Question about Do It Best Imports KB-310T-15 Outdoor Power Stake With Timer
Lost the directions to an outdoor 6 outlet power stake w/timer and can't figure out how to set the timer. Directions would be greatly appreciated!
How do I reset Jasco Ge 24HR Timer 6 Outlet Grounded Yard Stake? It was working fine then shorted out and now won't receive power
Open link below to confirm this is your yard stake.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59730
1) I tested this timer, and there is no reset.
2) Check that circuit has power. Plug timer into another outlet and see if there is problem with outlet.
3) Buy another GE yard stake at Home Depot and then return defective one.
4) This timer is for 'temporary' outdoor use like seasonal lights.
If timer was buried in snow or got real wet, it might not perform
5) Maximum load for all outlets is 1200 watts.
This timer is not heavy enough for motor loads because motor draw a lot of amps when starting.
For pumps up to 1/4HP use GE15117, or Intermatic HB88RC
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
For pumps over 1/4HP, use box timer like GE15207, or Intermatic T101.
http://waterheatertimer.org/GE-timers-and-manuals.html#15207
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Dec 27, 2010 | Jasco Ge 24HR Timer 6 Outlet Grounded Yard...
I have a noma outdoor mechanical 3-outlet lighting timer power stake with built-in photocell technology- 5 off settings but I lost the directions on how to set it. on the back it's marked SP-030 ...
the 2/4/6/8/ hrs settings work like the photo cell and start at dusk then remain on for the time set , ie 2/4/6/8 hrs then shut off
Dec 18, 2010 | Solar Home
Need instructions for Holiday Living Yard Stake digital timer #10243
The following link shows several yard stakes on the market today plus operating manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html#yard-stake
I cannot find photo of the holiday living yard stake 6 outlet programmable timer.
But I think Holiday Living is same as Westinghouse 28018
See 28018 at Amazon
http://www.amazon.com/Westinghouse-28010-Weather-6-Outlet-Photocell/dp/B004A16LTO/ref=sr_1_39?ie=UTF8&qid=1292415078&sr=8-39
If this is not your timer, or timer does not show on first link, add a comment and provide feedback.
Let us know where you purchased the product and give more detailes about the product so we can provide correct answer.
Your information will help fixya community better serve folks who want free answers.
Dec 15, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
I've lost the instructions for my Holiday Living #10243 6-outlet outdoor yard sake with digital easy set timer. How do I program the yard stake? thanks!
I think the Holiday Living yard stake is made by Woods.
GE sells identical 6-outlet yard stake for which I have a manual with clear instructions and images:
http://waterheatertimer.org/pdf/GE-15107-outdoor-timer-manual.pdf
Add a comment to help me identify your timer so others will be helped also.
If manual shown above is incorrect, open link below to view general list of yard stakes with manuals:
Dec 11, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
How do I set the woods outdoor timer model #59730
Woods 59730 is24-hour 6-outlet yard stake with dial located on top
This timer is identical to GE15107 yard stake
Manual.
If this is not your timer, look at following page to identify your timer
Add a comment any time
Timer instructions.
Set current time by rotating dial until time lines up with arrowhead located on inner dial
There are segments located around dial.
Look at inner dial > segments are located just outside the inner dial.
Timer comes with segments pushed inward.
To set timer to turn ON, pull segments outward for hours you want timer ON.
All 6 outlets are controlled by timer.
Last step:
There is override switch located on inner dial.
Move switch to TIMER for timer to operate.
Dec 09, 2010 | Woods Outdoor Lighting Timer
I have a holiday living 6 outlet yard timer and i lost my directions....Model # lx28006
Woods brands sells timers that are packaged and sold under various names and numbers.
For example GE sells same yard stake under their brand.
Woods 6-outlet yard stake manual:
Add a comment and say if this is your timer manual.
Dec 05, 2010 | Hardware & Accessories
I HAVE MODEL #83643B POWER STAKE AND 15 FT DIGITAL TIMER AND HAVE LOST THE INSTRUCTIONS ON HOW TO SET THE TIMER CAN YOU PLEASE TELL ME HOW TO SET THE TIMER
That sounds like the Woods 17321 Dusk-to-Dawn yard stake
Product image:
http://www.amazon.com/Woods-17321-Outdoor-3-Outlets-6-Foot/dp/B000BHN4H8
Manual
http://waterheatertimer.org/pdf/Woods-17321.pdf
If this is not your timer, check following page:
Instructions:
Yard stake control outlets, and turns ON automatically at Dusk
Rotate dial to set options:
Rotate to OFF > outlets OFF
Rotate to ON > outlets ON
Rotate to Dusk-dawn > outlets on at dusk and off at dawn
Rotate to 2 4 6 8 > outlets on at dusk and off 2 4 6 8 hours later
Dec 05, 2010 | Woods Outdoor Lighting Timer
My yard stake is a tower with 6 outlets and a single button to set, the brand is Holiday Living. I can't get it to come on at dusk and run for 4 hours without the lights blinking. I want a constant...
Put black tape over photo electric eye and see if lights stay on without blinking.
Dusk-type yard stake has photo electric eye, which is visible as round glass ball.
Lights from circuit can cause photo-eye to think it is daylight, so circuit turns OFF.
Moment later, photo-eye thinks it's dark and lights click back ON
Usually 6-outlet yard stakes have 4 top outlets controlled by timer.
Normally bottom 2 outlets are ON full time.
Make sure bottom outlets are not blinking also, which implies problem with outdoor circuit or basic timer problem.
Check circuit with inexpensive circuit analyzer from Home Depot electric department.
Photoelectric eyes go bad easily, but usually they don't blink.
They stick ON or OFF.
Nov 29, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
Do It Best Imports KB-310T-15 Outdoor Power Stake With Timer Logo
123 people viewed this question
Top Do It Best Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Do It Best Hardware and Accessory Expert? Answer questions, earn points and help others
