SOURCE: Remotes don't work
I recently had Verizon FIOS equipment installed in my garage (for phone, internet and TV), which is plugged into a 110 volt electrical outlet. Thinking this equipment might be causing some RF interference, I unplugged the FIOS equipment, and both garage door openers immediately worked perfectly again!
After reconnecting the FIOS equipment, I then plugged the garage door opener into a different electrical outlet approximately 15 ft. away via an extension cord, and the openers continue to work fine. Fingers crossed, I hope the issue is permanently resolved.
SOURCE: remotes quit working for garage door
I had the same problem with my Craftsman opener but different model. However to fix this I simply followed the instructions that came with the opener and reprogramed the remote to the opener. The instructions are in your owners manual and are pretty straight forward.. John
SOURCE: Remote will not operate garage door opener from outside garage
Will the remotes work in the garage? If yes but not outside with the door closed you might have radio interferace with your remotes. You might have to chage to a your reciever and remotes to a different brand (frequency). Sometimes it is less trouble to change out the operator. Chamerlain changed frequency from 390 (old) to 315 (new).
SOURCE: Remote Garage Door Openers won't work
Does your wall console have a LOCK or VACATION setting. Turn off.
