Question about Viking DFUD042 Built-in Dishwasher
Viking DW 20.3 dishwasher. We have two of them.
Viking dishwasher. We have two of them. One works great but the other sometimes leaves grit on the glassware on the top rack. I'm wondering if the upper spray arm should be checked and if so, the proper way to do so. Do I just pry off the upper arm? I see two plastic clip-type of things holding it on.
aborcass
  • 2651 Answers
SOURCE: broken nozzle and upper spray arm
the spray arm just screws back on, unless of course its cracked in which case needs replacing( chances are since it fell off its cracked) heres the part num 154478202
Posted on Mar 15, 2008
  • 10865 Answers
SOURCE: Whirlpool GU3200XTP dishwasher - No spray on upper rack
Sounds like the hose assembly that attaches to the rear of the upper rack has come undone. just pull out the upper rack and reconnect it.
please rate my answer as a fixya! thanks.
Posted on Feb 14, 2009
Kgt1962
  • 59 Answers
SOURCE: Viking dishwasher not cleaning bottom rack of dishes
Yes there is the Water Div valve, it diverts the water between the wash arms.
Posted on Mar 11, 2009
localwonder
  • 6784 Answers
SOURCE: will not clean dishes on the upper rack
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
Posted on Jun 16, 2009
SOURCE: Very low pressure getting to spray arms
I removed the lower spray arm, and then the filter. I found that there was a lot of buildup under the filter area. I scraped the buildup off. I found that it was restricting the input of water flow to the pump
Posted on Aug 03, 2009
Bosch dishwaser. starts and stops, it will say clean. leaves water in the bottom. we purchased a new pump and still not working? :( :(
All dishwashers leave a little water in the bottom. However, I suspect there's an appreciable amount in the machine. I'd suggest you lift out the filter and check the drain port.
Feb 11, 2015 | Bosch Dishwashers
It leaves a lot of grit on the dishes
dont pre wash the dishes before putting them in if you dont and cut back on detergant and prine the sink before starting the dw
Jun 03, 2010 | Dishwashers
Dishes/cups are not being completely cleaned. there is grit in the cups on the top rack, along with coffee stains still in the coffee cups. i sometimes pre-rinse, however, i didn't have to w/ my previous...
1)check the enough inlet water pressure. 2)check any block in the rinse nozzle. 3)check it attains the temperature. 4)check proper detergent& sanitizer going.
Jun 03, 2010 | Viking 24 in. Professional Series VUD141...
No water, sounds normal . might be silenoid switch on inlet valve? vud140 viking dw
could be the water valve silenoid connection clip to the power source has been disconnected, 2) water valve is clogged with debris, 3) water valve silenoid has gone bad. I think one of these three things may be your problem. Good Luck
Dave
Aug 07, 2009 | Viking Designer Series DFUD140...
Water is sitting in the bottom of our Viking Pro DW. Removed stainer. Still water. Any suggestions?
Is the drain hose clogged or kinked? Or the knockout for your disposer inlet not knocked out?
Jul 07, 2009 | Viking 24 in. Professional Series VUD141...
I have a Kenmore dishwasher that seems to leave a bit of water inside. Model 3631435598. Is this normal finish mode? Seem the water would get stale. I have no manual can anyone help with either ?
Hi Doc!
You know? If I had to postulate an educated guess, I'd wager that your dishwasher's (DW) drain hose isn't hooked up properly under the sink. When it's not hooked up right, water from the sink will siphon down into the DW making you think that there's a problem with the DW when in reality the problem is elsewhere. Kinda tricky, huh?
Anyway... I put together some photo's that show the incorrect installation and the correct installation of DW drain hoses. Check it out.
The downward sloping hose allows water from the sink to go to the DW.
The "loop" (actually called a "vacuum break") won't allow water to go to your DW.
Here's a schema of the layout...
So the drain hose from the DW always has to loop upwards to keep gravity from weilding its' wicked hand and drawing water down to the inner most depths of your dishwasher.
So, that's the first thing to check, Doc. (<---- that was my Uncle's name, btw. He owned and operated a microwave repair shop back in the late 70's.) If you find the hose under the sink looks like the first pic, just loosen the clamp, pull as much slack from the DW as you can, form a loop like in pic #2, tighten the clamp (to hold it in place) then tie off the hose to a stationary location (like the hot or cold line feeding your faucet)
There ya go! Fixed! Ain't it cool? How easy was that? What about 20 minutes? Maybe less? All you needed was a 5/16" nutdriver and some tape! Too cool.
Don't forget to rate me, OK? My self esteem is counting on you.
Oh! If you find that the drain is properly installed, let me know. We'll go deeper into the solution, OK?
SG
Jun 07, 2009 | Kenmore 15762 Dishwasher
Viking Dishwasher leaves a film on the dishes
Hi! I found a great product at www.dishwasherfilter.com that will take care of this problem for you and your wife. It mounts under the sink and works great!
Use promo code DF5150 when ordering for an additional discount!
Dec 16, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Viking DFUD042 Built-in Dishwasher Logo
439 people viewed this question
Top Viking Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Lloyd Carter
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
