
There are capacitors in the vertical circuit that can cause this problem. You may be able to find these capacitors by using a hair dryer pointed to the suspected bad cap and then when the problem happens you can spry a little cooling spray on it to see if the problem clears up. The vertical output IC could be going bad but this can be checked the same way. if you have no TV solid state repair experience, play it safe and take this set into a local repair depot. Good Luck
Mar 17, 2007 | Toshiba MW24FN1 24 in. TV/VCR/DVD Combo
JVC AV-36D302 36" TV Logo
203 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
