Question about Compaq Presario Notebook
Computer just went dead was working fine than just went blank.
My wife was using my laptop she passed it over to me and the computer just stopped working seems like to power cant turn the unit on.
  • 2,404 Answers
Take out the battery and only hook up the ac adapter and turn on the laptop and see if you get power.
If that doesn't work then check your ac adapter to make sure the green light is on when its plugged into the wall outlet. If it is then you know the ac adapter is working properly.
Take the hard drive out and the dvd drive out of the laptop and then see if you can power on the laptop. If it still doesn't power on then that means the hard drive and dvd drive is good and also means the motherboard is bad and would need to be replaced.
Posted on Dec 10, 2009
SOURCE:
My acer aspire 7736G was working fine, it's about 2.5 years old, and is used mainly with the power cord plugged in. When using it the other day the computer just went dead on me. I took the batter
You have reached the end life of the battery pack. The battery must have some minimum charge to have computer function even with the AC power pack connected. So I suggest you replace the battery pack as a solution. Any local Radio Shack store can test this battery I am told free of charge.
Jun 20, 2012 | Computers & Internet
Nikon d40x suddenly stopped working- won't turn on- was working fine and when I connected it to laptop to download, it turned on , then suddenly went blank.
Do you get the 'push shutter button again' or 'turn off and on again ' message? If so the motor in the SQ unit that charges the shutter and moves the mirror up and down has failed. A very very common problem. The part is on constant back order at Nikon, and good luck getting it anyway as Nikon is going to stop selling parts to anyone in just a few weeks.
May 06, 2012 | Nikon D40x Digital Camera
Black screen on Acer aspire 1642
Try below steps.
1. Check computer in safe mode (Tap F8 while booting)
if works fine in safe mode , check startup programs and services.
2. Run antimalwarebyte in safe mode download from http://www.filehippo.com/download_malwarebytes_anti_malware/download/6a5b2c1adb0e88e84ab39920bab1ebbd/.
3. Try to repair using repair your computer option (windows 7,8)
Dec 02, 2011 | Acer Aspire 1642WLMi Notebook
Describe your vs19 (Silver) 19"
You did all the correct diagnostics and proved that the monitor is faulty. Take to a local service centre for repair.
Feb 22, 2018 | HP vs19 (Silver) 19" LCD Monitor
I have an everex nc1500. it was on working fine, then it suddenly went dead like it was on battery,(but was on charger). now no lights come on ,it doesnt charge, doesnt try to turn on in any way. it acts...
This seems like a poor soldering job at the factory which has become loose/disconnected over time, affecting the power port the ac adapter plugs into. Take the laptop to the shop and have your power jack inspected.
Mar 10, 2011 | Everex StepNote NC1500 Notebook
Carrier a/c thermostat was working fine, then display went blank!
if it has no batt I would ck transformer for 24to26 volts no voltage replece transformer be sure trans has 115 volts to it trans should be in furnace section
Jun 09, 2010 | Carrier 38CKC030 Air Conditioner
ACER ASPIRE 9410-4933 LAPTOP SCREEN GOES BLANK DURING P.O.S.T.
Were you working with laptop in battery mode, not plugged in a/c power? You could have drained your internal DC battery & at the same time damaged your B.I.O.S. [button type] battery inside the laptop. that the computer goes into POST means that it is trying to FIND itself, not finding the graphics card, it does not know what type of 'picture' ( usually black screen with ""DOS"" words ) to show you.
1st- turn laptop on, you should see name,what type of cpu (the "inner " workings of computer) and sometimes the amount of memory (clicking like a digital timer) If not, don't worry. Press f1,or DELETE, ESCAPE (ESC), or read your book to find the KEY to puts you into SETUP. There should be a menu and somewhere there are DEFAULT. USE THOSE! Reboot to see results.
Apr 02, 2009 | Acer Aspire 9410 Notebook
Computer boots fine but the monitor is blank
if the monitor works fine on your laptop, the problem definitely is at the computer, possibly with the video card (if it is using one). it could have loose connection, or parts might have damages. it seems the problem is intermittent so electronic component of the video card could have parts partially damages or leaky components.
if your still using the motherboards built in video out put, try installing a new video card.
Oct 31, 2008 | Computers & Internet
Compaq Presario Notebook Logo
70 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
