Question about Car Audio & Video
Stereo System Not Working
All of a sudden my system isnt working in my car. The speakers arent blown, i have reset the deck and the amp is fine...i dont know whats wrong!!
  • 65 Answers
Often time, if a speaker wire gets "grounded out," in other words when a speaker wire gets shorted to the chassis of the car, it will prevent sound. Best thing is to check through the system with a multimeter
Posted on Jan 21, 2008
"2000 Buick Park Ave. rear speakers on deck lid stopped working nine speaker system all others work
First, check the fader on the stereo, then, check the wiring from the stereo to the amp and from the amp to the rear speakers. The amp controls all speakers, not just the rear so it seems that it is still working therefore the fuses must be good. If you have access to any other speakers, I would try plugging one in in place of one of the rear speakers and seeing if it works then you'll know if it's just the speaker or not.
Jul 25, 2015 | Buick Cars & Trucks
Dennis my 1995 lincoln towncar JBL radio quit producing sound the system comes on fine but I get no sound could u help me please, what is the problem?
The Amp in the trunk might have blown,
Town Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: Blue/Red
Car Stereo Antenna Trigger Wire: Blue
Car Stereo Amplifier Location: Trunk
Car Audio Front Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: 6? x 9? Speakers[img src="http://www.assoc-amazon.com/e/ir?t=modilife-20&l=as2&o=1&a=B00009UHRE" width="1" height="1" border="0" alt="">
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Check the fuses
24851106-prgqozi4aluuon54ixeydqz4-5-7.gif 24851106-prgqozi4aluuon54ixeydqz4-5-0_0.jpg
Jul 20, 2014 | 1995 Lincoln Town Car
I was listening to my stereo system in my car and all the sudden all the speakers stopped working and the sub has a constant and quick vibration. I disconnected the sub but the other speakers still...
check the out put of the head unit . check the out put on amps check speakers do this all with a DMM Digital multi meter, check that amps aren't in protect. check ground on head unit. if you dont know how go to you tube and type in such as, this how to test speakers with a DMM many videos on all subjects.how to test amp out put with the humming you may have a short or a blown speaker some where.
May 03, 2013 | Car Audio & Video
Just got a used boat with a JVC KD S590 stereo and a JVC KS AX302 amp. The stereo works fine with the in boat speakers but the tower speakers do not work, I checked them both on another system and they...
take a digital volt meter and check the power cable and ground on the amp to see if you are getting any power . should read 12.5 or more if no power then check fuses and the ground connection
if you have power then replace the equipment that not working
Oct 29, 2010 | Car Audio & Video
My 1994 e150 sound system sounds puny compared to what I believe stock should be. All the speaker work there just isnt much volume, bass, or treble. Is there an amp that boost the sound? where is it?
well first i would change all the mid speakers out to kenwood speakers and not the cheap ones cause the cheap ones are like stock speakers the more higher priced ones like the 80 dollar ones are equal to 300 dollar speakers then you should get a 2 channel or 4 channel MTX amp each speaker can take 150watts. your system would be alot better than stock. if anything look on crutchfield.com that would be the best place if you dont want to go to a car stereo shop in your area. if you plan to keep the deck stock then you need a hi-lo adapter which will hook up to the right or left rear speaker and the remote wire needs to go to the ignition wire behind the deck
Aug 01, 2010 | Car Audio & Video
Stereo speakers not working
Sounds like the factory deck went bad or you have blown speakers and causing the deck to go into protect mode. Check the speakers frist
Jun 04, 2009 | Car Audio & Video
Subs fading out briefly but speakers working fine
Holy mackerel you have a ton of power i bet that ****** is loudddddd-sounds like your charging system isnt quite keeping up with the amount of current draw that your amps can pull.Upgrade your alternator and look into a dual battery system using an isolator-that way your alt will charge both batteries but your amps will only pull off the one battery-you can look online into how to set that up its not that hard for someone that has managed to install the gear that you already have- Some folks if not most would encourage you to get some sort of capacitor to store power blahblahblah-BUT a dual battery system has waaaaayyyy more storage capacity than a capacitor does-check out the pro competitors online they arent using capacitors to run their stuff they use banks and banks of batteries to get their power-brother you need more juice
Apr 15, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Active sub has stopped working
I have 2 12" kenwood speakers on a 1000 watt amp ... the other day they cut off but the speakers arent blown, i replaced every fuse in the amp and the amp still cuts on when i turn the car on, yet the amp seems to not be pushing the speakers ...i also looked at the main fuse under the hood of my car but i cant tell whether its blown or not, why is my amp not pushing out any power?
Mar 31, 2009 | Audio Players & Recorders
Rca 5 disk changer stereo model # rs 2640b
Unit may have defective amp or blown speakers. Have serviced
Aug 09, 2008 | RCA RS2620 Single Cassette Deck
No sound
you may have a blown speaker...many cd decks will shut off their audio circuits when a speaker is blown to protect from shorting out. Go to the back of the deck and try disconnecting speakers one by one. You will have to turn the deck off and back on each time. Hope this helps!
Jul 16, 2007 | Verge VGA300M Car Audio Amplifier
Car Audio & Video Logo
184 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
