Question about HP PSC 2410 All-In-One InkJet Printer
How do I set the time on my printer - HP PSC 2410 All-In-One InkJet Printer
    Sergeant:
    Champion:
  • 240 Answers
You may refer to this HP support document: (copy and paste the following link into the location bar of your browser)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu01833&cc=us&lc=en&dlc=en&product=303753
Choose the link for your product.
Posted on Dec 10, 2009
SOURCE:
My Lexmark x3550 only prints one page of multiple pages. I've checked my print setting and it all looks correct. I'm also having problems scanning and copying. It's a fairly new machine as I hardly use...
Try to reset your printer factory default settings. Press Settings button -> Defaults -> Set Defaults -> Use Factory -> press Check. You will be asked to setup your printer settings like you're setting it up the first time - set the time and date, etc. When done, unplug and replug the printer into the power outlet to refresh the printer.
Apr 13, 2011 | Lexmark X3550 All-In-One Printer
What setting is it, to keep the printer from calibrating every time I switch out the paper, even though they're all the same length & width. It wastes 2 labels, before it prints what I need.
There's a couple of settings in the menu that let you choose different options every time you open and close the printhead and also for every time you power it on.
"MEDIA POWER UP" - Set this to "CALIBRATE". -This will calibrate every time you power on the printer. I recommend this setting.
"HEAD CLOSE" - change to "FEED". - this will insure the printer starts printing properly witout having to recalibrate.
Jan 11, 2011 | Epson Printer
Time set
its not a problem sir its may be setting mistake or camera printing is not printing time check settings
Jun 26, 2010 | Kodak ESP 5 Printer
How do you set date and time on HP7210 printer?
Press: Setup, press: 4, press: ok, enter Date, then Time
Time is found in Basic Fax Settings option 4 and option 1 on the HP OfficeJet 7210 All-in-one series printer fax scanner
May 14, 2010 | HP OfficeJet 7310 All-In-One InkJet...
How do i reset my z4m printer?
  1. Press Setup /Exit button 2 times. A message to save changes will be displayed.
  1. Press the “+” sign 3 times. A message to load the default settings will be displayed.
  1. Press the select button 1 time. The printer will be reset.
  1. Print a configuration label:
    1. Turn off the printer.
    2. Press and hold the CANCEL key while turning the printer on.
    3. Release the CANCEL key after the data light turns off. Verify that it is printing correctly.
  1. Software needs to match the printer driver settings. The software will override printer driver settings in properties of the printer.
Nov 11, 2009 | Zebra Z4M Printer
Every time I print a document the printer spits out a print record of settings and time and pages printed etc . can't find a way to turn this off !
That is a setting which you can control by looking into properties and the other settings, at print time. Also, when the printer is idle, you can re-set these things to not provide a status report at the end of a print session.
RTFM is the word of the day - Read The Freaking Manual, and learn how to set the printer to do what you want it to do. Otherwise, it will do whatever it wants to get done as the output statistics.
Sep 23, 2009 | Canon PIXMA MP970 InkJet Printer
HOW TO SET TIME IN PRINTER
Set the date and time
You can set the date and time from the front panel. When a fax is
transmitted, the current date and time are printed along with the fax header.
The date and time format is based upon the language and country setting.
Normally the computer software sets the date and time automatically.
1. Press Setup.
2. Press 3, then press 1. This selects Basic Fax Setup, then selects Date and Time.
3. Enter the month, day, and year (last two digits only) by pressing the appropriate number on the keypad. The underline cursor presented initially beneath the first digit advances automatically to each digit after, each time you press a button. The time prompt automatically appears after you enter the last digit of the date.
4. Enter the hours and minutes. The AM/PM prompt automatically appears after the last digit of the time is entered.
5. Press 1 for AM or 2 for PM.
The new time and date settings appear on the front panel.
Apr 26, 2009 | HP PSC 2210 All-In-One InkJet Printer
Setting the time
On my 6310 all in one printer ------> Hit "Setup" key (with the question mark next to it >> Select Tools (menu item 6) with OK button >> Date and Time (menu item 3) with OK button.
Then set the date and time using the keypad on the printer and the ok button. Either the arrow keys or the setup button move through the various menu options.
Nov 05, 2008 | HP Officejet 6310 All-In-One InkJet...
Set Time back
To restore your settings to 2 weeks prior:
Click start > programs > accessories > system tools > restore.
To set the time back to 2 weeks earlier:
Double click the time clock at the bottom right hand corner of your screen and change the date and time.
However, if you mean you lost the printer driver, neither one of those options will find the driver. If the driver is not on your system, even doing a restore will not bring back something that is missing.
You can download the drivers for your printer here.
Dec 22, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 2410 All-In-One InkJet Printer Logo
24 people viewed this question
Clive
Clive
Thomas F. Schneider
