Question about Pentax ZX-10 35mm SLR Camera
Pentax ZX-10 mirror stuck
I have a ZX 10 that seem like it wants to work but the mirror get stuck up and will not let the camera work. I have changed the batteries.
Ostewart2102
  • 41 Answers
SOURCE: Mirror locked up
Older cameras like this are notorious for locking up after not being used for quite some time. Though, it is an easy fix, it does require some steady hands and a good memory of where everything was after you're taken it out or apart. The best solution for this is, once you've taken it apart and have access to the mirror, is to have a q-tip with a little vasoline on the tip, apply a thin (very thin) layer along all springs and joints surround the mirror and around the edges of the mirror opening, while avoiding getting any vasoline on the mirror itself. I've worked with cameras all my life and have worked at camera shops, and what I've explained here is exactly what a camera repair place would do. But, if you don't feel comfortable with small parts and tiny screws, a camera shop will gladly fix it for you, and not at a bad price.
So, Good luck! Hope this helps. I hope you're out taking photos soon!
Olivia~*
Posted on Dec 01, 2008
  • 185 Answers
SOURCE: Pentax ME Super Shutter and Rapid Wind Button won't release
Must have batterys to work shutter. Put select off auto and the shutter will work equal to 1/60th sec. for flash setting. This is a very rugged fine camera,should last for many years if taken car of.
Posted on Dec 07, 2008
  • 11967 Answers
SOURCE: can the shutter curtain be replaced on a Pentax
It can be replaced only by a trained service technician. Check the Pentax website for a service center near you.
Posted on Aug 12, 2009
Obertelli
  • 3006 Answers
SOURCE: the mirror on my pentax pz1 (film) camera is stuck
Mirror lockup often occurs if the batteries are flat.
Try new batteries first and if the problem remains please report back for further options.
Posted on Feb 13, 2010
Testimonial: "ha ha yes that's what it was thankyou!"
  • 411 Answers
SOURCE: THE SHUTTER STUCK OPEN AND NOTHING HAPPENS, EXCEPT
loader gear broken,get it replaced ,get it done by a camera tec.
Posted on Mar 08, 2010
My Pentax ZX-7 (MX-7) mirror is stuck
This camera can be notorious for these types of film advance issues. The bad news is that a ZX-7 is probably not repairable. Good news is that there are many used Pentax bodies out there that will work with you lenses.
Dec 11, 2013 | Photography
Lens zx 30
is the mirror stuck up? Lots of these ZX Pentax models have failure of the mirror motors when the plastic gear on the shaft of the motor cracks and then the motor just runs continously
Oct 20, 2013 | Pentax ZX-30 35mm SLR Camera
The shutter on my Pentax zx-50 SLR is stuck in the open postion. I can't see anything through the view finder nor will it focus automatically. However, it will advance the film upon taking a snapshot and...
if its just a sticky mirror you could try to very genteely flip it down again but if the shutter is jamed in its sliders it could need to go to a camera shop to get it "fully serviced!" also check its not just the shutter lock button stuck in, or the shutter is locked open,
Nov 28, 2010 | Pentax ZX-50 35mm SLR Camera
Can't see through viewfinder
That will happen if the mirror is stuck in the up position and so blocking any light from entering the viewfinder.
Mirror lock-up is very common on 35mm SLR's like yours where the shutter is entirely electronically controlled and in most cases it's cured simply by fitting new batteries.
If this resolves your problem then please rate my answer, if not then add a comment instead to confirm that the batteries have been replaced and I'll try further options.
Apr 26, 2010 | Pentax ZX-50 35mm SLR Camera
Shutter locks up and won't release (zx-10)
Its gonna need repair. Most likely causes:
Lubrication dried up/deteriorated internally
Shutter electromagnets need repair/ clean/ replace.
(This was a constant issue with the Canon T-90)
Shutter blades out of alignment
Shutter speed stuck on B (not likely)
Oct 13, 2009 | Pentax ZX-10 35mm SLR Camera
The viewfinder of my minolta x700 is always black
Check if the mirror is locked or stuck. If the viewfinder is dark, it means there is something wrong with the mirror.
Feb 14, 2009 | Minolta Photography
Mirror locked up
Olivia~*
Nov 26, 2008 | Pentax ZX-10 35mm SLR Camera
Pentax zx 50 35mm slr
Others here have suggested the problem lays with the plastic gear on the advancing motor beside the mirror.
This might cost $100 or so...?
Oct 22, 2007 | Pentax ZX-50 35mm SLR Camera
Pentax zx-50 Shutter Problems?
I really think this is the classic zx - 50 shutter motor problem : small motor on the side of the mirror box is not cocking the shutter . This is very repairable but unfortunately it requires fair amount stripping down of the camera to get to the fault and so you will have to take it in for repairs.
Sep 03, 2007 | Pentax ZX-50 35mm SLR Camera
Black viewfinder
Slr mirror is stuck. remove the lens and try to slightly move the mirror up and down ( but not forcing it to move!)and pushing the shutter switch. Try also applying lighter fluid in the mechanism while operating or shooting, fluid will help loosen the stucked mechanism.
Aug 31, 2007 | Pentax ZX-7 35mm SLR Camera
Pentax ZX-10 35mm SLR Camera Logo
313 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Geoff Hone
Are you a Pentax Photography Expert? Answer questions, earn points and help others
