Make sure you are inserting a compatible memory card for your model. Below is the list of compatible digital media memory cards for the Lexmark P350 printer:
CompactFlash I & II
Sony Memory Stick, Memory Stick PRO
Secure Digital (SD) Card
MultiMediaCard (MMC)
xD Card
Sony Memory Stick Duo (with adapter)
Mini Secure Digital (Mini SD) Card (with adapter)
Sony Memory Stick PRO Duo (with adapter)
SanDisk TransFlash Memory Module (with adapter)
RS-MMC (with adapter)
Guidelines to print via bluetooth:
You can print photos from a Bluetooth-enabled device such as a camera phone using a USB Bluetooth adapter.
Make sure that the Bluetooth Enable and Discovery Mode selections on your printer are set to On.
Insert a USB Bluetooth adapter into the PictBridge port on the front of the printer.
Note: Bluetooth adapter sold separately.
Once the printer detects the Bluetooth adapter, the following message appears on the printer display for five seconds: Bluetooth Dongle Connected.
To print photos from your Bluetooth-enabled device, see the documentation that came with the product.
Sony Ericsson Xperia X10 Mini Bluetooth couldn't be used to
send or receive files via bluetooth, you must download and
install a program that allows you to do so.
go to: https://market.android.com/details?id=it.medieval.blueftp&feature=search_result
because Sony Ericsson Xperia X10 Mini Bluetooth is not sufficient to send or receive files via bluetooth. you must download and install a program that allows you to do so. go to https://market.android.com/details?id=it.medieval.blueftp&feature=search_result and download it
Good day,there is probably an error in the established bluetooth link between the phones,my solution goes thus;
Put off the two phones and turn back on after 5mins,reconnect the phones via bluetooth and transfer the files,if the problem persists,it means the problem is solely from either of the phones,try transferring with other phone to establish where the fault is from and let me have a fitback to this solution
you need the DW5530, it will work with the sim card slot you have. I beleave it goes inside the pc into a mini-card slot ( mini pci express not into a usb port )
