Question about Microsoft LifeCam VX-3000 Web Camera
When I use my webcam, I can see me but the person
When I use my webcam, I have to go into settings every time before I use it. Sometimes that doesn't work. I can see me and the person I am chatting with, but they can't see me. It used to work fine. It started doing this when I had to update MSN Messenger. Any suggestions on how to fix it?
  • Microsoft Master
  • 3,015 Answers
Uninstall current software
unplug webcam
download new software
http://www.microsoft.com/hardware/download/download.aspx?category=ICE&type=LifeCam&sku=68A-00001
configure to msn
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - if not - make sure the webcam is set as default - restart MSN
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Posted on Dec 15, 2009
SOURCE:
My webcam doesn't work to my skype, what's the problem?
To test if the A4Tech WEBcam is functioning, check the USB cable; make sure itis connected properly. Then check the Skype configuration. Sometimes the WEBcam settings drop offand the WEBcam need to be selected again. Open Skype - Tools - Options - VideoSettings and select the A4Tech WEBcam Also check the AudioSettings for the Microphone THEN click on Save.Avoidconnecting the WEBcam to an USB hub.
Sep 07, 2011 | A4tech PK-635 Webcam
When I click on my webcam I can see myself, but if there is someone who also has a webcam, can that person see me or do I need to download Skype or some other software? Also, if person can see me, my...
There are usually a few places to change your image size and quality. You can look under the start menu for the Acer utilities and then webcam settings. You can set the size and image quality there so it doesn't take up the screen. The other way is usually through the messenger software such as Skype or Yahoo messenger or MS messenger etc. There is a tuning and setup section in each you have to run that checks your image and sound and you can set it there. This can override your Acer settings while running so will only sned a smaller image and so on. You can set it to send webcam all the time automatically or only when you want to. The other person will have to use the same messenger to see and talk to you. They can also choose to accept images or not.
Sep 02, 2011 | Acer Aspire 5610-4648 Notebook
I am not a computer person.I was wondering if logitech webcam C250h will work with skype?
Yes, I have a Logitech WEBcam (not the same model) and I use Skype.
After you installed Skype then :-
To test if the Logitech QuickCam is functioning, check the USB cable; make sure it is connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture your image/video.
If this works then the fault is with the Skype configuration. Sometimes the WEBcam settings drop off and the WEBcam need to be selected again. Open Skype - Tools - Options - Video Settings and select the Logitech QuickCam
Also check the Audio Settings for the Microphone THEN click on Save.
Avoid connecting the WEBcam to an USB hub.
Mar 09, 2010 | Logitech Webcam
On skype i can see the other person but they cannot see me, on test image is ok ?.
If the Logitech works then the fault is with the Skype configuration. Sometimes the WEBcam settings drop off and the WEBcam need to be selected again. Open Skype - Tools - Options - Video Settings and select the Logitech QuickCam
Jan 05, 2010 | Logitech Webcam
Use on laptop creates noise & frozen picture 4 person talking to
Its not due to the laptop, the other person is viewing you on the internet (Yahoo/Msn etc) so the Video might get frozen sometimes or may be a lot many times depending on the bandwidth or the server load.
The voice is due to the microphone you are using, you can use microphone with noise reduction technology with some noise reduction utility.
Regards,
Shrey
Oct 10, 2009 | HP KQ246AA Deluxe Webcam
My webcam
Can be several reasons
1) Lack of resources - internet connection etc
2) Check settings
INTERNET CONNECTION
Webcam connected
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
TESTING
> Messenger > My webcam - the warning panel will launch, click 'OK' and your webcam will start.
DEFAULT
With webcam still running > Messenger > Preferences > Webcam > Camera Source - set your webcam as default using dropbox. > Camera Settings - adjust settings to suit. > Apply > OK
Take a note of any additional software, if you have multiple choice for Camera Source, you may wish to uninstall any redundant webcam software later to prevent conflicts
The person viewing the webcam should make the INTERNET CONNECTION as above ( less webcam connected )
Sometimes it takes a bit of juggling and I have been running on "connect via proxy" for 3 days to enable my webcam to show as 'available'
Aug 15, 2009 | Labtec 961307-0914 Webcam
The person i am calling on skype cant see or hear me
You can only use the webcam with one device at a time? If you are sure the webcam is working properly shut down the software specifically for your webcam.
Log into Skype as normal.
Do you see the video call options in Skype?
In Skype you can check what you see in the following path?
Tools/ Options/ Video Settings/ Camera
Is you webcam listed if not link it using the option here.
May 11, 2009 | Logitech Webcam
They can't hear me?
Check you microphone settings in you audio mixer and make sure it is enabled for the web camera and not your sound card.
Aug 08, 2008 | Logitech QuickCam Communicate STX Personal...
When in skype, we canot see the other person om our webcam
Do you have a router installed between your Skype installation and the other person. Does the other person have a router installed? Are you both using high speed connections i.e. a good broadband connection. Even cable will sometimes cause problems. If you and he has a router in your configurations, then verify that ports necessary for video transmission are open on both ends of the connections.
Feb 21, 2008 | Philips SPC 900NC Webcam
Video problem
when you set up your webcam, depending on the application, you need to turn on the video, usually from the application, but sometimes from the settings profile.
Patrick
Jan 19, 2008 | Microsoft LifeCam VX-1000 Webcam
Microsoft LifeCam VX-3000 Web Camera Logo
119 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
