Question about Panasonic CT-36HL43 36" TV
No power panasonic CT-36HL44J. I have used various outlets to make sure it has power.
  • 1 more comment
  • alfa87 Jan 19, 2008
    No power. Have checked outlets. Dead as a doornail.
    alfa87
  • joeliv Jul 23, 2008
    SAme Problem no power ,Checked line voltage 117v also checked fuse it seems good .can I discharge the crt with a screw driver like the old days.could it be the switch and How do I get to it .Any help would be great
  • joeliv May 11, 2010
    Thanks for you help but I got rid of the tv and bought a Visio 42 inch lcd
    Joeliv
    Champion:
  • 252 Answers
To discharge your crt wont hepl you to switch it on . check the power supply first if they had B+ then check the horizontal transistor
Posted on Sep 29, 2008
Will power up only after the power cord unplugged and plugged back in to the outlet. Then shuts back off again. CT-36HL42CF.
High voltage too high going into xray protection. Check the collector of the horizontal output transistor for 130v dc.
Oct 10, 2011 | Panasonic CT-36HL42 36" TV
Television problem
HELLO!!
FROM WHEN ARE U FACING THIS PROBLEM ???
Dec 30, 2007 | Panasonic CT-36HL43 36" TV
Have a Panasonic CT-36HL44J hdtv, power supply is good, when powered up it acts like it wants to start but immediately shuts off, power indicator light blinks 8 times then pause then 8X (repeat). Spoke to...
According to a service forum (not FixYa), 8 blinks indicates Driver SOS 3 SS Board (SS energy recovery circuit) - in other words, the 8 blinks means a protection code for a faulty board/module. Unfortunately, this may not be repairable at consumer level; the TV will have to go to a workshop to have that board (if this model has it) examined and/or replaced (manufacturers no longer provide individual components for replacement; they lean towards replacing entire boards/panels/modules in their appliances nowadays). The only problem here is the likely cost(s) involved.
I suggest that you obtain a quote from an authorised Panasonic service centre, then you can decide for yourself if it is economical or worthwhile repairing. It's up to you.
- the error code/circuit failure can vary over different models.
Feb 04, 2011 | Panasonic CT-36HL43 36" TV
My Panasonic HDTV will not turn on
Mine did the same thing. Did you find out what to do?
Oct 11, 2009 | Panasonic CT-26WX15 26" TV
Tv won't turn on at all
no remote but tv was working with front power key? unplug from ac outlet and plug back and listen for any type of indication (noise or chirp) that something energizes inside if theres nothing then suspect a power supply problem, main fuse blown, shorted low volt rectifiers other components could be at fault.
Aug 05, 2009 | Panasonic CT-32SL13 32" TV
Panasonic CT-36HL44J TV went dead, won't turn on.
have check for fuse? is your tv cord good?
Oct 24, 2008 | Panasonic CT-36HL43 36" TV
Panasonic television
I had the same problem, however mine was a 32inch. It is a blown fuse. It is not the power cord. What you need to do is find out what fuse voltage you need. Hope this advice helps. I have a panasonic model CT-32SX12C.
Aug 20, 2008 | Panasonic CT-36SX12 36" TV
TV does not power up
Check Power Cord is Plugged into Active Outlet
Adjust Brightness and Audio Controls Change Channel Check Cable Connections Program the Remote Control Again Check Second Video Source Operation As warranty has expired, check if fuse at power supply input is ok.
Consult online manual for troubleshooting.
http://www.fixya.com/support/p232673-panasonic_ct_36sl13_32_tv/manual-7023/page-22
Feb 14, 2008 | Panasonic CT-36SL13 32" TV
Panasonic model CT-36SL13G TV
Your problem is most likely the thermistor , or degausser, is going bad. It is a little black box with pins and says D1R5M on it. It can be found by following the wire from the degaussing coil around the picture tube. The location number is CF803( i think)the Panasonic partnumber is D4DF1R50001. Also, I believe your fuse is 6.3A not 3.6A.
Nov 07, 2007 | Panasonic Digital Video Duplex, Color...
3year old Panasonic ct-32sx12f dead?
Sure, Why not? It is worth the effort. If the set is 'dead', it is the easiest to repair.Only 'tampered' sets pose problems. It could be a simple blown Fuse, or the Power Regulator IC. This should not cost you more than $100-150 as Technician charges + 15-20$ for spares. It could also be a defective Horizontal Outut Transistor and short cicuiterd FBT, (tho' it seems remote), but if yes, add another $100. definitely worth calling a professional techie
Aug 22, 2006 | Panasonic CT-32SX12 32" TV
Panasonic CT-36HL43 36" TV Logo
73 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
