Question about Kenmore Dryers
My Kenmoor dryer will not start. When pushing the
My Kenmoor dryer will not start. When pushing the start button the dryer will run but only when I keep the button depressed.
  • Kenmore Master
  • 2,696 Answers
Send model number, an even heat board would cause this,or you can unplug dryer and open console on top and see if the even heat board is in there,check it for burn marks,there should be a tech sheet in the console that will help you out but put it back,if you have to call someone in to work on your dryer and the tech sheet is gone they might not be able to help you, there is a relay part 3405281 could be in there,there are actually two of them,there is a heat relay and a motor relay,you can change them out as they are the same part and see if motor stays running,if so change out the motor relay, but i need model number to look up your dryer
Posted on Dec 10, 2009
Why does dryer run as soon as main button is pushed.
It can also be a bad relay on the the control board. This problem requires a tech to properly do a diagnostic, its not a simple problem for any technician.
Feb 20, 2015 | Dryers
Old hotpoint gas dryer will not stay running starts when start button is pushed will stay running if button is held in but stops as soon as button is release
you have a bad push start button test it with a meter for continuity ohms should show ohms when pushed in and none when released
Oct 04, 2014 | Dryers
When I push the "push to start" button (knob) on
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Mar 14, 2011 | Kenmore Dryers
Push start button dryer runs 1 second. Hold start
HI! The Push To Start Switch is defective. Click on the following link to order a replacement switch. !http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Dryer-Parts/3977456/0026/110/Model-11063952102/0582/0151200?keySuffixId=NA&productTypeId=x&searchModelNumber=11063952102&subCompDesc=Top%20and%20console&brandDesc=KENMORE&modelDesc=ELECTRIC-DRYER&pathTaken=partSearch&blt=11 for only $9.96. If you have a SEARS store closed by, you can get it from them.
To install, check the diag. on this page http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11063952102/0582/0151200/P0211134/00001?blt=06&prst=&shdMod=
Good Luck! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 08, 2010 | Kenmore 63952 Electric Dryer
Kenmoor model # 110.64982300 will not run unless start button is held in all the time.
You have a bad centrifugal switch on the motor. Or the motor is not getting to full speed.
Eric
Jun 08, 2009 | Kenmore Dryers
Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Apr 18, 2009 | Kenmore 73952 Gas Dryer
Kenmoor 80 series drier won't turn on.
I would check house breakers or fuses first.
Jan 05, 2009 | Kenmore 62602 Electric Dryer
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Dryers Logo
74 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
