Question about Electrolux EOU6330 Electric Double Oven
I have an electrolux EOU 6330 double oven, how do I gain access to change a faulty element?
  • Electrolux Master
  • 3,463 Answers
Assuming you live in the u/k, and it is an electric fan assisted oven, and that it is the fan oven you are referring to, then the element is usually to be found at the rear of the oven compartment, behind a removeable cover.
Hope this helps.
Posted on Dec 10, 2009
The top oven is over-heating with no change in temp display. A red-hot heating element on the left side of the oven (facing it) shows through the floor of the oven.
Good Morning Eileen, thank you for your inquiry!
I understand that your Electrolux double wall oven is having over heating issues. It is possible that this could be a faulty thermostat, control panel, or element. Since it could be anyone of these underlying having a technician out would help avoid any unnecessary part purchases. If you need help locating a technician you can visit your manufacturer's website for additional assistance with locating a technician. I hope this information is helpful to you. -Matt
Aug 09, 2015 | Electrolux 27" Built-In Double Electric...
Hi, I have an Electrolux EOU 6330 electric grill/oven. In have only used it twice as i have just moved in to the house and after the second use during the cool down period it started rapidly clicking and...
Try turning the power off to the oven at the meter box and leaving it off for an hour or so. This will allow it to fully reset. When you power up again, reset the clock time and set to manual cooking , hopefully , all will work again.
Jun 27, 2014 | Ovens
Eog 6330 oven door does not fully close ie small gap at top unless you hold door closed are hinges damaged or bent?
you will have to replace both left & right hinges / this should correct problem .. mm
Jul 12, 2010 | Electrolux Ovens
Eod6630 does not heat to temp changed element now does not reach temp on cooker
Try and locate the thermostat, check no wires have come off from there. Your old element may have been ok, you may have a faulty stat or a loose wire on one of the connections.
Dec 07, 2009 | Electrolux EOD6330 Ultrafan Electric...
Bottom oven not working have put new element in still not heating
You need to determine that you are getting power to the element, you will need a meter to test with.
If no power, then could be faulty thermostat or regulator switch.
If you have power, then element faulty.
trust this helps you.
Thanks.
Dec 05, 2009 | Electrolux EOU6330 Electric Double Oven
I have an electrolux double oven eou 6330 the bottom oven element has broken.Can I buy and fit it myself as single female with very little spare cash?
Yes. You can do it. Part should be $40 or less.
Turn off the power to the oven. Remove the oven racks.Unscrew the element screws from the back wall of the oven. Carefully pull the element out. The wires may be short. Remove the wires from the element. Do not let the wires pull back into the oven cavity. Take the element to the appliance parts store and have them match it to the existing element. Attach the wires to the new element,insert the terminals into the opening,replace the mounting screws. Turn on the oven and bake away.
P.S. Your model number is not correct.
Nov 05, 2009 | Electrolux EOU6330 Electric Double Oven
Electrolux double oven does not get hot
If it is a fan assisisted oven and the fan is still working, then you need a new oven element fitting.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Electrolux EOU6330 Electric Double Oven
Changing an element on the main oven - Neff U1721 Double oven
You should not need to remove fan to access the element fixing scew(s).
You may need what is called a torx screwdriver, if the screws are conventional screws, but some times a small screwdriver will undo them if they are not too tight.
let me know if you require any more assistance.
Thanks.
Jan 10, 2009 | Neff U1721 Double circotherm Electric Oven
Electrolux EOU6330 Electric Double Oven Logo
515 people viewed this question
Top Electrolux Ovens Experts
Steve Allison
Steve Allison
John Tripp
John Tripp
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
