My lenovo keeps rebooting..when I select ''last known'' it shuts down and restarts the process again
  • chrissydenne Dec 10, 2009
    Thanks for your quick response. I tried to select that and it goes right back to rebooting and not getting me to the start screen
    I'm not good at these things but does that mean to reinstall the disk I first used when setting up my pc?
  • 26 Answers
Start in safe mode and do a system restore pick a date before the problem came about its usauly a piece of hardware or virus.
Posted on Dec 10, 2009
  • 2,404 Answers
Try to see if you can boot up the computer into safe mode. Keep pressing the F8 key as you turn on the computer and when it gets to the boot menu choose "Safe Mode".
If you can get into safe mode then go into the start menu and go into the system tools folder and then choose system restore. Choose a date on the calendar when the computer was last working properly and let the system reboot and hopefully that will take care of the issue.
If you can't get into safe mode or windows normally then that means windows is corrupted and you'll need to wipe out the drive completely and reinstall the OS and device drivers.
SOURCE:
Factory reset lenovo g580
Step 1:
There are a variety of reasons you may need to reboot a Lenovo laptop. These can include the installation of a new program, the dreaded blue screen of death or to free up memory that has been hijacked by a program that is now closed. There are three ways to reboot and all are simple to accomplish.
Click on your start menu button on your screen. Click on "Shut Down" or "Turn Off Computer." Click on the drop down box if you are running a version of Windows before XP (such as 2000 or 98). Select the "Restart" option and then click "OK." On XP or later versions, click on "Restart." The laptop will then reboot. Press and hold down the "Alt," "Ctrl" and "Shift" keys simultaneously. This will bring up the Task Manager. Pressing and holding the same keys again will force the computer to shut down. Press the power button to reboot the computer. This feature should be used when the mouse has stopped working and you cannot access the start button. Hold the power button in the "Off" position for approximately 5 seconds. This will force the machine to shut down. Press or slide the button again to reboot the laptop. Use this process when you get the "blue screen of death" or the computer is not responding to either the mouse or the keyboard.
Feb 22, 2013 | Lenovo Computers & Internet
Pc wont boot up
Restore to last known Good Configuration:
To use the Last Known Good Configuration feature, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Select the Last Known Good Configuration item from the menu and press [Enter].
Keep in mind that you get only one shot with the Last KnownGood Configuration feature. In other words, if it fails to revive your WindowsXP on the first attempt, the backup copy is also corrupt.
Use system utility software like RegInOut after restarting windows.
Jan 01, 2012 | Computers & Internet
Computer keeps shutting down
Restor to last good known configuration:
Dec 29, 2011 | E-Machines Computers & Internet
Studio 17 laptop stalled during uploading of a music cd into ITune libray. Manual shut down and reboot resulted in stalling of reboot process at 3/4 of the status bar with only the dell logo on black...
AS YOU ON THE SYSTEM AND EVEN BEFORE WINDOWS STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL MODE.
IF THIS DOES NOT WORK SELECT "LOAD WINDOWS WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY SORT OUT YOUR PROBLEM.
PLS REPLY OR COMMENT. THANKS
May 16, 2011 | Dell Studio 17 Laptop
CANNOT GET PAST THE VERIFACE LOGIN yesterday i was using it fine but today i cannot get to put my password in it keeps going to veriface and in circles
hi
just restart the system
then press "F8" function key continuously while starting windows
it shows some options like
safe mode
last known good config
and so on
select
if that not worked
then again try select safe mode then restart
if problem not solved replay me
Apr 21, 2011 | Lenovo G550-29583AU Notebook
My toshiba Satellite A215-S7422 System unit, dose not shut down until the batries runs down.
1. It means the normal shutdown process is not working!
2. Try to press the "Power" button continuously untill the system shuts down!
3. Restart the system.
4. Press F8 key to get the advanced booting options.
5. Select the last option "Last Known Best Configuration"!
if it don't helps tell me...tc! :)
Jan 05, 2010 | Toshiba Satellite Pro A210-EZ2202X...
My pc is restarting automatically continously when i turn on my
Does it show BLUE Screen, or does it show the Windows loading before it restarts?
If Bluescreen, something happened to root system files and you need to REPAIR
1. Shut down PC, pull out all USB devices, Floppies and insert Win CDROM
2. Power on
3. Press any key to boot from CDROM
4. Select Install
5. Select Repair
6. Ans questions and let run 30min
7. Remove CDROM
8. Reboot - it should work now
If Windows Logo, A device or driver you or MS or Mozilla or... installed for you malfunctioned and you need to start in LAST KNOWN GOOD mode
1. Reboot
2. Press F8 and hold down
3. Enter Password if asked
4. Select "Last Known Good"
5. When stable and logged in, Reboot
Jan 18, 2009 | Microsoft Windows XP Home Edition
Hi from london, have new acer aspire 1 zg5 new keeps shutting down after boot can u hlp pls?
Try booting the system to Safe mode.
To boot to safe mode:
Restart the computer. As soon as the BIOS has finished loading, keep tapping on F8 key on your keyboard. When the Windows Options menu appears select the "Safe mode" then press Enter.
Once you managed to boot to Safe mode, change the computer startup and recovery settings by right-clicking "My Computer" then select Properties. Select Advanced tab. Under Startup and Recovery, click Settings. Uncheck the box for "Automatically restart" under System Failure.
Reboot again normally, see if it will reboot again by itself. If you managed to make the system boot normally, proceed to Events Viewer to find out what is the caused.
If the system failed to boot normally after doing the above, you might want to boot the system to "Last known good configuration"
Jan 11, 2009 | Acer Aspire 3690-2196 Notebook
HELP!! (dell precision 340) im getting 4 screens when i turn on m
Reboot into Safe Mode by repeatingly tapping on F8 while in process of rebooting and then select "last known good configuration". If that fails reboot again to safe mode and select safe mode with command prompt and in the command prompt type "chkdsk /f /r " <enter>
If that doesnt work do place your Windows CD into the Cd-Rom, reboot and select option "Repair"
Jan 02, 2009 | Dell Precision 360n PC Desktop
My computer won't shut down it just keeps restarting
The most common shut down problem is that the system will reboot rather than shutting down. In most cases, the reboot is triggered because Windows XP is designed to reboot after a critical failure. To stop windows from rebooting in case of a failure, you need to take the following steps:
Right click on My Computer, Select Properties, Click on advance tab, Click on Settings under Startup and Recovery, Uncheck the option Automatically Restart under System failure, Click Ok twice and try to shutdown the pc. If it shows any error code then let me know
Nov 24, 2008 | Toshiba Satellite M65-S809 Notebook
Computers & Internet Logo
132 people viewed this question
Alun Cox
k24674
