We have a rexel shredder 250 but i wont work,
We have a rexel shredder 250 but it wont work, there is a picture on top of what looks like a basket and this is lite up orange but i cant seem to find anything wrong
    President:
  • 3,085 Answers
Either your shread bin is full or the sensor is dirty. Blow out with canned air.
Posted on Dec 10, 2009
Just purchased shredder and it seems to work in reverse but not on auto.There was a small basket looks like it hooks on to something I don't see where.This basket is not shown in the manual.
Question: have you inserted paper to shred while set on AUTOMATIC?
In most units, there is a sensing switch (electronic or mechanical) that allows it to run.
Jun 06, 2015 | Honeywell 9112 Twelve Sheet Cross-Cut...
Rexel 3250 S3 wont stay in continuous mode
Try a hard reset first..Unplug the machine from power source, wait about 10 minutes, and try again..
Jun 07, 2008 | ACCO Brands 3250 S26 Shredder
I have a Staples SPL77M shredder. It stopped automatically feeding paper when placed in the feed slot and now requires the forward button be pressed and held down to shred paper. If the on/off switch is...
IF YOU LOOK INTO THE SLOT WHERE YOU FEED THE PAPER...GET A FLASHLIGHT ........IN THE MIDDLE OF THE SLOT YOU WILL SEE A TINY SWITCH. THAT THING SOMETIMES GETS GUMMED UP WITH GLUE FROM ENVELOPES AND SUCH... TRY SOME WD-40 ON THAT SWITCH... WITH THE MACHINE UNPLUGGED PUT PAPER IN THE SLOT TO MOVE THE SWITCH SO THE WD-40 CAN LOOSEN UP ANYTHING .... THEN TRY BLOWING AIR IN IT....
ARE YOU SURE THAT THE TOP OF THE SHREDDER IS SITTING FLUSH WITH THE PORTION IT RESTS ON??? THAT COULD ALSO MAKE IT NOT WORK..... OR IF THE BASKET NEEDS EMPTYING THE TOP WONT REST FLUSH ON THE BASKET.
Dec 02, 2014 | Staples Office Equipment & Supplies
Need a bin switch fir rexel 2259
Apparently your product is not made in the US. Here is a link for their available parts as well as an e-mail address to send them questions directly.
http://accoblobstorageus.blob.core.windows.net/assets/pdfs/support/Rexel_GBC_spare_parts_list_2014.pdf
Jul 12, 2014 | ACCO Brands Rexel 2250 Shredder
Wont turn on
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Oct 01, 2013 | Cross Infoguard Shredder SX102M
Rexel RSS1627/RSX1227 Red light always on when
I have an Acco Rexel RSX 1227 shredder. Can you use any oil to oil the shredder or must it be a special oil
Aug 22, 2011 | Office Equipment & Supplies
Old Rexel 1250 - falsely detecting safety cover is open
You'll have to unplug the machine, then remove the screws front (inside door or cabinet) and rear to remove the top cover. Insure that the safety cover arm which contacts the microswitch is not broken or the microswitch is out of adjustment.
Oct 24, 2008 | Office Equipment & Supplies
Acco Rexel 4550 Parts Manual Needed
I can get you the manual but i have to find out how to do it through FixYa.
Oct 01, 2008 | ACCO Brands Rexel 4550 Shredder
Rexel rdx1750 shredder jam
This is the available numbers for ACCO Rexel 0845 658 6600 or 01296 732466/732468 in the UK or you may contact by email mailto:informationeurope@acco.com and this is the web address http://www.acco.co.uk/
Mar 01, 2008 | Office Equipment & Supplies
PS-70 Shredder problem
Make sure that the shredder is locked down in its case by pushing down on all 4 corners.
Since the basket slides forward to empty it, I would think the safety switch is located in the front but not positive since I don't have a unit right in front of me.
Check to see if you see a slot in the top part of the shredder unit. Usually the basket has a piece of plastic that will line up with the slot when the basket is in place (Safety switch) so that the top part of the shredder knows that the basket is in place.
Look around with a flashlight, If you are going to feel around with your hand, PLEASE MAKE SURE YOU UNPLUG the shredder just to be safe.
Hope this helps.
Good luck.
Mac =)
Feb 10, 2008 | Fellowes PS-70 Shredder
404 people viewed this question
k24674
Marvin
Marvin
