Question about Maytag Washing Machines
I have a maytag washer model# pavt244aww and it jumps all over the place while it is spinning. any ideas what the problem could be I cant seem to figure it out
  • 1 more comment
  • mmmattmitche Dec 10, 2009
    yes it does. there is a lot of free movement on the drum. its almost like there is a stabilizer missing maybe?
    i have looked for the stabilizer bar and i dont see anything disconnected or broken. is there a bushing on the bottom? or underneath the unit it self there are belts and pullies. do they have anything to do with the drum other then spinning
  • Mark Egan May 11, 2010
    Does it jump all over the place with no clothes in it?
    President:
  • 1,214 Answers
There is a stabilizer bar that stretches across the back of the washer, and a pivot point in the right front corner. Both can be accessed through the back panel (tension bar) or top (pivot) of the washer.Look for one end of the tension bar having become disconnected, or the pivot point having become dislodged or broken.
Posted on Dec 10, 2009
  • Mark Egan Dec 10, 2009
    There is a pivot point on the front right corner of the plate the stabilizer bar is hooked to that could be broken.
    If the stabilizer bar is spring loaded, and the spring is broken, then that could be the cause as well.
    You can go to SearsPartsDirect.com and see how the washer is assembled. While the stabilizer bar may be captured at each end, there is a pin that may be missing on what would be the right rear corner stabilizer mount, or right end of the bar.
Maytag performa pavt244aww washer burnt rubebr and black pieces
Check with the belt off that the bowl will turn freely, if not check drum bearings or something caught between inner & outer bowl. Make sure when you fit new belt it is adjusted to the right tension or it will slip & burn.
Nov 24, 2013 | Maytag Performa PAV2200
Maytag washer (model PAVT244AWW). Won't spin. Don't know how old it is or its history, as it came with a home we purchased in October. Several times it's "walked" during the spin cycle. About 6 weeks...
Its the clutch ,And it sounds like it time for a new washer,the clutch is expensive and washer are cheap try a second hand store that sale scratched or almost new machines
Jul 05, 2010 | Maytag PAV2300 Top Load Washer
Maytag pavt244aww
We had the same problem and it is a known problem by Maytag. They came and replaced the springs under the drum as the original ones were not stong enough.
Dec 10, 2009 | Maytag Washing Machines
Seized tub - Maytag pavt244aww washer
you may have a seized up pulley on your pump. this will burn the belt. also check the pulley on the end of the motor.
Oct 27, 2009 | Washing Machines
The washer comes to life on the spin cycle lol
IS THE WASHER LEVEL ? YOU'LL BE SURPRISED HOW MUCH THIS WILL EFFECT YOUR WASHER JUST PUT A LEVEL ON IT TO MAKE SURE IT'S PLUM
Apr 12, 2009 | Washing Machines
Maytag washer model PAVT244AWW will not agitate during wash cycl
When the machine drains etc the gearbox locks up and the whole unit drum box and all spins when washing the gearbox innerds move the otherway so to speak and this cuasees a washing action this sounds as if the input shaft may need replaceing but it is usually better to replace the gearbox depends on finances but to be sure get a technition in to check and quote you first this is not something you can do if you have not done it before
Jan 25, 2009 | Maytag PYE2300AY Electric Dryer
Maytag washer will not agitate. model pavt244aww
TURN THE PULLEY ON THE BOTTOM. ONE DIRECTION WILL CAUSE THE PULLEY TO TRAVEL UP AND RELEASE THE BRAKE, CAUSING THE TUB TO SPIN. TURN IT THE OTHER WAY AND THAT SHOULD BE YOUR AGITATION. YOU SHOULD HEAR THE TRANSMISSION CLUNK AS THE GEARING CHANGES DIRECTION TO GE THE AGITATION ARC. IF NO NOISE IS HEARD, YOU HAVE AN INTERNAL PROBLEM WITH THE TRANSMISSION.
Washer model PAVT244AWW agitation noise
Sounds like the motor is going bad. It will only get louder before it finally stops. There is a device that assists the agitation motion that may be bad or is going bad.
Dec 01, 2008 | Maytag PYE2300AY Electric Dryer
MAYTAG TOP LOAD WASHER
you don't say which model you have. one version uses two belts accesible by just tipping the machine back. Another version you must remove the front panel, and drop the pump and you'll be able to replace the one belt.
Jul 03, 2007 | Maytag Atlantis MAV7260B Top Load Washer
Washing Machines Logo
423 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
