Question about Whirlpool Calypso GVW9959K Top Load Washer
The top part with all the press botton functions is broken from the sides. Also bottom chassis near floor is rusting. Machine washes but stops at 6 seconds in the spin cycle. No error code except for an occassional Open lid. Andrew
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^@#$
Posted on Sep 21, 2010
Where is the balance sensor located on my Kenmore Elite Oasis washer
Hello.
Top loading washing machines can emit loud noises and vibrations if they are not properly balanced. Imbalanced machines are the result of large loads of clothing that rock the machine causing one or more of the feet to rise off of the floor. Front loading washing machines do not have this problem because there is no side-to-side motion. Kenmore top loading washing machines have self-leveling feet on the rear of the machine and adjustable feet on the front of the machine.
1 plug the washing machine's power cord from the electrical socket. Pull the washer away from the wall, or out of the laundry closet, so that it is easily accessible.
2 rasp the top back of the washer on both sides and tilt it forward until the back feet are off of the ground by 4 inches. Lower the washer gently back to the ground. This maneuver, adjusts the self-leveling rear washer feet so that they are fully extended. You may need the assistance of another person to do this.
3 lace a level on top of the washer near the front edge. Look for the air bubble in the level to determine which side of the washer is out of balance. The side that the bubble leans toward is the side the needs to be raised.
4 Move the level so that it is positioned along the side edge of the washer and check to see if it is level from front to back. If it is level, move it to the other side of the washer and see if it is level.
5 Lift up on the front of the washer and insert a wooden block or brick under the front bottom edge.
6 Crouch down on the floor near the front foot that needs to be raised. Use your fingers to twist the threaded foot clockwise to retract the foot and counterclockwise to extend the foot further. If necessary, adjust the other front foot as well using the same method.
7 Lift up on the top of the washer and slide the block out from under it. Place the level on top of the washer to check that it is level. If the washer is not level, replace the block and continue adjusting the feet until the air bubble is centered in the level.
8 Crouch down on the floor near the front of the washer and use a 14 mm wrench to twist the metal nut on each front foot counterclockwise. Twist each nut until each is tight against the washer and will no longer move.
9 Plug the washer's electrical cord back into the wall.
And the problem will be solve.
Thanks.
Nov 13, 2011 | Washing Machines
Where is the balance sensor located on a Kenmore Elite Oasis washer
Hello.
Below are instruction on how to solve the problem of the washer.
9 lug the washer's electrical cord back into the wall.
Thanks.
After washing it stops and does not spin or rinse
Sounds like your lid switch is broken. This is located under the top of the washer and is activated by a tab that hangs off the side of the lid.
Accessing this part requires you to flip up the control panel by removing two phillips head screws in either the front bottom corners (may be behind the end-cap covers), or rear bottom corners, pull panel forward and lift to disengage the tabs at the bottom. Flip the panel upwards and it will swing back out of the way.
Next you will see one wire connector going into the top of the machine, this is actually your lid switch connector, disconnect it. Now using a flat screwdriver pry the front of the two brass clips towards the rear of the washer (put tip of screwdriver into front most part of clip and press handle of screwdriver towards rear of machine). The clips should pop off the top pretty easily.
Now you can open the lid and place a hand on the front of the opening and pull the cabinet forward. The entire front and side wrapper will come off the base platform and you can set it on the floor to gain access to the lid switch that is screwed to the underside.
Good luck to you on this!
Jul 03, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I own a GE WBSR3140 Washer and I'm getting a banging sound whenever the machine is a wash or rinse cycle but not on spin. How do I get at the problem ? Remove panel from the front or the top?
First of all, you do remove the a panel from the front.
On the inside floor of the machine, there were two "L" brackets with a hole for bolts, There were also two brackets on the bottom of the tub with similar holes. One pair was on the left bottom side and the other was on the bottom right.
It appeared that a bolt or some type of "dampening" connector was meant to go through to these holes. But there were no broken parts lying inside.That was my first "guess" for their purpose.
The left side (as facing the machine) "L" floor brackets and a tub bracket had been " bent" in such a way that that when the tub shook enough, the two brackets prevented the tub from moving too far. But not the pair on the right hand side. Go figure.
How it ever got this way or whether this was a "jury-rigged" solution at the factory (because they ran out of parts) is beyond me. Maybe the two brackets were meant to act as some form of "stop". But why were bent in such a fashion? And why only the ones on the left bottom side of the machine? I swear somebody bent them on purpose but that's me.
In any case, the tub had moved far enough that the bent tub bracket had slipped around the bent floor bracket. When ever the machine was on "wash" or "rinse" this "configuration" would bang against each other loudly. But it would not happen during the "spin" cycle.
I simply bent the two left hand side brackets back into a someone normal configuration (as with the bottom right floor and tub brackets) and put every thing back together. The banging sound was gone. However, you could still hear the brackets hitting each other on heavy loads. But it was not the "BOOM" I was getting before.
Eventually, the four rubber top corner "shock" springs will need replacing but at least things are quiet for the moment. But why or how the left bottom tob and floor brackets got so bent out of shape is beyond me. "Human intervention" or normal "wear and tear"?
Mark
Dec 21, 2009 | General Electric WBSR3140GWW Top Load...
Goes of balance. even with small load. it walks across the floor. clothes seem to gather to one side.i have leveled this machine, but no luck
There are 8 springs in the bottom tube to hold on the chassis. If some of them broken, it may cause this problem.
Jul 02, 2009 | Maytag Performa PAV2200
Washer leaks under tub
Can you see exactly where the water is coming from? When the machine is spinning and you lift the lid does it stop in less than four seconds? Does the water come from the side of the tub near an area where a tube attaches? Is there water staining down the side of the tub and an area near the top shows leaking? Is there rust and oil stains at the base of the gear case? Please blog back, SearsTechToo.
Oct 06, 2008 | Washing Machines
Don't start
It doesn't work at all If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Aug 10, 2008 | Kenmore Oasis HE 27082 Top Load Washer
GE Top-loader Leaks Water from Vertical Tube Behind Tub on X-Large Loads
it sounds like the basket is not locked when it is agitating, if so the water will climb the wall during the wash cycle and leak out of the overflow (which is the plastic tube you described). if this is the case, it is a transmission brake problem. it can be fixed by a professional, but you might want to look into buying a new machine.
Jun 18, 2008 | GE WHRE5260E Top Load Washer
Kenmore 416.82042042
Remove the botton front panel and look at both sides towards the bottom. There are mini shock absorbers. Most likely, one is broken. They are only $16.99 each at Sears.com (part # 131268200). There is also a counterweight on the left side that may be invlolved. I just opened my washer and saw the counter weight laying loose on the floor. Not sure if DIYJim can tackle this job or not............
Dec 06, 2007 | Kenmore 43142 Front Load Washer
Trouble with Tub
Elizabeth, it sound like a counter-weight spring issue. Spring's function is to keep tub's balance. Open the machine and look for the spring, it should be connected between tub's bottom to the machine's bottom. It seems that the spring either "run away" from its place or was broken. In any case, repair cost for it very cheap. Good luck !!
Jun 28, 2006 | Kenmore 22642 Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
14 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
