Question about Welch Allyn Spot Vital Signs Monitor with NIBP and Stand
I am a trainee nurse Can you tell me how does the nibp machines work? How does it measure the correct preasure?
    Problem Solver:
  • 14 Answers
You just have to put the right size cuff on the patient and press the green button.  Here is the manual for the Welch Allyn Spot monitor http://www.welchallyn.com/documents/Patient%20Monitoring/Vital%20Signs%20Capture/Spot%20Vital%20Signs/usermanual_20070523_spotvs.pdf
Posted on Feb 21, 2010
Are the Feed Dogs on a model CX205LA Brother Sewing Machine 5mm or 7mm, or other? I need to know so I can purchase the correct "narrow hem foot". Thank you.
This indicates that the measurement of the opening in the needle plate will tell you which foot to buy. If the opening measures 6mm, then it is a 5mm machine. Or, you can stitch the largest zig-zag stitch and measure the width of the stitch.
How to determine if 5mm or 7mm machine sewing discussion topic...
Aug 24, 2017 | Brother Sewing Machines
I need a workshop manual. Thnks
Your body works better when you're working all from it. You also elevate your Testosterone Booster levels however work home loan houses muscles. Within a nutshell: working the whole body, gets better overall results. This is an essential point for natural trainees.
http://greencoffeesupremecleanseidea.com/megadrox/
May 17, 2016 | Sewing Machines
How to calibrate my Jobar blood pressure cuff?
Was yous at heart height when you took readings? Too low will give high readings. Nibp can differentiate by as much as 10-15% remember.
Sep 05, 2014 | Health & Beauty
After putting the correct preasure on the tire and resetting the tire preasure light it's still on
Don't spend money taking it to a mechanic or dealer. Lower the spare a correct the pressure in it. Then reset the pressure light. All these Lexus tire sensors are little transmitters sending a signal to your car's receiver. Had the same problem and solved it this way.
Jan 05, 2012 | 2007 Lexus RX 350 FWD
Nibp is not recording ,
What do youmean by not recording ? Is it actually getting the pressure but not recording on paper ? If it is not getting a pressure at all , does it give an error on-screen ? (time-out etc. ) These NIBP units use a pump and there may be a leak somewhere in the line from pump to cuff . If you have another unit or any Mindray unit with NIBP , you can troubleshoot using another NIBP line . Unplug the exisiting and try another line . If not verify the cuff does not have a leak and you can run a leak test withing the unit itself . If you do not have a manual , you can get one online from Mindray or other sources to describe in detail how to run the leak test .
Jan 25, 2011 | Medical Specialties Mindray Pm9000vet...
Very little fuel preasure on Explorer
there are two fuel lines on left side of engine if you trace the lines to the rail one after the regulator is the return line disconnect it and place line in bottle turn on key and measure how much is being drained to bottle should be very little if thers none then its the pump problem .always check power and grounds be for you replace the chek the plug right before the pump on frame rail at left rear leaf spring have seen problems with that plug. if you do replace the pump allways grind clean ground by the pump. hope this helps.
Sep 13, 2009 | 1996 Ford Explorer
Welch Allyn Spot Vital Signs Monitor with NIBP and Stand Logo
262 people viewed this question
Top Welch Allyn Medical Experts
Argospete
Argospete
ykanter
Level 1 Expert
Are you a Welch Allyn Medical Expert? Answer questions, earn points and help others
