Question about Toshiba 36A43 36" TV
Colors The colors are all out of whack - i have reset the colors - i have tried to change from warm to cool but no luck. Is there something i can replace myself?
    Problem Solver:
  • 4 Answers
Here is a couple of ideas, hope they help...Move any big speakers away from set, if there be any close by.
Also you will need to borrow a degaussing coil from someone, get them to explain to you and show you how to degauss a tv with the colors out of purity. Also, you may have a bad degaussing circuit in the tv...but definetly make sure no big magnetic speakers are in the same area or close to your tv. Hope this helps.
Another problem which would require someone knowledgeable of it, is a problem in the convergence circuit...depending on what brand of tv you have and how new it is...this problem causes an outline or color shadows around people and or objects.....the first problem above causes impurity or splotches of color in the video or picture.
Posted on Jan 31, 2008
AV-48WP74 48 in. Rear Projection HDTV-Ready Television: my 3 colors are all out of whack and the convergen...
you most likely need to replace the convergence ICs. If you are lucky, they may have unsoldered pin connections at the PCB, you can try re-soldering those loose pins. What usually happens is that because of the heat generated, the pins have become detached at the IC also, thus the need to replace the ICs. Some of these have either fuses or resistors to the ICs that have also opened & will need replaced also.
May 16, 2010 | JVC AV-48WP74 48" Rear Projection...
Tip
Tips on choosing the sunglasses color.You can't go wrong with basic black....
Tips on choosing the sunglasses color.You can't go wrong with basic black. Everyone should have at least one pair of gigantic black sunglasses for everyday wear - they're so Breakfast at Tiffany's. For extra movie-star appeal, make sure the lenses are as dark as possible.<br /> Pay attention to the colors you wear most often. You want your sunglasses to work with the majority of your clothes. Do you wear cool colors most often? If so, try to stay with cool colored sunglasses in shades like black, gray, blue, and silver. If you tend to wear warmer colors, look for brown, red, gold, or similar warm-toned sunglasses.<br /> Try to buy shades in one of the colors that flatters you most. Shades that flatter your skin and hair coloring will bring out your features and make you glow. Not sure which colors look best on you? See my article How to Find Your Perfect Colors.<br /> Have fun and experiment with cheap, colorful frames. Neon sunglasses are a huge trend for summer 2009, so I recommend having some fun and trying the trend out with some inexpensive frames. Sometimes it's fun to wear ridiculously bright, cheap sunglasses. Keep the rest of your outfit simple & classy but go wild with your shades for a look that's very modern and right-now.
on Nov 07, 2010 | Clothing Accessories
My E771 monitor colors suddenly shifted with
Possibilities:
1. video-card gone bad;
2. video-cable gone bad;
3. video-cable not tightly-connected to CRT;
4. video-cable not tightly-connected to video-card;
5. "red" gun inside CRT gone bad.
Disconnect the video-cable from the computer, and try again to adjust the "red". If red-free, then it's time to responsibly recycle the CRT.
Reconnect & wiggle the video-cable, to see if that induces any "red" onto the CRT.
Connect the CRT to the VGA-output port on a notebook computer, to see if that video-card generates "red" as one of the primary colours.
Give the CRT a strong "whack" on the side, to see if "red" makes an appearance.
May 07, 2010 | ViewSonic E771 17" CRT Monitor
My Sanyo HDTV's colors are whacked. Wat's up?
I kept digging for answers and while I was waiting I decided to turn it off for a while and see if it had an automatic degaussing feature. It was off for about 1/2 an hour and when I turned it back on, it looked good as new ... problem solved.
bill
Oct 11, 2009 | Sanyo Televison & Video
Color problem
change your lcd monitor
Jun 26, 2009 | Acer X193W LCD Monitor
Color on Acer 191w
Any of the 3 internal wires that delivers the tree color (Reg-Grenn-Blue) is disconected or damaged.
Open your monitor and try to locate that wires...
Good Luck
Best Regards !
Jun 24, 2009 | Acer X193W LCD Monitor
Blue bulb is lit but no picture
the messed up colors are probably from a burned out convergence chip. not too pricey to fix.
Feb 17, 2009 | Philips 55PW9363 55" Rear Projection...
Philips 23PF9966/37 color problem!
Try to adjust it in the Service Alignment Mode (SAM).
Press 062596 followed by the STATUS button (upper left). Navigate to "White Tone", press the right key to enter and select "Normal" mode. Set the colors:
Red = 135, Green = 128, Blue = 133.
The "Cool" and "Warm" menus are deltas from the "Normal" settings:
COOL: R -3, G -1, B 5
WARM: R 2, G -3, B -13
Press the "MENU" button to return to the main menu, then the "Power" button to turn the TV off.
Jan 04, 2009 | Philips 26PF9966 26 in. LCD Television
Colors out of Whack on HD input 4 only
May need higher quality component HD cables? Tried switching Blue on Red? Just some thoughts.
May 02, 2007 | Philips 60PP9202 60" Rear Projection...
Toshiba 36A43 36" TV Logo
65 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
