Question about Toshiba 55H70 55" Rear Projection Television
I have a Toshiba 55H70 that started with convergence issues when we moved. I have done some reading and understand that this is a common problem. I ordered new IC chips and installed them, I also checked the resistors. The problem has not changed at all the colors still do not line up and the pic is distorted. Any ideas?
  • 2 more comments
  • Steve Dec 10, 2009
    Ok, I've looked for the fuse that you described and I don't see it. I'm looking on the green video board, correct? Not the brown power board. Also the fuse that I'm looking for, is the board label FA something or the fuse itself? Thanks
    I found 6 fuses that were labeled with an F none were labeled with an FA. I'm assuming that F stands for "fuse", C for "capacitor", and R for "resistor". If it is a fuse then am I correct in thinking that it should have little resistance? The fuses on the board all have either 2 or 3 ohms of resistance.
    Yes if you could that would be great. Email is nutcase2be@gmail.com What is the best way to see/ get a copy of that service bulletin? Thanks for all the help, I really appreciate the info. and help.
    Never mind about the bulletin, I see that the part num. is just followed by a "T".
  • 834 Answers
This is a very old set and the problem you descrbe , sounds like the ics are not getting their -32 and +32 volts and this could be a fuse i do not have a diagram on habd due to age and I checked toshiba website and they no longer support this set i can tell you that
the fuse im talking about has a label of FA something it looks like a rectalngle cap take a look arounf the deflection board that is the one with the flyback on it
Posted on Dec 10, 2009
  • 3 more comments
  • Dave Naylor
    Dave Naylor Dec 10, 2009
    no you should be looking on the power board and it should be labeled on the board itself
  • Dave Naylor
    ok then they are good the problem in in the convergance digital board , and in check not avail
  • Dave Naylor
    the fuses i was talking about are f 850 and 851 located near t852 if you would like i did find the diagrma and i could try to send it to you via email if you want to supply me you email address
  • Dave Naylor
    there is a service bulletin to replace the convergance ic with 392-110 T only they are a shronger ic
  • Dave Naylor
I can't get the red color to move and converge with the blue and green ... HELP?
You have a bad resistor 1.8 ohms it controls the red convergence
you have 3 of them all are 1.8 ohms 1 watt they are located in front of the Convergence ICs STK392-110
Aug 13, 2010 | Toshiba 55H70 55" Rear Projection...
Power light bliking
common on these models is open fuses and convergance. the blinks give a code to the issue. need to know the blinks , count the blinks please.
Jul 08, 2010 | Toshiba 55H70 55" Rear Projection...
Color convergence issue.
Yes,U know how to solders?Must replaced 2 convergence ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairworld.com to buy a convergence to repair it ur self.The shop will cost U $300 for parts and labors.
Mar 27, 2010 | Toshiba 55H70 55" Rear Projection...
Toshiba 55h70 Convergence IC
I used the SONY stk180's on my 55h70 and works great...2 years no problem.
Get the real thing though....the knockoffs do fail
I also made sure the contact surfaces between the IC's and the heatsinks were properly cleaned and used "Arctic Silver Thermal Paste" applied in an even thin coat on all contact surface areas.
Mar 20, 2008 | Toshiba 55H70 55" Rear Projection...
Toshiba 55h70 turns self off
It sounds like your Convergence IC's have gone bad. This is a $300-$600 repair depending on where you live. I have recently changed them myself and it's not that hard if you have common sense and patience. If you do it yourself, you can do it for under $100.
The parts you need are 2 STK392-110 convergence amps and it's best to replace all 6 resistors that are related to the convergence amps as well.
Part numbers on the resistors are 24323129 and you can find then at http://www.vancebaldwin.com/products/?TBA&start=4501
Mar 10, 2008 | Toshiba 55H70 55" Rear Projection...
TN55X81 Rear Projection color separation - convergence problem
You shouldn't need to do a board replacement, all you should need to do is manually tune the convergence.
You can do this with the built-in user tool, but there's also a far more powerful set of options in the service mode. To save you the trouble (I advise doing a LOT of reading before attempting any of this) here's a solid set of various tutorials based on what form of "separation" you have occurring:
http://www.keohi.com/keohiHDTV/brandspecific/toshiba/servicemenu/servicemenu.html
Nov 21, 2007 | Toshiba 55H70 55" Rear Projection...
Double imaging
The Toshiba 55H70 is a standard rear projection set. It does not have a "lamp", it has 3 picture tubes. When the colors suddenly do not line up on the screen, it means that one of your convergence output IC's has burned out and needs to be replaced. This is very common on those sets. If your set is using the STK392-110 IC's, it is probably a good idea to go ahead and replace both IC's with the newer upgraded STK392-150 IC's. The IC's should be replaced and the convergence circuits realigned by a qualified tech familiar with Toshiba projection sets.
Sep 11, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba 55H70 had convergence problem fixed that now vol.went out
check to make sure that the tv switch on the back panel for surround sound is not in the on position check the customer menu to make sure that the speakers are turned on
Sep 28, 2006 | Toshiba 55H70 55" Rear Projection...
Toshiba 55H70 convergence problem fixed but now vol.is gone
I just posted a question about a convergence problem( juice07 ). I am unable to adjust the red color in the convergence adjustment mode. Did you have a similar problem ?? Please help.
Sep 28, 2006 | Toshiba TP50H50 50" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
147 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
