Question about Sony Playstation 3 (PS3) Console
When i switch my PS3 on the light will appear green then a blue light will come on and off and then the green light will turn orange and then flash red continuosly!
    Problem Solver:
  • 19 Answers
Yellow Light Of Death <-- Thats your fix. Or if still under warranty call Sony Tech Support.
I’m happy to assist further over the phone at https://www.6ya.com/expert/pete_c82bc0866827d502
Posted on Dec 11, 2009
Turn ps3 on light goes green then flashes blue then back to red
PS3 turn on goes green then flashing red is not a new issue. Please read this post and you can find the solution :
PS3 Red Light Blinking Fix
Feb 09, 2011 | Sony Playstation 3 (PS3) Console
When I turn on the PS3 it makes loud driver noise and the blue /green lights come on but after 30 seconds it beeps 3 times and flashes red. There is no orange or yellow flash. Someone suggested taking out...
hello have you tried to reset it.while in standby mode press and hold the power button you hear 1 bleep then 2 short bleeps release the power button this should reset the ps3 make sure you've got it connected to the tv screen hope this helps
regards
shaun
Aug 02, 2010 | Sony Playstation 3 (PS3) Console
PS3 will not turn on
your ps3 has the yellow light of death, here are some quick fix you can do:
1. Turn off your PS3. If you think it has been caught by the heat, then give it some time to cool down and turn it back on again
2. Check your PS3 and see if there is any loose cable
3. Try to put out the hard-drive, and put it back in. You might want to repeat this 2-3 times for better results
4. Clean the air vents from dust and PLEASE don't put your PS3 on the floor on up against the wall because it will block the air and that what cause the ps3 to overheat
Good luck.
Jul 24, 2010 | Sony Playstation 3 (PS3) Console
Ps3 will not switch on. The green light turns orange than red
This is known as the yellow light of death (ironic i know because it blinks red). This is caused when the unit overheats causing the solder on the board to melt and bridge(connect). Once this happens it shorts out the board causing the error you have now. Contact Sony and see if the unit is still under warranty.
Feb 12, 2010 | Sony Playstation 3 (PS3) Console
Soon as turn PS3 on it goes orange then flashes red.
Its called the Yellow Light of Death. It can be repaired but what you need is an Infra Red BGA reflow of the solder on the PS3 graphics chip.
The best place in the UK to do it is:
http://www.playbackups.com/Playstation3-xbox-360-repair-repairs-manchester-bga-solder.html
Nov 09, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wrecked
it has a bug if it is a 40 or 60gb they are the ones that have it.
Jul 08, 2009 | Sony Playstation 3 (PS3) Console
My playstation won't turn on!
I know what is the problem the same thing happen to me before you need to open your ps3 and look for a battery that the ps3 have inside. the battery is locate under the motherboard take out and them put it back and this is everything whem you finish try to turn on your ps3.
Feb 01, 2009 | Sony Playstation 3 (PS3) Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
229 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
