Question about Samsung HLP4663W 46" Rear Projection HDTV
The red light saying stand by temp whats that mean
    President:
  • 632 Answers
The unit is in stand by mode due to overheating. The ventilation grill on the rear of the TV is most probably clogged with lints and dusts, not allowing proper air circulation inside the TV. Unclog it and make sure that the TV is placed at least four inches away from the walls to allow enough air circulation.
If problem still exist, please provide complete details such as observations and remedies done so far.
Posted on Dec 10, 2009
  • Samsung Master
  • 5,138 Answers
Is your TV working at all?
SOURCE:
What if the tv is off and the red stand by light is not on what does that mean
The red "stand by" light shows power is getting to the TV. If it is off, you may have no house power being connected. If you can get the red light to come on but your TV still does not turn on the power supply may have failed
Apr 04, 2013 | Sylvania Televison & Video
Just brought a second hand freezer for garage. It worked at the house but when I brought it back home and plugged it in it didn't get cold I had a green light on and a red hazard light on. Should I have...
The green light means it has power . The red light means the temp is not satisfactory . If the freezer was laid on its side anytime and did not sit for 24 hrs before plugging it in , then it's no good anymore due to compressor pumping solid oil into the lines instead of refrigerant . The oil causes restrictions not allowing the refrigerant to flow .
Sep 26, 2010 | Refrigerators
The last led light blinks green and sometimes it turns solid red
red light is stands for hardware boot and the green one is stands for system boot and disc boot. when red light remains solid it means your system is in 0% cpu usage and nothing doing, stop working
May 09, 2010 | Intel SC5299BRP
I have a 61 inch Samsung DLP it says stand by temperature what does this mean?
If stand by/temp light blinks it could be: a fan not turnig, back vents blocked (overheating) or DMD/light engine failure.
Apr 11, 2010 | Samsung HLT6187SAX 61" DLP HDTV
Sony tv is blinking orange light saying standby. what does this mean?
Picture won't come on. It clicks a couple of times then red stand by
light starts blinking
Sep 14, 2009 | Sony KP-46S25 TV
The red lights are blinking under lamp and temp.
did you try setting the lamp over the red light on the tv?
Jul 14, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Why is the ''snowflake light'' showing up red in my car?
I have a '99 Mercury Cougar & I've been read somewhere that the snowflakes have to do with the outside temp. & traction. I think it's warning you that it may be slippery or icy. I've noticed that when it's +3 to about -2 or -3, the yellow snowflake shows up. Any anything colder than -3 shows the red snowflake. The other lights: the wrench comes up in yellow. That one has always turned on after a certain amount of km's & it's advising you that your car needs a check-up (that's when I know I should look into getting an oil change). You can turn this light off by holding down the two buttons above & below the 'clock' button. Hold them down together for at least 5 seconds & that wrench light should go off. Otherwise, there is a light for checking your breaks (upside down exclamation mark), low windshield fluid. I can't think of any other ones but I hope this helps.
Nov 18, 2008 | 1999 Mercury Cougar
Red stand by light blinking
5 blinks = lamp driver (ballast) failure.
1-468-798-14 for the 610 model
replacement is done from the back of the set, should be straight forward, keep the red ballast wires apart for best results
if a tech replaced the red tube, you have an older tv where 5 blinks is the AKB error meaning your CRTs are getting old.
Nov 17, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
High temp warning
2 BLINKS: Temperature
Apr 05, 2008 | Sony KDS-R50XBR1 50" HDTV
Samsung HLP4663W 46" Rear Projection HDTV Logo
128 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
