Question about Procom Heating & Cooling
Pro com heater won't stay lit
Can lite pilot by hand when it warms up and gets to end of cycle the pilot goes out
5 Suggested Answers
SOURCE: Laars Lite heater not working
1st time this happened to me the filter wasn't clean. 2nd time it was the pressure switch and for the third time they say I have to bleed the gas line, not enough gas to lite. And I also need the on/off switch gone bad.
Posted on Jun 15, 2008
danforddan1
  • 192 Answers
SOURCE: my heater wont stay lit
Chanches are the thermal couple a safty divice is gone bad. they don;t cost a big bunch and the parts store at a local propain dealer may show you how to install it. its no biggie. Good luck. DFD
Posted on Apr 13, 2009
  • 33 Answers
SOURCE: pilot stays lit, but burners underneathe do not light up or burn.
Check pump is working, if so could be stuck flow switch or gas valve fault get unit serviced
Posted on Jan 17, 2010
SOURCE: warm morning propane heater. new thermal couple.
There are basically three things that can go wrong with the Warm Morning .
Sensor shut off. There is a sensor button on the back of the unit with a wire going from it to the thermocouple. This sensor turns the heater off if the flue is blocked, however it will also shut the heater off if the wire contacts are dirty, or if the sensor has gone bad.
You can test this by bypassing the sensor. Disconnect the two wires from the sensor and reconnect them directly together. If the pilot stays on, your problem is here. Try cleaning the wire contacts first.
Pilot orifice. If the pilot flame is small and doesnt look healthy, the pilot orifice may need cleaning. The hole is very small and can get dirty. Disconnect the silver tube and clean with electrical parts cleaner. Never try to clean the hole with an object like a pin, you may damage it. You may have to slide out the burner unit to get at the silver tube. (Always shut off gas before disconnecting lines and after you reassemble, spray joints with soapywater and look for small bubbles which may indicate a gas leak. Dont use parts cleaner around an open flame.)
Thermocouple can go bad but this is not as common as the first two problems.
Posted on Jan 28, 2010
When my glo warm heater reaches desired temp it not only shuts off but pilot light goes out too.
Maybe it's a direct spark ignitor so when call for heating pilot would open and spark ignitor would lite it
Jan 05, 2018 | Heating & Cooling
Raypak problem, Pilot is lit, can jump TH to TH to lite, goes out when jumper is removed.
check how many millivolts the pilot is generating. if pilot stay lit and burners wont fire u have a problem with one of the safties, lose wire connection, tstat control
May 28, 2013 | Raypak Pool & Spa
Pilot lite won't stay lit
Thermostat flame sensor. Do you see a little rod next to the pilot? That is what tells the main gas valve that the pilot is lit and it is safe to give gas. Easy swap, and you can usually just pick up a generic one.
Apr 14, 2013 | Heating & Cooling
It runs out of fuel
sound like pilot lite is not getting thermocouple hot.
check that pilot lite flame is extending out to and touching thermocouple. If not, clean out pilot lite orface and pilot lite gas feed pipe all the way back to the main gas valve if necessary.
If pilot lite flame is touching thermocouple, then replace thermocouple
Jan 22, 2013 | Mr. Heater Big Buddy Heater
I have a desa gas log heater when the heater lites and goes out the pilot lite goes out also
I would start with cleaning the Pilot ODS Assembly and also reseating the thermocouple.
Here is a link to cleaning instructions.
http://www.allpartsinc.com/mmAllParts/Others/Reseating%20Instructions.pdf
Oct 08, 2012 | Desa International Unvented Gas Space...
Reliance 606 Hot water Heating element (Pilot light) won't stay lit
Gas water heaters don't have elements, so I am confused about what type water heater you have..
Look on the side of tank for the label.
Find the brand, and type. Does it show BTUs? Or does it show wattage?
Then re-post question with this information, for best possible answer.
Also post question on Tank forum.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 12, 2012 | Water Heaters
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Rheem NatGas hot water heater model 41V50, basement flooded pilot went our how do I relight?
At the controls there should be a knob that says " Pilot"... "ON" Turn the knob to pilot and hold it down while lighting the pilot lite. Keep holding it down until it gets warm enough that when you leave it up the pilot stays on. Once the pilot lite stays on on it's own turn it to on.
Mar 14, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
Heating & Cooling Logo
792 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
