posted by ronz2 on Jan 19, 2008
im haveing problems installing my monitor.it seems to not want to down load. its a proview cd download for my camera.
Solution #1
posted on Feb 20, 2008
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Good Luck!
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
HP 22" Widescreen Flat-Panel TFT-LCD HD Monitor
Sony CPD E200 Monitor
Philips 107E56 (Black) 17" CRT Monitor
Philips 107E61 (White) 17" CRT Monitor
Philips 107E66 (Black) 17" CRT Monitor
Philips 23PF9945-37 (Silver) 23 in. Flat Panel LCD Monitor
Philips 170C4FS (Silver) 17" LCD Monitor
Can you Help with these Monitors problems?
Polyview S17E 17" LCD Flat Panel Display With...
Grey then screen goes blank on...
As soon as I attach the powr is... Answer This...
Toshiba P000232050/F 13.3" LCD Monitor
interference lines and patterns...
I have noticed what seems like... Answer This...
Repair Service
Find Monitor Repairman Near You:
