Question about Mitsubishi WT-42311 42" Rear Projection Television
The mitubishi wt-42311 42in won't cut on at all now, what will be the average cost to get the problem fixed.
I have the same problem. This is the second time. Cost me 350.00 the first time.
Posted on Jan 27, 2008
Tv turns on have sound but no picture for ages
If you are ready for some expensive boards you can try to fix or have it fixed. Average boards in this set are well above the average cost of similar parts in other sets, from a person who works in a shop---IF it can be fixed expect well over 200 dollars as a average.
May 25, 2012 | Philips 42PF7320A 42 in. Plasma HDTV
How much will it cost to fix the fuel pump on my 2000 alero
you will probably won't be to happy about this: you can't necessarily fix it as you can replace it. the fuel pump will probably range from 120-200 dollars depending on it's performance/where you get it. and if you are having some one else fix it the labor will make it cost much more. It cost about 75$ an hour and takes 2-3 hours. (average)
Jun 29, 2011 | Oldsmobile Alero Cars & Trucks
I just want to download the Microsoft Word and i don't mind to pay how I do that? can i just download word without all the other thank you Raaul
Raaul, you can download Word here
http://emea.microsoftstore.com/UK/en-GB/Microsoft/Word-2010?WT.mc_id=pointitsem_Word_download&WT.srch=1&WT.term=microsoft+word+download&WT.campaign=6085&WT.source=google&WT.medium=cpc&WT.content=623199605
Apr 03, 2011 | Computers & Internet
What's the average cost to fix a cooling system on this vehicle?
Depends on the particular problem, if your heater core has a leak you will be spending more than the value of the car to fix it. If you have a leaking hose a twenty buck part and thirty bucks labor. Now at a dealer that hose will be 200 dollars to fix. What is wrong and who is going to fix it? There is no average repair cost.
Oct 12, 2010 | 1994 Volvo 850
I have a model WT-42313. The convergence of the red is off to the right if you are looking at the screen. I have tried to use the advance settings, but the red will not shift left. Is there any thing else...
You have to replace the stk 392-250's(convergence ic's) and possibly a resistor or two. We've fixed several of these. It will probably cost between $250.00 - $350.00 from most repair shops to fix.
Jul 29, 2010 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi WT-46807 Bottom of picture cut off
YOU HAVE A VERTICAL DEFLECTION PROBLEM, THE RETURN CAP IS DRYING OUT AND MUST BE REPLACED
Dec 27, 2009 | Mitsubishi WT-46807 46" Rear Projection...
My car is jerking and will stall when the air is on
Look at your RPM gauge, before and after, putting on the A/C. Does the RPM drop with the A/C on? May need to adust the idling or check the throttle sensor
May 04, 2009 | 2001 Mitsubishi Eclipse
20" TruFlat cuts on and off on it's on
Hi
This is power supply issue! a defective parts need to replace. like power oscillation. here in the philippines the cost is about 750.00 php.
Thanks!
Dec 29, 2008 | RCA 20F420T 20" TV
Powering down
THAT'S CORRECT, YOU NEED SOMEONE WITH ELECTRONICS SKILLS TO FIX THIS PROBLEM. YOU HAVE A POWER SUPPLY PROBLEM AND I BELIEVE THAT THE CONVERGENCE IC'S HAVE TO BE REPLACED TOO.SO CALL AN EXPERT IT WON'T COST MORE THAN $350.00
Aug 25, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46809 Intermittent color problem
I have the MITSUBISHI WT-46809 46" HDTV CONVERGENCE IC PROBLEM as well. I just ordered the STK392-570 IC for 7 bucks and I am going to attempt to switch them both out (two of them). I am getting the overstated "bow tie", "RBG separation" issue that you are talking about. I am going to attempt to de-solder the intergrated chips and put new ones in. I figure it is worth the shot, insted of paying 350-650 bucks to have some **** with average skills do the same I figure it is better to have this **** with average skills do it and keep the cash. I will let you know how it goes.... DJ
Feb 24, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-42311 42" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
