Question about LG LRFD25850 French Door Refrigerator
Lights stay on inside Sears (really LG) french door refrigerator
This is the second time for this problem. cost me over $300 first time and now it has happened again. Melted plastic covering over lights. Food in top shelf ruined. Appliance is three years old.
Model # 795 77316600
That should be a covered repair. There was a safety bulletin on that. Call Sears and complain. Tech should have known that.
Posted on Jan 12, 2010
Testimonial: "Thanks so much I did get a fix for this time but I guess they won't take care of the first time. I appreciate your help."
    Problem Solver:
  • 11 Answers
Hi illinicardsf,
I have seen this problem several times. The solution is to replace the main control board p# 6871JB1375E and the light socket harness p# 6621JK2003B. LG has updated the main control and added a thermostat to the new light socket, preventing it from overheating.
Good Luck.
Posted on Dec 10, 2009
How do I remove melted plastic from top stove burner, kitchen aid oven/stove, branch new
Clean the stove so all food residue is removed. Take a single blade razor blade and very slowly scrape the edges of the melted plastic. Blade should be held at a low angle, and only a small amount should be cut away at a time. It will take time, but the plastic will come off.
Once clean, use the manufacturer approved cleaner to clearn the area.
You may want to try to turn the burner on for about 10 seconds on high, and then off to help soften the plastic. Be careful to not burn yourself.
Mar 08, 2015 | Kitchen Ranges
Samsung microwave internal vent cover melted
The temperature reached a high enough value to make the plastic melt .The device ran for too long. The device ran without any substance (food) to heat.
Nov 26, 2013 | KitchenAid KHMS145KSS Microwave Oven
Hole in Maytag Neptune front load washer door and flaking or melting of door.
I've owned the same Neptune since 1999 and had this problem happen to me twice, the first time the inside molded plastic door melted through in a circular pattern and had to be replaced. The fact that it was circular indicates that something was rubbing during the high speed spin. That something was a stiff bottomed duffle bag that was rubbing on the plastic door during high speed spin. The washer was full of other clothes that didn't allow the duffle bag enough room in the washer tub, hence it pressed against the plastic door. The second time it happened I got a circular groove melted in, but not through, the plastic door... caused this time by a small child's back pack. I would make sure "rigid" items have enough room to "float" in the tub cavity by not putting in other clothing that over packs the washer.
Oct 15, 2017 | Maytag Neptune Washing Machines
My microwave has melted a huge hole 17 cm in diameter in the plastic cooking cover - what is wrong with the microwave.
Nothing is wrong with the microwave, the plastic cover was either not microwave suitable or a splash of grease/oil/food was stuck to the plastic and melted it.
Jan 24, 2011 | LG LMV1630ST Microwave Oven
Interior Lights "ON" With Doors Closed
Jane0901. Go to the following web site. Look at the solution section concerning Sears Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}Service flash "sf46-515". I am "DaleCos" and have the same problem. I have reported the probem to Consumer Reports and the Consumer Product Safety Commission. More people need to contact these two organizations. Good luck.
http://www.fixya.com/support/t968825-interior_lights_doors_closed
Sep 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Door display freaking out
Very common, this unit was mfg by samsung for ge and maytag. Its your hi voltage control board located on the back. You might call maytag and see if they will pick up the costs for this repair. There was recently a major rework kit for the samsung and ge units, but maytag opted not to follow the same. Call them and raise heck and let them know your food costs that spoiled and that your afraid to touch it because of the actions of this ele problem.. G luck
Apr 02, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Microwave (inside on right hand side wall) has a plastic cover. Behind this cover while popping popcorn there was bright yellow/red flashing/light, it started to melted the plastic cover within seconds....
You don't say which make/model microwave you have, but on every model I have ever seen the thing that sits behind the plastic cover is the magnetron - the bit that actually generates the microwaves.
Unless the microwave was a fairly top-end model, you might well be cheaper to just buy a new one.
Hope this helps,
Matt
Mar 27, 2008 | Microwave Ovens
795.77573600
I just saved my fridge / home too, smelled what I thought to be an electrical fire when I opened the Trio doors, immediately looked at the bulbs as a probable cause, and sure enough, the base of the bulb sockets were burned-brown and the plastic housing was to hot to touch without a hot-mit.
Unscrewed the bulbs and set aside out of children's reach and combustable materials.
I'm filing a complaint and service repair today. 8/3/08
Sean-Jon
Nov 07, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
LG LRFD25850 French Door Refrigerator Logo
459 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
