Question about Motorola Mobility RAZR V3
I do not have deleteas an option in my mess main menu i understand how to go into main menu but there is no delete option there. thank you, budd
I can not open my facebook
I think the cookie setting in your browser that causing the mess up
wcvczl2igfbbgaaaabjru5erkjggg==
Delete Cookies in Internet Explorer How to delete cookie files:
  1. Open Internet Explorer and click on the "Tools" menu.
  2. In the "Tools" menu, click on "Internet Options".
  3. The Internet Options pop-up window appears.
  4. Under the General Tab select the "Delete Cookies" button.
  5. Delete cookies by clicking "OK".
Optional:
  • Select the "Delete Files" button to clear the Internet cache. Make sure to check the box to "Delete all offline content".
  • Delete temporary Internet file history data by selecting "Clear History".
arge3vrldwcfaaaaaelftksuqmcc
Delete Cookies in Firefox How to delete cookie files:
  1. Open Firefox and click on the "Tools" menu.
  2. In the "Tools" menu, click on "Options".
  3. The Options pop-up window will open.
  4. From along the left side of the window select the "Privacy" icon. This displays the Privacy Settings in the right side of the window.
  5. The option to erase the temporary Internet file "Cookies" is near the bottom of the list.
  6. Click "Clear" to delete cookies.
Optional:
  • Delete all temporary Internet files by selecting the "Clear All" button.
  • Delete specific temporary Internet files such as History or Cache files by selecting their individual "Clear" buttons.
Delete Cookies in Netscape How to delete cookie files:
  1. Open Netscape and click on the "Tools" menu.
  2. From the Tools menu select "Options".
  5. The option to delete cookies labeled "Cookies" is near the bottom of the list.
Optional:
  • Delete specific temporary Internet files such as "Page History" or "Cache" by selecting their individual "Clear" buttons.
I hope this information will be helpful. Thank you for using FixYa!
Jun 14, 2011 | Facebook Social Network
I need delete msg my mobile no 9788270157
Try following these steps:
  • Go to the main menu option
  • Go to Messages
  • and then go to particular option there wherein you want to delete the messages ( like ex. Inbox,Outbox,Drafts)
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
Jun 02, 2011 | Nokia 1600 Cellular Phone
Master reset code
  • Remove any memory cards that are in the phone (MicroSD, SD or MiniSD), and remove the SIM card, if your phone uses one. Make sure the phone is turned on before continuing (if you had to remove the battery to remove the memory card or SIM, turn the phone on).
  • Select "Contacts" from the main screen of your cell phone to access your contacts list. Go through the entire list, selecting each name and deleting the entry. Consult your cell phone manual to find out where the "Delete Entry" option is located in your Contacts menu (if you do not have a manual use the link in "Resources" to download a copy of one for your phone). Typically, when you choose an entry, the option to "Edit" will appear on the screen. Select that and one of the sub-options will be "Delete Entry." Do this for all of the entries in your Contact list.
  • Open your text messaging (SMS) application on your phone. Most phones have an icon you can choose from the main screen to go to the application (where you can compose, send, or read SMS messages). Press your "Menu" key again (or the key under the "Options" choice on the screen), and select "Delete All." Click on the choice to delete both read and unread messages. When you are done, return to the main menu.
  • Delete all of your media files. Go to your music, video, photo and MMS directories, and either use a "Delete All" option from the menu, or individually highlight each file name, select "Edit" and then "Delete" and remove each one.
  • Open your calendar and clear all of the entries. Make, sure when you choose this option from the calendar edit menu, that you check off the option to remove the calendar history as well, so past events are erased.
  • Open your email settings (where you entered your email address originally to receive notifications on your phone of new emails), and delete the email address you registered.
  • Open your notepad program and delete any notes you may have stored in the memory. Do this for any Voice Notes, if your phone offered this function as well.
  • Oct 07, 2010 | Motorola Mobility W220 Cellular Phone
    How can I play online?
    Look for the Online / Multiplayer option from the game's main menu.
    Jul 14, 2009 | EA - Electronic Arts Battlefield Bad...
    On nokia 5800 it says sim card full, can't
    I have just fixed the exact problem on my phone, all you need to do is go into messages and then select options, SIM messages and delete any messages in there this should solve the problem as it has just worked on mine.
    Mar 12, 2009 | Cell Phones
    Goes off even when disarmed!
    This is from page 19 of the Simon3 manual found here:
    http://www.safemart.com/manuals/simon3.pdf
    It appears you have the "CHIME on Motion" enabled. Follow the Option 41 steps to disable it.
    Option 41 - Voice Chime
    The panel will verbally announce which chime sensor has been tripped if the chime
    feature is on.
    Add enables chime voice.
    1. Open panel cover. Panel announces, Use numbered keys to enter ID.
    2. Enter Access Code using the numbered keys. Panel announces, Please select from
    Start Menu.
    3. Press Add from the Start menu. Panel announces, Select from main menu
    4. Press Option #. Panel announces, Option 1, press again for next option or done to
    select.
    5. Press 41. Panel announces, Option 41, press again for next option or done to
    select
    6. Press DONE. Panel announces, Option 41 is on.
    Delete disables chime voice. The panel will not announce which chime sensor has
    been tripped but will still chime 2 times for doors and 3 times for motion sensors when
    a given sensor is tripped.
    Start Menu.
    3. Press Delete from the Start menu. Panel announces, Select from main menu
    select.
    delete
    6. Press DONE. Panel announces, Option 41 deleted.
    Dec 26, 2008 | GE Security Simon 3 Wireless Home Security...
    I WANT TO DELETE OPTION FROM 'CENTER' BUTTON TO GAIN MENU OPTIONS
    first you selected the right button on your hand and then it will deleted ok you changes the option button in settings
    Dec 26, 2008 | Samsung SGH-G600 Cellular Phone
    Virus
    i understand you have a problem with the virus here are a few solutions
    1.go to start >run>type regedit>HKEY_CURRENT_USER/softweare/microfost/windows/currentversion/run
    now look what it says when u clikc run if anything that seems suspicious deletea it be carefulk u could permntaly mess up ur pc look for things like that also in HKEY_LOCAL_MACHINE
    2. download avast i recomend it do a full system scan and if it finds a virus deleate it then \ do another scan find agian then move to chest
    3. prefor a system recover thsi will deleat all things that havent came with ur ocmputer when it was mad such as viruses and male ware etc.. just get a cd to store improtant inf o you dont wasnt to lose!!!!!!
    May 29, 2008 | Computers & Internet
    Deleting pics from phone
    which phone are u using? as far as i understand if its multimedia phone than u will get delete in options menu
    Apr 30, 2008 | Pantech Duo Smartphone
    Main Menu problems
    your phone has deleted its own menu options happens all the time and they say machines are smart is your clock out too?
    Unfortunatly you wi;ll have to take a different route to get to your phone options or you will have to invest in another many have done this unfortunately but if its been under 6 months since you got it you can get a new one
    Mar 30, 2008 | Motorola Mobility RAZR V3i Cellular Phone
    Motorola Mobility RAZR V3 Logo
    16 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    Virgil Wolter
    Level 1 Expert
    vince
    D. E. Hev
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
