Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Colorful lines appear at the top of the television when turned on. picture comes out in double.
  • 834 Answers
The convergance amp is not working. This could be caused by one of 3 fuses locar to the lower right of the hv or Flyback transformer they are tanish brown in color you your handing then test them with a continuity tester if one is open you can replace it with a 4 amp pico fuse
please make sure the set has been unpluged and off for some time the deflection board comes out with plastic latches around the edge unplug alll connetion escept the hv lead from the flyback this is not needed as you will just flip the board over if you don't feel confortable call a shop in your area
Posted on Dec 10, 2009
I have a RCA Model R52WH74. It hs a double view to it liek the colors has seperated. It also has a wavy red line across the top. It looks like the projector bulbs are out of line. All three bulbs are...
The tv have a problems known as a convergence problems,it is dead.Tv have any colors lines R,G,B mis alignments,have any colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead,convergence board must require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to fixed the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 01, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
The picture is showing a double image and is distored.
The problem you are refering to is more than likely a convergence problem. The convergence circuit in your tv is controlled by an IC (integrated circuit) stk392-110 and it makes the 3 colors (red, blue, green) line up/converge together to create a clear picture. You'll know when this part needs to be replaced because the picture you see is 3d looking and possibly bowed on the top or bottom or on the sides in any or all 3 colors.
Jan 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Picture on Samsung LCD LNT5271F is blurred sometimes, lines, color distortion, double images, then goes away and will come back.
Try reseating the LVDS cable.It runs from the main signal board to the T-con board at the top of the panel.
Dec 01, 2009 | Samsung LN-T5271F 52 in. LCD Television
Visual transparent lines at top of picture
You have a vertical output circuit problem. This was common for Philips' sets. Have a repair shop check it out. Should not be too expensive to repair.
Oct 15, 2009 | Philips 27PT6441 27" TV
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
Sony color rear video projector KP-43HT20
get the tv degaused that should fix the problem
Jul 23, 2008 | Sony KP-61V45 61" Rear Projection...
Distorted picture on RCA LCD TV
your set has convergence problems i dont have the answer yet ,i do know that convergence broad is not what is causing this! I have one in my shop now with same problem as soon as i find out problem i will post it !!!!!
Jan 09, 2008 | RCA HD52W59 HDTV Projection Television
Convergence and picture problem.
convergence ic's
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Jan 07, 2008 | Sony KP-57WV600 57" Rear Projection...
I have 47 inch with double color in picture, reds and green
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
convergence amp ic bad
Oct 14, 2007 | Samsung HCL552W 55" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
48 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
