Question about Kenmore Elite 45986 Front Load Washer
What is a f20 code mean? - Kenmore Elite 45986 Front Load Washer
  • 15,935 Answers
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify the Pressure Switch hoses are intact and connected properly.
- Verify wire harness connections at the pressure switch, inlet valves, drain pump and Central Control Unit (CCU).
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Pressure Switch – remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a plastic air hose attached. Verify the electrical connections are intact, and the air hose is attached and not cracked or leaking.
To access the Central Control Unit (CCU) – with the top panel of the washer removed, the CCU is located directly behind, and just above the rear of the wash tub. There should be a tech sheet directly behind the lower panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics and to verify the wire connections at the CCU. In addition, the tech sheet will also assist in how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Tip Courtesy JSRock
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Dec 10, 2009
Fisher & Paykel fridge is showing F20 fault in screen and beeps when door is opened
SOLVED: Fisher paykel French door fridge shows F20 error - Fixya
www.fixya.com/support/t16590488-fisher_paykel_french_door_fridge_shows
Feb 15, 2013 - F20 does not stand for 20 degrees Fahrenheit you pleb. It is a fault code. Your fridge probably beeps 20 time when you open the door and then stops. To fix is simple and takes 5 mins. Remove the top left hand hinge cover and you will find a broken wire. Just switch off the fridge and then connect the wires ... What does F20 mean on my F & P Fridge. When I ...
14 Feb 2018
What does F20 mean on my F&P fridge. It beeps ...
14 Feb 2018
I have an f20 error on my fisher and paykel fridge ...
16 Nov 2017
SOLVED: Error code F20 on RF610A Fisher & Paykel
9 May 2011
More results from www.fixya.com
Fisher Paykel Refrigerator F20 Error Code ' Wills Creek Community ...
www.willscreekcommunityforum.com/fisher-paykel-refrigerator-f20-error-code/ Sep 27, 2017 - If you are experiencing a F20 code on your Fisher Paykel refrigerator, you will hear a constant beeping sound when you open the frig door. This error code means there is a broken wire on the top of the door hinge (usually left side). If you are even a bit handy, A simple solder job is the fix and can save you ...
Apr 29, 2018 | Fisher Refrigerators
Frigidaire ples389ece range
http://www.frigidaire.com/support/ResultsPage.asp?strModel=ples389ece&User=&Search=Search
That website has a manual for your Range and it should explain the F20 code.
I'm gonan look through the manual and check out what F20 means so ill be back in a bit.
Jan 20, 2008 | Frigidaire PLCS389DC Dual Fuel (Electric...
F20 error code on maytag epic any idea what this means?
F20 means that the unit isn't detecting water is entering the machine quick enough. When the error code appears if there is little to no water in the tub, then you have an issue with either the water supply to the washing machine or the electronic water valve. If the washing machine fills up about 1/2 way up the door and is overfilling with the water, it means that your pressure switch is faulty and will need to be replaced because it's not detecting that water is entering the machine.
Mar 02, 2015 | Maytag EPICz 3.7 cu. ft. Washer
I have a kenmore elite HE3t and it has an F20 error code. What does this mean?
The F20 error code means; no water was detected entering washer or pressure switch trip was not detected after 6 minutes
Many times that is caused by a blockage a pinched fill hose,or the filter screen on back of washer where hoses attach to are clogged
Good luck,i hope this helps
Gene
Aug 01, 2011 | Kenmore Elite HE5t Washer
Showing code F 20
f20 code means no water is entering the machine. make sure your water hoses are connected properly and that the water is turned on. could also be a problem with your pressure switch.
Feb 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does F20 mean. this us\ally happens during the first cycle.
as far as i can remember f20 means an outflow problem. On whitegoods.co.uk all machine faults are explained. Error codes can be quite vague and f20 could mean your pump has stopped functioning, you outflow pipe is kinked or you have an internal blockage.
May 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
MAYTAG 3000 SERIES JUST RECEIVED AN F20 CODE. WHAT DOES F20 MEAN? THE MECHINE RAN FOR 10 WASHING THE STARTED STOPPING ABOUT 10 MIN IN TO THE CYCLE WITH F-20 FLASHING.
need the correct model # and ser # _ _ _ 3000 _ _ _ _ this tell us age and and fault codes . now inside the machine / you will find a tec sheet with the codes . this may be quicker .. mm
Dec 02, 2009 | Dishwashers
My washing machine has a trouble code showing,the code is "F20",what does this mean?
F20= flow meter, they sense the 'flow', if no flow after a certain amount of time it errs out, replace the sensor, it is erratic. Tell your tech he can replace it or get a 'recall'
Oct 23, 2009 | Kenmore Elite 45986 Front Load Washer
F20 code.
in my fixing f 20 needs a new cpu main board in the top washer middle back side
Nov 16, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
79 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
