I have a Toyo Aircon split unit Airconditioner/heat pump. 12000 Btu. When in the heating mode, I get the code E8 after it runs for 5 to 15 minutes. At that point it seems to run (at least the internal fan), but the heating aspect seems to be marginal (about the or just above room temp), keeping the room several degrees cooler than what is set. I have been unable to find any source for support of these units. The warranty phone number says it is not connected. Thanks Ed
You might want to refer to the unit manual, which has a fault code section (if the unit has a manual), look up the fault code E8, in the manual and it will tell you what fault it is. Depending on where the unit was manufactured, you may not be able to contact anyone regarding the warranty or diagnoses of the fault, so instead contact your local A.C company for help. Sorry I could not be of more help.
Posted on Dec 11, 2009
I have a aircon that showing me the error code e3 on the display board. can you help me with this problem
Hi I googled (error code e3 for Sanyo 12000 Btu Mini Split Air Conditioner) and found this link below of a short youtube video of the answer you're looking for, Also on the right there are other video's you might be interested in...I hope this helps you..CHEERS..
https://www.youtube.com/watch?v=nISwqnhul90
Mar 22, 2016 | Sanyo 12000 Btu Mini Split Air Conditioner...
What does error P1 means in pioneer heat pump
It means the power is off or went off to unit . Check for power then power cycle unit to try and restart .
Nov 14, 2014 | Pioneer Ductless Mini Split INVERTER Air...
Display is out
Push the swing button 2 times quickly. This will turn the display back on.
Jan 15, 2014 | Soleus Air KFHHP-12 12000 BTU Mini Split...
Help me please have a R410a 12000 btu mini split airconditioner heat pump that lost gas how do l regas it have closed all the leaks and have the R410a refregerant with the adapter.i have not charged a...
Mini splits need to have the refrigerant weighed in. First, ( if the system is already empty ) pull a vacuum down to 500 microns. Second, add the amount of refrigerant listed on the mfg. tag. Hope this helps!
Jun 07, 2012 | Heating & Cooling
My LS-H186 VML 1Metal Art Cool 12000 BTU Air Con does not heat up
You should also check the outside unit to make sure the coil is not clogged with dirt or grass clippings and the fan is working. The reversing valve that switches it from cool to heat could also be a problem. If it isn't shifting it will not switch between heat and cool.
Apr 29, 2010 | LG Art Cool LA181CNW Split System Air...
I just installed a ductless mini split 12000. when I put power to it the outside unit compresser runs no fan the led read out just blinks very fast the remote does't do any thing
One thing you need to check is Polarity. the 2 wires red and white, need to be on the same terminals inside as they do outside. this is very important.
Oct 28, 2009 | LG LS-L1210HL 12000 BTU Heat and Cool Mini...
TOYO TA-09CHS aircon problem
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
Jun 09, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Airconditioner LG LSk181-N2 shutting off
Sounds like your aircon is stuck on heating mode. Or. The outdoor fan speed is affected by ambient temperature, or low refrigerant. In heating mode the indoor fan will come on for a while to sense temperature and will then wait for the outdoor unit to pump up pressure and build up heat.
Feb 01, 2009 | LG LS-K1830CL Cool Mini Split Air...
Heating & Cooling Logo
202 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
