Question about Dryers
Need help my dryer sounds like a mac truck the dryer is level but still sounds bad
  • 236 Answers
Sounds like either the front or rear support bearings are worn. get a feel of the problem by moving the drum slowly with your hand and listening closely to it. noises are difficult to predict remotely let me know how you get on.
Posted on Jan 20, 2008
Rosetta stone on Mac doesn't open because of error 9120
Go to System Preferences (click on the apple in upper left corner of monitor and pull down)
Look for "hardware" and click on "sound". Is your mike on? Make sure your "output" level is high.
Hope it helps!
Feb 22, 2013 | Rosetta Stone 3 Farsi Level 1 2_3 Set Full...
Washer is shaking really bad making bad noise sound as though it off balance but its level.
may be the drum rollers/glides:
Jan 11, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My dryer makes a thump thump sound
  1. Thoroughly check the inside of the dryer for any foreign objects with hard surfaces. Sometimes items that fall out of pockets become stuck inside a dryer and make thumping noises.
  2. Check for level
  3. Make sure the dryer is level. A dryer that is out of level may not rotate properly. Banging or thumping noises from unleveled dryers are common, particularly if the dryer is resting against another metal object such as a washer.
  4. Check rollers
  5. If the thumping noises are present only for the first few minutes of the drying cycle the likely culprit is rollers. If the rollers are warped they will need to be replaced and a professional should be called in to help
Dec 17, 2010 | Frigidaire Electric Dryer
Kenmore 90 Series Dryer started to operate very loudly. The noise sounds like it normally does while drying, just much, much louder than usual.
I would think the belts are getting bad need to be checked anyway, also while your checking the belts check the tenision pulley for the belts make sure it has not fallen off, also, make sure dryer is LEVEL, hope this helps let me know please thks larry
Feb 27, 2010 | Kenmore Dryers
I have a matag performa model PYE2300AWY dryer that wont start. Jumped out the thermal fuse, and door switch still nothing. Whats next? Timmer?? HELP
Could be a burned lead, timer might be bad, or the water level switch could be bad. (Water level switch enables motor operation when the level is high enough.) Hope this gives you a good lead to check... Good luck.
Nov 28, 2009 | Dryers
Go to system preferences and select sound then click on output and then choose the device for sound output usually internal speakers or headphones and at the same time at the bootom of the control panel check what level the output volume is. Hope this helps
Oct 10, 2009 | AB Soft MacBook 2.0Ghz Intel Core Duo 13",...
It sound like you have a bad pump seal.If you can get to it remove the pum and put in spin cycle if the noise is gone then you need a pump good luck
May 01, 2009 | Whirlpool LER4634J Electric Dryer
Top loose, new dryer not level? rattle when start
No dryers are not self leveled. You may not have put the legs on ? they come in the box or if you have then you need to prop them up with a 1x4 or something.
Apr 19, 2009 | Kenmore 500 6952 Dryer
I have video but no sound using SKYPE.
It sounds like you're asking whether headphones are necessary to the Skype experience.
You don't absolutely *need* headphones (or a microphone or a headset that has both), but if you don't use headphones, then your Mac external microphone might pick up the sound of your conversation and you might get unpleasant levels of feedback.
If this doesn't answer your question, please write back with the following information:
1. Your Skype version (click Skype --> About Skype)
2. Your model of Mac
3. Whether you are having problems with your audio
- On Skype only?
- On other applications?
- In general?
4. Whether you have tried clicking on "Skype Test Call"
- Whether you could hear the voice giving you instructions
Jan 23, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Ge microwave
Sounds like you have a bad magnatron tube, check your owners manual as most of them have a 10 year parts warranty.
May 23, 2008 | GE DBSR453EBWW Electric Dryer
Dryers Logo
63 people viewed this question
Top Dryers Experts
