Question about Microsoft Xbox 360 Console
Controllers will not connect with xbox put new batteries in them an still not working. it came back from being repaired yesturday by microsoft an now this has happend.
  • 3 Answers
On the top of it, Around where u put the battery cartage in, you can see a little button, press it, and above the On/Off Button on the xbox is another button, Click that too right after u clicked your remotes, it should connect to your Xbox 360
Posted on Dec 10, 2009
SOURCE:
Connecting new Xbox controller for 1st time
just put batterys in and push the button on top on the controller (its small but you cant miss it) and at the same time press the small button on the front of your xbox its a little bit bigger the the button on your controller and it should work, the rings on your xbox and controller should flsh and go in a circle and if it dosnt work the fisrt time keep doing it untill it syncs, hope this helps, Jamie
Dec 12, 2012 | Microsoft Xbox 360 Elite Console
X box controller keeps turning itself off - I have put new batteries in
Connection problems might be caused by one or more of the following factors:
  • Weak batteries or a weak Xbox 360 Rechargeable Battery Pack
  • Interference from another wireless device, such as a microwave oven, a cordless phone, or a wireless router
  • Metallic objects positioned between the console and the wireless controller, such as a chrome faceplate or metal dividers, shelves, or doors on an entertainment center cabinet
    Note All licensed Xbox 360 console faceplates are tested for interference, and do not interfere with licensed wireless devices.
  • There are already four controllers connected to the console.
uparrow.gifBack to the top THINGS TO TRY Solution 1: Restart your console Turn your console off, wait a minute, and then... Solution 1: Restart your consoleTurn your console off, wait a minute, and then turn it on again.
If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 2: Replace the batteries or the Rechargeable Battery PackInsert fresh AA batteries, or attach a fully charged Xbox 360 Rechargeable Battery Pack to your controller. If you have an Xbox 360 Rechargeable Battery Pack
  • Remove the battery pack and reattach it to your controller, making sure that it is attached correctly.
  • Press and hold the Xbox Guide button. In the upper-left area of the Xbox Guide button, the battery meter indicates your current level of battery strength. You might need to recharge the battery pack, if the level is low.
If you have an Xbox 360 Play & Charge kit
  • Make sure that the Xbox 360 Rechargeable Battery Pack is correctly connected to your controller and plugged into one of your console's USB ports. If you check both of those things but are still having the problem, try the suggestion below.
  • Plug the charge cable into each USB port on your console, one by one. There are two USB ports on the front of the console and one on the back. If the controller works in one USB port but not another, try another accessory in the USB port that did not work with the controller. If the USB port does not work with any accessory, your Xbox 360 console might need to be repaired.
  • Turn off vibration feedback (rumbling) on the controller. If you play games with feedback while charging, it takes longer for the controller to charge and might drain the battery pack faster than it can recharge. Here's how to turn vibration off.
    1. Press the Xbox Guide button on the controller.
    2. Go to the Settings area, and then select Preferences.
    3. Select Vibration.
    4. Select Enable Vibration to clear the checkbox.
If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 3: Remove objects between the controller and the consoleThe controller works within 33 feet (10 meters) of your console. However, objects placed between the controller and the console might reduce this range. In addition, objects that use wireless technology (for example, a cordless phone) can interfere with your wireless controller. Remove or relocate objects or wireless devices that might interfere with the wireless controller or console. Here are some things that can cause problems:
  • Microwave ovens
  • Cordless phones
  • Wireless routers
  • Chrome faceplates
  • Metal dividers
  • Shelves
  • Doors on an entertainment center cabinet
If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 4: Disconnect all controllers and headsetsIf all four rings surrounding the power button on the console are green but the controller has four flashing green lights, four controllers might already be connected to the console. Disconnect all of the controllers, and then try to connect the controller with the problem.
  • To disconnect a wireless controller, press and hold the Xbox Guide button for three seconds, and then turn the controller off.
  • To disconnect a wireless headset, turn the headset off.
  • To disconnect a wired controller or headset, unplug its cable from the console.
To learn more about connecting your wireless controller, please read the following Knowledge Base article: 906947 (http://support.microsoft.com/kb/906947/ ) How to connect an Xbox 360 Wireless Controller to an Xbox 360 console or computer If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 5: Replace your controllerIf your controller still does not work correctly, it might need to be replaced. Please contact Xbox support at the following address: http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) uparrow.gifBack to the top Additional supportPlease visit the following Web site for information about how to contact Xbox support: http://www.xbox.com/support/contact (http://www.xbox.com/support/contact)
Dec 05, 2010 | Microsoft Xbox 360 Controller
Xbox 360 Wireless Controller: it wont connect to the xbox...
Try to put in new batteries in the back of you controller.
May 16, 2010 | Microsoft Xbox 360 Wireless Controller
My xbox 360 controller start doesnt work and it does not turn on when i put a new battery in
have you tried adjusting the terminals for a better connection for the batteries
Apr 24, 2010 | Microsoft Xbox 360 Controller
If my xbox controller is more than 5 ft. from xbox it disconnects
First you can try to make sure there are no electonics causeing the problem, after that try using 4 wireless controllers, see if that works, if it doesnt, call microsoft and tell them to fix it for free.
Sep 04, 2009 | Microsoft Xbox 360 Console
My Xbox 360 wireless controller battery pack broke!
Well as you probably know all there is to a rechargable battery pack from xbox is 2 generic batteries that connect to the plate that connects to your controller. I recently took mine apart to try and fix it because it was not working at all. If you still have the original battery case that takes the AA batteries i would go out and buy a rechargable battery base and charge the cheap *** batteries that xbox uses in their packs. Then use the batteries that came out of the pack and put them in the original harness. Or you could just use the ones you buy.
Feb 08, 2009 | Microsoft Xbox 360 Controller
Xbox 360 wireless contoller won't sync with game console
If you're using an HDMI connection between the Xbox 360 and the TV, it might be that. When using HDMI, the Xbox won't boot up until it knows what the TV is capable of displaying. Although the controller will turn the console on, it won't sync with the console -- and it's not a controller or console problem, but just a symptom of the fact that the Xbox won't get to the point where controllers will sync until it can properly communicate with the TV. I'd recommend turning off the TV and the Xbox, disconnecting the HDMI cable and re-connecting it after making sure the contacts are clean. Then turn the Xbox back on first; you'll likely to see the same behavior. Finally, turn the TV back on. With it being switched back into HDMI mode, it just might "kick-start" the Xbox into a good communication link across HDMI. Hope that helps.
Jan 18, 2009 | Microsoft Xbox 360 Controller
You must sync the 360 with your controller. Turn on your 360 and your controller. Push the little black button on the front of your console, then hold the little tiny button on the top of your controller for a few seconds. This should sync them.
May 19, 2007 | Microsoft MS Xbox 360 Common Controller...
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
