Question about American Standard Traditional Champion4 2034.004.165 Silver One-Piece Elong
Newly installed but the tank leans forward, not parallel to the wall.
Are the tank to bowl bolts tight enough? Loosen the bolts, turn the tank where you need it, and tighten the bolts up until the tank is secure, not moving, and upright.
Posted on Dec 12, 2009
Frigidaire FAC107S1A leaking water thru the inside of the house
Hello, first make sure the unit is tilted back in the window about a 1/4 inch. Also, check the drain on unit, sometimes they can clog and prevent condensate from draining.
Jul 31, 2012 | Frigidaire FAC126P1 wall/window Air...
What position do I need to keep my body in when playing billiards?
Your body must be in a comfortable and stable position. Start by placing your feet and shoulders at the same width. Then take one step forward onto your leaning foot and put your chest in a parallel position to the floor. Place the cue on your leaning hand and look straight over the cue. Now you are ready to take a shot.
If you need some more in-depth guidance, please refer to the following link:
http://www.ehow.com/how_2217456_position-hand-body-playing-pool.html
Jul 25, 2012 | Sport & Outdoor - Others
Can my Toshiba 42WL58A be hung on a wall? Where can I find a manual for it? I've lost me manual and can't find any information on it.
Unfortunately the TV is not designed to mount on wall. Hence there is no wall mount bracket available from Toshiba to install it.. However, if you have a base in your wall you can use the supplied clip to hold it on the wall from leaning forward..
If you lost the manual, you can download the manual from the following link:
http://www.mytoshiba.com.au/support/televisions/lcd-tv/wl58a/42wl58a/download
Jan 20, 2011 | Televison & Video
LG - 32LG20 - Excellent LCD TV, but the stand is junk
there are four screw holes at the back, you might want to make use of it for anchoring. I guess these models are designed for TV-like installations and not for computer desktop monitors. The base takes a lot of space too.
Aug 16, 2009 | LG 32LG30 32 in. LCD HDTV
Elongated toilet doesn't fit where a round toilet was installed
Hi. There are toilets designed to accept a round seat and there are other toilets designed to accept an elongated seat. The primary difference is that the round seat fits a round bowl and the elongated seat fits an elongated bowl.
I recommend that you return the elongated seat and exchange it for a round toilet seat. good luck
Jan 31, 2009 | Kohler - Toilet - One-piece - Gabrielle -...
Leaks
if washer is leaking lean backward against wall pump is on front bottom ck it for leak most likely suspect can be changed without removing cabinet 2 clips 2 clamps..front and side come off together remove end caps on console by pulling forward and off remove screws underneath roll console back remove the clips underneath unplug lid switch cabinet will lean forward and off
Sep 02, 2008 | Kenmore 23012 Top Load Washer
Sony Dual DVD +/- RW
set the hard drive to master and the dvd to slave
Jan 24, 2008 | Computers & Internet
Removing Microwave
I just got my Whirlpool MH7100 off the wall. It was a bit of a hassle. I could not find a proper manual online at Whirlpool, but I guess since my unit was manufactured in 1993, who can blame them? Was the Internet even around in 1993?
There were 2 obvious bolts to remove above the microwave, these were found by opening the cabinet above. The next step was the hard one. Even after these were removed, the microwave would not lean forward so that it could be removed from the rear brackets. To get it to lean forward, I had to partially remove and partially break (i think) the vent for the exhaust fan. This revealed what looked like a very large screw with a regular head, one on each side. Once I unscrewed both of these, I was able to lean it forward and get it off the rear brackets.
Nov 25, 2007 | Microwave Ovens
American Standard Traditional Champion4 2034.004.165 Silver One-Piece Elong Logo
373 people viewed this question
Top American Standard Home Experts
Mike
john h
Tom Chichester
Are you an American Standard Home Expert? Answer questions, earn points and help others
