Question about Canon PIXMA MP460 All-In-One InkJet Printer
Canon mp460 instructions missed
Lost detailed operating instructions so struggling to adjust print/copy from original setting. Need to change cartridge too. Only have basic book.
  • Canon Master
  • 5,342 Answers
There should be a user guide on the disc that came with the machine. There is also a PDF on this site for it.
On the cartridge replacement lift the top and wait till the cartridges come to the rest position, there should be a guide there, but if not pull them down and fit new ones - they should push up into place. Close the lid, the machine will then reset if you have done it right.
PS make certain you remove the orange film from the new carts!
Posted on Feb 02, 2009
I have a Ricoh Aficio 1013 that prints fine but copies are unclear and off
Problem Cause Solution Colored lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About this Machine . Copies appear dirty. Image density is too high. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . Copies appear dirty. Auto Image Density is not selected. On the control panel, select [Auto Density]. The reverse side of an original image is copied. Image density is too high. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . The reverse side of an original image is copied. Auto Image Density is not selected. On the control panel, select [Auto Density]. A shadow appears on copies if you use pasted originals. Image density is too high.
  • Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference .
  • Change the orientation of the original.
  • Put mending tape on the pasted part.
The same copy area is dirty whenever making copies. The exposure glass, scanning glass, or ADF is dirty. Clean them. See "Maintaining Your Machine", About This Machine . The same copy area is dirty whenever making copies.
  • The original that has already been printed is scanned.
  • Original Type is set to [Text / Photo], and an original with text and photographs that can hardly be distinguished from each other is loaded.
On the control panel, press [Generation Copy], and then begin copying. Copies are too light. Image density is too light. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . Copies are too light. A light copy may result when you use damp or rough grain paper. Use recommended paper only and be sure its storage environment meets the recommended temperature and humidity conditions. For details about recommended paper and the proper way to store it, see "Recommended Paper Sizes and Types" and "Paper Storage", About This Machine . Parts of images are not copied. The original is not set correctly. Set originals correctly. See "Placing Originals", Copy and Document Server Reference . Parts of images are not copied. The correct paper size is not selected. Select the proper paper size. Parts of images are not copied. Even if you place originals in the ADF correctly, margin of a few millimeters on all four sides of the original might not be copied. Use "Create Margin" function to reduce the image of its original size.
For details about missing image area, see "Missing Image Area", Copy and Document Server Reference . images appear only partially. The paper is damp. Use paper that has been stored in the recommended temperature and humidity condition. For details about the proper way to store it, see "Paper Storage", About This Machine . Black lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About This Machine . White lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About This Machine . White lines appear. The dustproof glass is dirty. Clean the dustproof glass. See "Cleaning the Dustproof Glass", About This Machine . Copies are blank. The original is not set correctly. When using the exposure glass, face the originals down. When using the ADF, face them up. A moir? pattern is produced on copies. Your original has a dot pattern image or many lines. Place the original on the exposure glass at a slight angle. Black spots appear on the copy of a photographic print. Because of high humidity, the photographic print has stuck to the exposure glass. Place the print on the exposure glass in either of the following ways:
  • Place an OHP transparency on the exposure glass, and then place the print on the OHP transparency.
  • Place the print on the exposure glass, and then place two or three sheets of white paper on it. Leave the ADF open when copying.
White stripes appear on the OHP. Fragments of paper are stuck to the OHP. Use a dry cloth to wipe any paper fragments off the back of the OHP. The image on the back side of duplex copies has mottled blank patches or is smudged. Missing patches and smudges are caused by moisture leaking from the paper.
  • Do not install the machine in areas that are susceptible to low temperatures.
  • Use paper that has been stored where temperature and humidity conditions meet the limitations we recommend. For details about the paper storage conditions we recommend, see "Paper Storage", About This Machine .
  • Install the Optional anti-humidity heater. For details about the anti-humidity heater, contact your service representative.
When You Cannot Make Clear Copies
Feb 02, 2018 | Ricoh Aficio 1013 All-In-One Laser Printer
Hi When I print out my photos to my MP460 printer the picture is darker than I see it on my PC screen. How can I lighten the picture
goto printer properties and select printing preference, from there you will be able to select the setting, under custom setting you will be able to adjust the brightness and contrast of the print out.
Jun 20, 2010 | Canon PIXMA MP460 All-In-One InkJet...
My Canon MP460 has malfunctioned and Windows doesn't recognise it
Check your user manual for instructions on how to reset the printer to factory defaults.
Oct 12, 2009 | Canon PIXMA MP460 All-In-One InkJet...
When I try to print docs from the web, the printer feed the paper but it get stuck after pulling eigth of the page. Copies are OK to print without problem
Clean the paper feed tray
and adjust the tray
Clean the paper feed tray with damp cl;oth
reset the printer to factory default settings if still does not work
....Go thru the manuals how take printer back to factory default settings
Sep 15, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Can't print in color on my Canon printer
If you go here you can download or view a manual for your printer, with detailed instructions on changing the print cartridge settings in windows or mac.
If you go here, you'll be taken to the home support page for your printer, where you can enter a search for "print in color", and detailed instructions will follow.
You go to control panel>printers>print preferences> and uncheck the grayscale printing and set the color to auto.
Issue: Image prints black and white instead of color....See below.
Solution: Uncheck Grayscale Printing checkbox (Windows)
Unchecking Grayscale Printing Follow the steps below to change the Grayscale Printing option:
  1. On the Windows desktop, click 'Start', point to 'Settings', then click 'Printers' (Windows XP: On the Start menu, click 'Printers and Faxes').
    For Windows Vista: Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
  2. Windows 2000/XP/Vista: Right-click the printer icon, then click 'Printing Preferences'. Windows 98/Me: Right-click the printer icon, then click 'Properties'.
  3. On the Main tab, click on the 'Grayscale Printing' check-box to remove the check-mark.
  4. Click the 'OK' button to save the setting.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 28, 2009 | Canon PIXMA MP460 All-In-One InkJet...
No instucions for canon pixma mp460 printor
Hi!
Unfortunately I can't mail you instructions, mine is a Mp600, however if you visit www.canon.com look for their help/support pages pop your machines details in and Bingo you can print them off direct.
Can't do better than that?
Press the Blue button please when sorted from my FREE effort!
Thank You!
Paul 'W'
Feb 06, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Lost driver disk for mp460
You can download the drivers for your printer here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=13369
Simply click on the link , and on the page select your operating system...it will provide you with the drivers you need! After the download , launch the file and it will set everything up for you. Should be printing in no time!
Oct 01, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
57 people viewed this question
old marine
old marine
