Question about Apple MacBook Mac Notebook
Disc won't eject
My macbook won't eject my CD.
I've searched and tried everything thats been suggested, i've done the 2 credit card thing, i've used terminal, i've used force eject.
each time, it goes to eject, all the correct noises happen, then just before its ejected, it swallows the CD back in. Its just a normal music CD.
any help is greatly appreciated, i'm on the verge of taking it apart!!!
  • petewhelan82 Dec 11, 2009
    ah, you're a prick! right! cheers for that!
  • 21 Answers
1. force turnoff computer than try to eject
2. use tweezers to grab it
DO NOT TAKE APART
THIS COULD RESULT IN ELECTRIC SHOCKS
Posted on Jun 29, 2010
How do you force eject a disc from a macbook pro?
Five ways to eject a stuck CD or DVD from the optical drive
Ejecting the stuck disc can usually be done in one of the following ways:
1. Restart the computer and after the chime press and hold down the left mouse button until the disc ejects.
2. Press the Eject button on your keyboard.
3. Click on the Eject button in the menubar.
4. Press COMMAND-E.
5. If none of the above work try this: Open the Terminal application in your Utilities folder. At the prompt enter or paste the following:
/usr/bin/drutil eject
If this fails then try this:
Boot the computer into Single-user Mode. At the prompt enter the same command as used above. To restart the computer enter "reboot" at the prompt without quotes.
Regards,
Alex
Aug 14, 2014 | Apple MacBook Pro Laptop Computer with...
I've tried everything the Internet has told me. It makes noises like its trying to eject but just won't come out. Is there a way I can open up MacBook on my own to retrieve disc or does this need to b
It is possible to do this yourself. But of you are not very tech savvy and are not confident with yourself, I'd recommend a certified technician.
Aug 13, 2013 | Computers & Internet
Stuck Cd
A few ways of doing this
restart mac and press down the trackpad after you hear the startup noise
if that does not work try opening up disk utility and click on the icon of your disk under the left hand column then go up to eject button and click eject
or open up terminal found in the utilities folder within your applications folder and then type in
drutil tray eject and then press return
Finally what to do is try pick up your macbook tilt the macbook to the one side and press the eject key and hopefully the effect of gravity will allow the CD to fall out.
One other way to do it which I have used recently but IT CAN BREAK THE CD DRIVE (Use it at your own risk), so only use it as a last resort. Get a thin piece of plastic (or credit card) and put a piece of double sided tape on it then with the macbook switched off insert the piece of plastic with the tape facing down in relation to the keyboard. Put it in about half an inch and you may be able to drag one of the CDs out. Hope it helps.
Apr 19, 2012 | Apple MacBook Mac Notebook
With a stuck cd on a mac, what is the 2 credit card thing?
One other way to do it which I have used recently but IT CAN BREAK THE CD DRIVE (Use it at your own risk), so only use it as a last resort. Get a thin piece of plastic (or credit card) and put a piece of double sided tape on it then with the macbook switched off insert the piece of plastic with the tape facing down in relation to the keyboard. Put it in about half an inch and you may be able to drag the CD out.
Mar 23, 2012 | Computers & Internet
Cant eject disk
hey man while your mac is booting up keep the mouse button pressed. it should force eject the disc. try it 2-3 times. it will work.
May 23, 2010 | Apple MacBook Mac Notebook
Hi what does Error 03 mean?
My endeavor has done this error 3 a couple of times and the cd changer basically shuts off all lights and won't do anything. Someone on another solution page said to slide a credit card back and forth in the cd opening to fix the problem. I've done this both times and it has made the changer play again as if nothing had happened : )
Nov 14, 2009 | 2004 Mitsubishi Endeavor
CD not coming out of my MacBook
Things I might try that you may or may not have tried already:
  1. Reboot and try to eject again.
  2. Reboot and hold down your mouse button during start up.
  3. Reboot and hold down your the eject button during start up.
If those don't work, check to see if your disk drive is warped in anyway. My old MacBook would only eject if I pried the slot open a little.
I hope you can get your disc out.
Jun 04, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
6 disc changer will not eject cds==
I had the same problem for months. I checked the owners manual, checked the fuse box, everything I could think of. Then, today, I did some online research and someone said one of the CD's is probably just jammed or slipped out a bit. The suggestion was to gently slide a credit card over the disk (through the door/slot, which in my case was partially open). I just tried it. The door closed and the message said "initializing". It worked! The CD player is back to normal.
May 24, 2009 | 2005 Mercury Mountaineer
APPLE MACBOOK WOULD BOOT. THE BOOT CD IS
unfortunately on the newer mac computer including the macbook you cannot boot to open firmware but there are other options
option 1)simply try holding down the mouse button or track pad button during boot after the first chime is sounded this will instruct the computer to eject the cd through the firmware
option 2) you can bypass the cd boot by holding down the option key after the first boot chime another simple solution this will allow you to choose a startup disk during...startup after which you can try the eject button on the keyboard or select the disk in finder and eject via trash can or eject symbol(symbol located in the open folder view of finder)
option 3) there is also a manual eject button though it may be harder to locate as they have change placements of it over the years however it can usually be found by probing the top center or far right of the cd slot with a paper clip just be gentle you don't want to damage an expensive piece of equipment by just carelessly jamming metal in it
you may want to try searching apple with your particular model and search for manual cd eject
best wishes, Crash
Apr 24, 2009 | Apple MacBook Mac Notebook
Apple MacBook Mac Notebook Logo
293 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
