Question about Dimplex Kitchen Ranges
How do I change fire effect bulbs on dimplex sbn20 springbourne
  • 104 Answers
SOURCE: How to replace fire bulb for Dimplex HTN20
I wanted an answer to this too. It was hard to find, but here we go.
Get hold of a torch, and look closely at the decorative surround at the bottom of the fire. There are two screws hidden in there, on each side! See below:
Unscrew these, and you can take the front off, and get at the bulbs.
For information, the fire takes two screw in bulbs, described as 240V – 60W E14 SES Clear Candle Lamps.
Hope this helps.
Posted on Mar 13, 2009
SOURCE: We have a Dimplex Danesbury
1.Remove the coals .
2.Remove the two screws in the front of the brass grate second bar down.
3.pull the grate assembly away from the fire.
4. The bulbs are now exposed.
Replace with 60 Watt SES clear candle bulbs. Reassemble in reverse order.
Posted on Dec 21, 2010
SOURCE: dimplex opti-myst fire main effect bulbs not
i've got the same problem - have you fixed it yet??
Posted on Jan 01, 2011
valeantudor
  • 787 Answers
SOURCE: Finding a wiring diagram for a Dimplex
What part do you want to replace?
Posted on Jan 19, 2011
  • 4736 Answers
SOURCE: change bulb on dimplex fire
If it's a fireplace that sets inside a free standing cabinet mantle, you access the bulbs by removing the glass on the front (actually, it''s plexiglass). Then remove the logs and the glowing ember bed (It lifts out). Now you can see and have access to the bulbs to change them.
It it's wood stove look-a-like unit, you can access the bulbs by removing the rectangular panel on the back, near the bottom of the of the unit. Removal of that panel gives you access to the bulbs.
Hope this helps to answer your question.
Posted on Mar 12, 2011
Dimplex dakota heater is working but flame effect is not its led I think not bulbs.
Says you can turn it on and off? Did you knock the switch?
Can I operate the flame effect on the fire without the heat?
All our Optiflame and Opti-myst fires can be operated on a flame-effect only setting, as can the flickering flame effect on our freestanding bar fires.
Is the flame effect expensive to run?
No, to run the flame effect involves powering light bulbs and a small electric motor and in most cases costs no more than a couple of pence an hour. Some of our fires have LED lamps fitted which are even more energy efficient.
Some have bulbs, some have LED.
Example calculations:
Using UK standard average price of electricity of 14p/kWh (source: Energy Saving Trust Feb 2015)
Optiflame LED flame effect only (eg Danesbury) = 0.1p every hour
Optiflame conventional bulb, effect only (eg Cheriton) = 2p every hour
Opti-myst, flame effect only (eg Oakhurst) = 3p every hour
Opti-V single screen = 0.5p every hour
2kW fan heater, on constantly (no thermostat) = 28p every hour
Optiflame lightbulbs for sale. Remove the coals and check for bulbs.
https://store.gdcgroup.co.uk/dimplex/products/index.htm?product_code=FP03022
Dec 23, 2015 | Dimplex Heating & Cooling
How do you change the light bulb in a dimplex gem 20 heater?
Hi, First ALWAYS disconnet from the mains!
To change the bulb on your Dimplex you'll firstly need to remove the log effect, there are 2 small black head pozi type screws hidden at the front one on the left and one on right which your bulbs are under situated in their holders (as there are 2 of them) they are mini screw types as opposed to the standard baynot type replace the defective bulbs with like for like once fitted reconnect the mains and try if working, JOB DONE! Page 14 on the link shows exactly how to do it Regards Steve.
http://www.dimplex.com/cms/publications/7400070000r01.pdf
Aug 07, 2014 | Dimplex Compact Electric Flame Stove...
Fire was working fine, then flame effect stopped. Heater still works on both settings, but no flame effect. Tried new bulbs, but still no flame effects, any ideas?
If it is not the bulbs, it is often a melted switch or circuit board.
You can obtain technical support for your stove here:
Dimplex Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Jan 05, 2013 | Dimplex Compact Electric Flame Stove...
I have 2 Dimplex DS4411 fireplace heaters. One has the fire display, but does not heat. The other has heat, but no fire display. How do I fix it?
The fire display is a simple replacement of the light bulbs that produce the effect.
The heater issue could be a bad temp sensor, or a bad heater.
You can contact Dimplex support here:
1-888-346-7539
Monday - Friday
Nov 28, 2012 | Dimplex DS4411 Electric Heater
Changing bulb in dimplex cht20 fire
Yes this is very easy on the cheriton range of fires.... remove the coal, then remove two screws from the front of the coal holder... the whole brass coal holder will pull away from the machine. The bulbs (two of them) are located directly behind this, just behind the rotisserie flame effect. The flame effect can be pulled out of its holder to access the bulbs.
Feb 19, 2012 | Heating & Cooling
The light has gone out on my dimplex ASP20 fire.
There are several light bulbs that create the flame effect. However, it's unusual for all to go bad at one time. If you still have your Owners Manual, it will tell and show you how to access and change the bulbs. In the meantime, turn the Master ON/OFF switch to OFF and Unplug the unit from the wall outlet. Wait 12 to 15 minutes and plug the unit back in. Turn ON the Master ON/OFF switch and test each function one at a time. Hopefully, the time unplugged gave the unit time enough to reset itself. However, if this continues to occur on a regular basis, contact Dimplex USA, Technical Service at
888-346-7539
If you want to Troubleshoot and access the bulbs yourself: Remove the Plexiglas from the front of the fireplace and carefully remove the logs. The ember bed below where the logs were sitting will lift out and you'll have complete access to the bulbs. The bulbs are 60 watt, small base, chandlier bulbs.
Hope this helps you solve the problem
Mar 21, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
I have a dimplex springbourne fire and the heater shuts off after it has been on for a short time what is the problem with the unit
Apparently, the heater is overheating and the overload switch is shutting the heater element off.
Contact Dimplex USA Technical Service at 888-346-7539 for assistance in solving this problem.
Mar 07, 2011 | Heating & Cooling
Hope this helps.
Feb 07, 2009 | Dimplex DS5598 Mid-Size Heater
Kitchen Ranges Logo
201 people viewed this question
Top Dimplex Kitchen Ranges Experts
Richard Lane
Gene Haynes
Are you a Dimplex Kitchen Range Expert? Answer questions, earn points and help others
