Question about Garmin Forerunner 305 GPS Receiver
I have just loaded Win 7. I have re install Garmin Training Center. It says, since this is the first time you are using the program, your device needs to be added to training center. It repeats itself everytime I try retrieve history... I can't go further than that
I had the same problem, my husband finally uninstalled the software which I had installed using the original disk, then he reinstalled it using software downloaded from Garmin. Works great now. Hope this helps you.
Posted on Jan 02, 2010
Garmin 705 - device not found by Training Center
Garmin has moved everything to Garmin Connect. Depending on your device, Training Center may or may not be supported anymore. You can go to the link to read more on Garmin Connect. Also, Garmin now uses Garmin Express to sync and update devices. I'll attach the link. https://www.garmin.com/en-US/software/express
Aug 16, 2017 | Garmin EDGE 705
My new computer running Win 7 will not recognize my Forerunner 305; I have installed and reinstalled training Center, drivers etc. and it still wont work. The USB connection is good because I can hear it...
Did you install from the CD or did you install the latest drivers (dated Dec 2009)? http://www8.garmin.com/support/download_details.jsp?id=591 has the latest USB driver. Other software updates are at http://www8.garmin.com/support/collection.jsp?product=010-00467-00
The newer drivers are Win7 compatible. Next, do you plug it into the computer or a hub? Try a direct connection. Also look at the contacts on the device and the cable. If there are any dark spots try cleaning the oxidation with a pencil eraser or another non-abrasive material (toothpaste for example).
What version firmware does the software report? If you see 0.0, try reinstalling the firmware https://buy.garmin.com/shop/store/downloadsAgree.jsp?id=3289&product=010-00467-00&cID=142&pID=349 . Download the software, then run it (click run a second time if the UAC comes up). Then connect the Forerunner to the computer. You'll need to allow extra time for a satellite fix the next time you use the device.
I hope this helps.
Apr 26, 2010 | Garmin Forerunner 305 GPS Receiver
How do you transfer 305 history to a new computer?
If you go into the Garmin Training center software under "File" you should see "Export". On some versions there is a Back up as well.
If you go into the Export and Export everything, Work outs, History, and Courses (all seperatly) you should be able to save these files to a USB stick. Using the USB stick you should then be able to "Import" these files to the new PC. Obviously you will need to install the Training Center onto your new PC first.
Feb 06, 2010 | Garmin Forerunner 305 GPS Receiver
Appears to recognise connection but when receiving
Back up your Garmin Training center (File , Export, History...Workouts... Courses.
Then try reinstalling software. My wifes PC has done this a few times. I think it is becasue she is not using the "safly remove hardware" icon in the task bar when disconecting.
Reinstalling the sofware has worked for us.
Jan 26, 2010 | Garmin Forerunner 305 GPS Receiver
Missing training data from my Garmin 305....
Unless you created a "back up file" with the Training Center software unfortunatly you will not be able to retrieve the data.
Regular back ups will insure you do not lose information in the future.
To back up your data in the Training Center go to "File" and "Back up" I believe the early version of the Training Center did not have the Back up feature so you would then need to use the "File" Export" option.
Dec 11, 2009 | Garmin Forerunner 305 GPS Receiver
Connecting to computer -- does not seem to see my device
Yes, contact Garmin, MS Service pack most likely the problem. Quote SP installed to Garmin Support
Jul 25, 2009 | Garmin Forerunner 201 GPS Receiver
Garmin Forerunner 305. Problem receiving activities and courses
This turned out to be corrupt data on my machine. I opened the Garmin traing center, backed up all the courses then deleted them inside the Training centre. I then received from device and all was okay.
Jan 12, 2009 | Garmin Forerunner 305 GPS Receiver
Garmin 305 not communicating with Training Center
I am new to the Garmin Edge 305, and started getting this problem yesterday. Indeed, yesterday it was the first time that I downloaded Courses.
I followed the Guest solution, deleted all new courses from my Garmin, and it now WORKs!!!!
Uploading my courses back again to the Garmin made the problem return back. I need some more work to identify the bad course.
May 05, 2008 | Garmin Forerunner 305 GPS Receiver
Information to computer
I did have exactly the same problem.
I think what caused the unit to stop communicating with the computer was that somehow I switched to "multisport" mode.
I was cycling and somehow I switch to running.
The solution that worked for me was to download and install the "Webupdater" software from the Garmin site. This will update the firmware on your forerunner 305 (you need to be connected to the internet of course). After 5 to 7 minutes it will be done.
Then, download the latest Garmin "Training Center". This worked for me, I'm relieved now.
Apr 19, 2008 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 305 GPS Receiver Logo
212 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
