Question about Dell Dimension C521 PC Desktop
My c521 powers up and shuts down immediately after. You get about 3 seconds of activity from the fan and LEDs. Nothing appears on the screen.
  • alkeith Jun 17, 2010
    Thanks for your advice. I am sorry I wasn't able to respond sooner. It was right on the mark. I changed the power supply and it worked like a dream. Thanks again.
  • 345 Answers
Sounds like a power supply is gone bad. if you can replace it and usually it is simple u can get them cheap on tiger direct. some stores sell pwr supply testers so can try that too.
Posted on Dec 10, 2009
Testimonial: "I am in the process of getting a power supply. There seems to be a consensus on the power supply from all those canvassed. Will let you know."
  • alkeith Aug 08, 2011
    Sorry for my late response. It was the power supply. Thanks for your helpful responses.
Hp P6000 fans stop after 15 seconds. Hard drive light stays on. nothing on monitor
dead PC, DESKTOP PC ,as old as 2009.
the fans tells you the PSU shut off, for cause.
fans, so you saw all fans turn off or just 1. or 2 of 3.
my pc has 4 fans many have 3;
CPU fan stops ,cpu overheats , PC goes slow or dead. clean the lint off it.
GPU fan , video goes dead. if it overheats.
PSU fan is inside the PSU if it goes bad, PSU is bad.
no monitor stated, is it CRT or LCD is it 15 years old.
if the monitor is 2002 or newer the OSD screen works
even with PC turned off, press the select button see that OSD screen ? telling you the monitor is not dead in 1second flat;
i caN NOT understand why the HDD lamp glows,
if the PSU shuts off , most LEDs go dead, on my PC
the standby LED on the MOBO glows, unless you pull the PSU power cord.
your HP PC came with 9 different mobo, during its production run.
at least. so answers come harder from that reason.
here are some simple tests.
test 1
power on, hear fans run
does the DVD drive (or cd) button eject work,.?
do all fans not just 1 or 2 worK? look for all fans clean the lent out
or things will overheat,
PSU can be bench tested or in the PC case.
using a jumper wire, even the HP service manual covers that.
power on the PC (after keeping monitor on for 5 full minutes)
test 2
the Screen must say, "hit ESC key to enter HP setup" BIOS.
press the ESC key on the monitor
if no text shows up that is a dead PC< "text above missing{"
if the PC told you to hit another key do so.
The ESC key , activates the BIOS brain. this cause
all those pages to work as seen in your service manual;.
if BIOS is dead that is a bad PSU (monitor ok)
or CPU is overheated.
bad ram, take all sticks out and test 1 by 1, ask how. !
The PSU will shut down on up to 12 or more faults
but never shuts down the standby power bus. unless AC line pulled.
IF the PSU has fan as most do this is the first place I look.
try this guide
https://support.hp.com/us-en/document/bph06788
Jul 08, 2017 | HP Computers & Internet
Tip
Error code by led indicator samsung SP67L6HX1X
<img src="mas_baz.jpg" /><br />There are three LED indicators. LAMP, TIMER, STANDBY/TEMP. Each Led or combination leds indicated problem.<br /> <ul> <li>LAMP blinking : The picture will automatically appear in about 15 seconds.</li> <li>TIMER and STANDBY/TEMP blinking : A cooling fan inside the set is not operating normally.</li> <li>LAMP and STANDBY/TEMP blinking : Lamp cover on the rear of the set is not properly shut.</li> <li>STANDBY/TEMP blinking : Check if the ventilation hole on the rear of the set is blocked, because if the inner temperature is too high, the power will shut off.</li> <li>All LED blinking : Lamp may be defective.<br /></li></ul>It takes about 30 seconds for the TV to warm up, so normal brightness may not appear immediately. The TV has a fan to keep the inside lamp from overheating. You'll occasionally hear it working.<br /><br /><br />
on Mar 29, 2011 | Samsung HL-R6167W 61" HDTV
Sceern locked up, battery life full. cannot shut off as well.
try holding down JUST the power button for 120 seconds may soft reset then
Jan 01, 2015 | Tablets & eReaders
Gateway laptop i push power button it wont boot up but leds in front flash 4 times
Try holding down the power button instead of just pushing it. I had this problem with my HP dv7 and holding the power button down for around 5 seconds worked for me. Also make sure that its plugged in to a power source.
Oct 23, 2012 | Gateway Computers & Internet
Freezes during start up
My first plan of attack would check
Second the event log in the BIOS, looking for a heat event. Make sure your fans are spinning, while you are in there get a can of compressed air and blow out any and all dust. Sometime it becomes necessary to remove the processor and put a little Artic 5 between the cpu and the heat sync.I would check out the video card, the easiest thing to try first is to remove and update the video drivers. I still lean towards the heat event Idea...
Hope this give you a headstart in the correct direction. Good luck,
PS, if you are the one shutting it down and rebooting, look to the Video Card,
Apr 25, 2009 | Dell Dimension C521 PC Desktop
TV PIcture and Sound Shut Down
it would appear its shutting down in a protect mode
its possible its a convergence circuit problem or something on the deflection bd
but it most likley will require some assistance from a tech that is used to working on this type of set
if you noticed when it does come on that the colors are all off line then suspect convergence circuit trouble the the green leds tell you what source is still alive there is a chart in the cabinet that will correspond with each source voltage that can lead you to tracking it down if you know what to look for and have the tools to do so
Jan 16, 2009 | Hitachi 53FDX20B 53" Rear Projection...
Gateway 400SD4 won't power up
replace the battery or have it tested. If these batteries don't have a minimum charge the machine will not boot into windows & will just shut down.You might try checking the battery condition with the "battery conditioner" in the bios
Rockman
Nov 26, 2008 | Gateway 400SD4 Notebook
Ya...Ok
Good Day, egear00;
Did you try the DMD board? Other wise I'm still looking for solution.
big IRISH.
Aug 21, 2008 | Hitachi 60V500 60" Rear Projection...
Problem with Dell Inspiron 1100 series laptop
Most certainly a non working fan would cause this behavior. Laptops are much more susceptible to overheating. Fan failures can be hastened by regularly blocking the fan by doing things like using it on a pillow or soft surface. The behavior is exactly what you think.
Nov 26, 2006 | Dell Computer Refurbished PE3250 SYSTEM...
Dell Dimension C521 PC Desktop Logo
203 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
