Question about Datamax I-4208 Thermal Label Printer
Datamax I-Class Thermal Label Printer: How do you make the ink darker. It is printing too light.
    Problem Solver:
  • 10 Answers
Check job darkness setting and you can downlaod manuals on www.datamaxcorp.com
Posted on Apr 15, 2010
Datamax I-Class I-4208 void
If the word "VOID" prints, turn the printer off, reboot your computer, turn the printer back on, and try printing again.
Oct 23, 2011 | Datamax I-4208 Thermal Label Printer
My datamax thermal is not heating up
These printers do not "heat up" as such. Possible causes are:
1. Incorrect ribbon type for fitted ribbon spools. Look at back plate and see which way arrows are pointing. If arrows point Anti-clockwise, then you require inside wound ribbon (i.e. standard datamax) If pointing clockwise then you require outside wound (i.e. Zebra type ribbon). Check ribbons by touching sticky side of label to ribbon (it will transfer ink to label on print side).
2. Could also be faulty printhead, Logic board or Power supply. These will require an engineer to check properly.
Jul 05, 2011 | Datamax M-Class Thermal Printer
Do you have downloads for Datamax Drivers? Mainly, E-Class
Free Windows Printer Drivers for Datamax can be downloaded here: Custom Design Label Systems from Able Label Systems
Look for the link toward the bottom labeled "Free Thermal Printer Drivers."
Jun 09, 2011 | Datamax M-Class Thermal Printer
I have a w class data max printer and it prints the labels but very light ink on it i was told that the green wheel on the side controls that but i have tried every single level on it but still light...
Lift the print head (where the label comes out and the ribbon should be right under it)
Take a clean Q-tip and some IPA, and wipe the little black line of dots you will see inder the head. These are the thermal points on the print head and they do build up debris which moves the head away from the ribbon causing lite print.
Dec 30, 2010 | Datamax M-4208 Thermal Label Printer
Hi! I have a problem with my office Datamax E class printer. When i change tickets in the printer it doesn't print them the right size - normally they are too short. Do you have any idea how to solve...
If you are changing length(feed length) you may have to recalibrate the printer . Also ensure that your print format is the correct length for the stock.
You can look at the setup of the printer using the datamax-oneil printer configutation program, or if it is using IP connection, you can go directly to the internal web page for set up. make the cal length 3 times the label length, or leave at the default value.
Dec 29, 2010 | Datamax E-Class E-4203 Thermal Label...
Label print too light
This could be caused by the darkness setting coming from the label software / printer driver. It's set too low and that setting will usually override the darkness setting in the printer. That's why test labels are fine.
Hope that helps.
Apr 08, 2010 | Datamax M-Class 4208 Thermal Label Printer
Problem with printing labels - not aligned, some missing
This is due to print server problem, you should change the options on the driver.
Nov 04, 2008 | Datamax M-Class M-4206 Thermal Label...
Datamax E class
Go to Control Panel > Pritners and Faxes. You should be able to see your printer there. You can check and ask it to print a test page.
Jun 05, 2007 | Datamax 1/PK EXTERNAL LAN INTERFACE METO...
Datamax I-4208 Thermal Label Printer Logo
682 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Starnley Johnwells
Starnley Johnwells
rongg
Joseph Mueller
Joseph Mueller
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
