Noise on phone line - noise disappears when Gigaset SE587 router is switched off. Have changed ADSL filters to no avail.Any ideas? Rob Stickland - rmstickland@lineone.net
  • 622 Answers
Physically add a filter... goto radio shack or compusa and ask them if they have a phone line filter... if that doesn't clear it up then you have to talk to your phone company ( the one that maintains the line )
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Posted on Dec 10, 2009
  • 557 Answers
You can purchace a very inexpensive phone line tester, then you will have the ability to check your phone jacks. This will tell you if any of your jacks have the polarity reversed.
Incoming voice is very low.battery is in fully charged condition.Volume is also set at max. WE are putting the call under speaker phone and continuing the call.
If you have ADSL line also connected to the same phone then it is because of that...
To solve the problem simply buy one vioce filter and install it in your phone line it should cost you around 2$.
Aug 09, 2013 | Siemens GIGASET-A49H GIGASET-A49H
My M1255nf works fine except that since we moved last month, when I get ready to send a fax the line is very noisey even with the phone line removed. I tried replacing the fax card but still same noise. I...
Do you have ADSL internet in your new place? If so you will need an ADSL filter plugged into the phone outlet and plugged into your fax machine. so it would look like phone wall jack--->filter-->fax machine.
ADSL internet creates it own jabber or digital noise in the line and the filter will stop your a analog device from hearing the noise. If you don't have a filter for your phone as well, you should get one. Without filters your ADSL internet will be slower as well. Your ADSL modem should have came with at least 4 filters, if not they can be purchased at your local Bestbuy, staples or computer place. NOTE: Filters only work if you have ADSL or DSL internet.
If you do not have ADSL or DSL internet and still have noise you may have to call your phone service provider to get them to diagnose your line issues. They can fix some noise issues from their end.
Chris
Sep 01, 2011 | HP LaserJet M1522nf Multifunction Printer...
Noise on phone until I switch off Siemens Gigaset SE587 router. I have changed ADSL filters to no avail.
Did that work? You called them and they will fix it for you or are you looking now for a new provider?
If my suggesdtion helped, please vote
Thanks
a
Dec 10, 2009 | Computers & Internet
Seimens Gigaset se587 ASDL Line speed goes
It turned out to be a phone line difficulty, not the modem. Seems there is a not so friendly mouse in my house. Thanks anyway. Live long and prosper.....
Sep 15, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Siemens gigaset se587 wlan dsl
HI
A flashing ADSL light on the router means its not getting constant broadband signals. Make sure it is connected to the adsl filter without any extensions and the filter should be directly connect to the main phone socket and not to an extension socket. Also check if the phone socket has 1 or more than 1 ports on it. If it has two port its most likely a SSFP socket which does not require a filter as it is inbuit.If all the connections are fine try changing da filter.
Sep 07, 2008 | Siemens (120-5830-001) Modem
ADSL light flashing!
what is used this router it is a adsl router or only router if this is only router then you have to connect your adsl modem then only its work properly .
Sep 03, 2008 | Computers & Internet
How to setup port forwarding on gigaset se587 router
Hi - You can get an online guide on the link below:
Gigaset se587
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 04, 2008 | Siemens Computers & Internet
Siemens gigaset se587 wlan dsl wpa
You can try this link, this has a step by step instruction and screen shots as well. I hope this one helps.
http://portforward.com/english/routers/wireless/Siemens/Gigaset-SE587/wireless.htm
May 04, 2008 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Error 106
the ipaddress of the router may not be 192.168.1.1 it should say somewhere on the router or the documentation
if you are suing DHCP to allocate the IP address, and the router is set as a DHCP server you should be able to see the ipaddress using whatever tools Apple give on settign up networks.
I think there is possibly something wrong with your telephone line setup check that no phone is connected unless its through a adsl filter, or you have an adsl socket on the master socket in the house. The fact that you are not getting the online light to light up suggests to me that the router isn't talking ADSL network. consider removing ALL phones temporarily and see if that helps...
you should be able to PING an IP Address, again I don't know how youd do that on a MAC, hate 'em personally.
usually all you need to know are the IP address of the gateway (the router). set the DNS to the same IP address, unless Tiscali advise otherwise
the ADSL filters should only remove the hissing noise on the telephone line, so after plugging in the filter the phone should work as normal..
Apr 29, 2008 | SMC EZ Connect Wireless Networking Starter...
Noisy phone line with 2wire rpoter
if the line is clear, just use a line filter only where you have a phone fitted and nowhere else, that way you can try the different filters if you are using more than you need as it sounds as if one may be faulty. Also check any extension leads you may have or remove and check you phone line again for noise. If there is noise it would normally stop you from connecting to the internet also.
Jul 01, 2007 | 2wire (1000-400108-001) Router
Computers & Internet Logo
181 people viewed this question
Alun Cox
David Payne
David Payne
