Has anybody configured Reliance Datacard - USB on ubuntu 9.04? Kindly give me step by step procedure for configuration? Regards, Moiz
    Guru:
  • 81 Answers
First use the following command to see if your card is being detected by kernel.
cat /proc/bus/usb/devices
Then you can use the following script for the installation, you can check if this is for your version of Ubuntu.
#!/bin/bash
#This program automates task of setting up connection for Reliance USB Card on Ubuntu Hardy Heron. This program does not come with any warranty whatsoever. Please use it at your own risk.
# Detect Modem
echo "Modem Detected: $(lsusb | grep -i huawei | cut -d" " -f7-)"
# Get Connection Number from User
echo "Enter Your Reliance Data Card Connection Number : "
read connection
echo "Setting up connection with $connection"
#Install Gnome PPP Package
echo "Installing Required Packages.."
sudo apt-get install -y -q gnome-ppp wvdial
#Add entries to /etc/ppp/ppp-secrets and /etc/ppp/chap-secrets
echo "I:Modifying necessary system files to allow dialing with Gnome PPP..."
sudo chmod 666 /etc/ppp/pap-secrets /etc/ppp/chap-secrets
echo "$connection * $connection" >> /etc/ppp/pap-secrets
echo "$connection * $connection" >> /etc/ppp/chap-secrets
sudo chmod 600 /etc/ppp/pap-secrets/etc/ppp/chap-secrets
#Start Gnome PPP
echo "We are all set.... "
echo "Starting Dialer..."
gnome-ppp &
exit 0
Posted on Dec 17, 2009
  • Shrey Srivastava
    Shrey Srivastava Dec 17, 2009
    Also you may have issues with gnome-ppp.
    You can try the following steps.
    copy these lines into /etc/wvdial.conf
    Quote:
    [Modem0]
    Modem = /dev/ttyUSB0
    Baud = 115200
    SetVolume = 0
    Dial Command = ATDT
    Init1 = ATZ
    FlowControl = Hardware (CRTSCTS) [Dialer cdma]
    Username =
    Password =
    Phone = #777
    Stupid Mode = 1
    Inherits = Modem0
    I had connected datacard before booting my system.
    (I have enabled root login):
    I executed following commands.
    Quote:
    #lsusb
    It listed many things along with my new reliance usb datacrd.
    Quote:
    Bus 006 Device 019: ID 12d1:1411 Huawei Technologies Co., Ltd. )
    then,
    Quote:
    #wvdial cdma
    --> WvDial: Internet dialer version 1.60
    --> Cannot get information for serial port.
    --> Initializing modem.
    --> Sending: ATZ
    ATZ
    OK
    --> Modem initialized.
    --> Sending: ATDT#777
    --> Waiting for carrier.
    ATDT#777
    CONNECT 153600
    --> Carrier detected. Starting PPP immediately.
    --> Starting pppd at Sat Dec 13 09:04:51 2008
    --> Pid of pppd: 6410
    --> Using interface ppp0
    --> pppd: `�[13] `�[13] ��[13]
    --> local IP address 220.226.118.181
    --> remote IP address 220.224.135.79
    --> primary DNS address 202.138.103.100
    --> secondary DNS address 202.138.96.2
    Now minimized the terminal and started firefox (work offline has to be disabled). It worked.
    (For disconnecting I use ctrl+c in the terminal. can anyone suggest the correct method?)
    If datacard inserted after booting of Ubuntu, command #lsusb didn't show the datacard.
    I executed
    Quote:
    #modprobe usbserial
    after sometime,
    Quote:
    #lsusb
    it worked. (I am not sure ubuntu automatically deteced it or 'modprobe' command did it).
    Then as usual
    Quote:
    #wvdial cdma
Ubuntu USB
Is your computer set up to read the USB drive in the boot sequence?
May 04, 2013 | ASUS Computers & Internet
How to use aircel sim in my datacard ?
You can contact customer care to get the procedure for datacard activation for your sim.
May 09, 2011 | Computers & Internet
My sim is showing 44'h,me error.
Apr 26, 2010 | Nokia 1600 Cellular Phone
Please can you give steps to disable the onboard usb controllers to use the CPI USB Card. I've installed the PCI Card after the onboard stop working
2.4.2 USB Configuration
The items in this menu allows you to change the USB-related features.
Select an item then press <Enter> to display the configuration options
USB Function [Enabled]
Allows you to enable or disable the USB function.
Configuration options: [Disabled] [Enabled]
Legacy USB Support [Auto]
Allows you to enable or disable support for USB devices on legacy
operating systems (OS). Setting to Auto allows the system to detect the
presence of USB devices at startup. If detected, the USB controller legacy
mode is enabled. If no USB device is detected, the legacy USB support is
disabled. Configuration options: [Disabled] [Enabled] [Auto]
USB 2.0 Controller [Enabled]
Allows you to enable or disable the USB 2.0 controller.
USB 2.0 Controller Mode [HiSpeed]
Allows you to configure the USB 2.0 controller in HiSpeed (480 Mbps) or
Full Speed (12 Mbps). Configuration options: [HiSpeed] [Full Speed]
BIOS EHCI Hand-off [Disabled]
Allows you to enable support for operating systems without an EHCI
hand-off feature. Configuration options: [Enabled] [Disabled]
NOTE!!!
Do not disable the BIOS EHCI Hand-Off option if you are running a
Windows® operating system with USB device
hope above given details with give you a detailed description as you desired.
good luck
Feb 04, 2010 | ASUS P5LD2-VM Motherboard
Enable Atheros AR5007 WiFi with UBUNTU 8.1 64 bit
you dont need to install drivers in vista . just search for new automatic updates all drivers will install automaticaly
Mar 10, 2009 | Computers & Internet
Using tata indicom usb modem in Ubuntu
linux connectn
1st log in the root user
connect the usb modem
run terminal in linux
type following command
wvdialconf /etc/wvdial.conf
wvdialconf will detect the modem
nano /etc/wvdial,conf
jus replace dis wid defaulf setting
modem-/dev/ttyusb0
baud=115200
dial command=atdt
baud=115200
dial command=atdt
init1=atz
init 2=at+crm=1
flow control=hardware
username=internet
password=internet
phone=#777
stupid mode=1
aftr dis open terminal type wvdial &press enter
if u want to disconnect den press clt +c
Dec 09, 2008 | Canonical Ltd. Ubuntu
Configuring DLink Wifi router for Reliance broadband
quick questions
1. how did you setup your modem?..is it via PPPoA or PPPoE
2. can you please provide the model number of your modem
thanks
Apr 24, 2008 | Linksys Wireless-G Broadband Router
Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Feb 01, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Computers & Internet Logo
375 people viewed this question
Alun Cox
David Payne
David Payne
