The error light indicates something is wrong with the machine. The error light in combination with another light indicated that the problem lies with that item.
If there is an issue with a job not being able to be printed you can press the go button to allow it to continue (Normally happens if you send a job to the printer using paper other than what the printer has in it)
Here is the procedure for resetting the Toner flashing light on Brother HL-2140 (sources for other answers here and self testing - specific to HL-2140)
Open the front cover and leave open.
Turn the printer off.
Hold the "white button" while turning the printer on. (All panel lights should be on.)
Release the "white button".
Press the "white button" 2 times (Pause, wait for all lights to come on.)
Press the "white button" 5 times. (All lights to come on again, then go out.)
Cancel "maintenance driver" install, if prompted
Close cover.
Power cycle printer.
This will:
reset the toner light (stop blinking)
restore the printing darkness (when toner light flashes, printer prints lighter to save toner)
This error occurs when your printer is dealing with a particually complicated print job and cannot process it all. Try to reduce the complexity of your document or cut the print resolution. It may be worth trying to print the document in several parts if at all possible.
Dear sir, I know what is problem? your toner cartridge is demage please change it also you re-install your old toner then quickly take a decission
Thanks
xptareq2000
wiz
all the best
am not very sure but i think u should try go to printers and faxes through control panel open it and right click on your printer and select print on line
