Question about Canon imageCLASS MF4150 All-In-One Laser Printer
My Canon imageclass MF4150 display an error code E225 and not working now.
  • joseph_d2ssc Dec 20, 2009
    I can't perform the Firmware update because the machine still having an error E225 so may i know is there anyway to reset the error RED indicator first then just follow by the Firmware update?
    You do agree with perform the firmware update definitely can solve the error E225.
    Thanks!
    Best Regards,
    Joseph
    President:
  • 2,923 Answers
Try to press and hold the Stop/Reset button for a full 6 seconds and see if this step would clear the error.
Thank you!
Posted on Dec 20, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Turn the main power switch off and then back on. My Canon imageclass MF4150 display - 457f2e4.gif If still the issue is not resolved then you have to do a firmware update which will solve the issue.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Dec 18, 2009
  • Rylee Smith
    Rylee Smith Dec 18, 2009
    Please follow this procedure to complete the firmware update:
    1. Save the downloaded file "MF4150_FirmwareUpdateTool_V0xx.exe on local drive. (i.e. desktop)
    Computer Requirements for update
    - Microsoft Windows 2000 or XP (32bit)
    - Equipped with a USB port (either 1.1 or 2.0)
    - Free disk space: 100 MB or more
    2. Make sure that Processing/Data indicator (Green LED) on the MF4150's operation panel is turned off.
    If the light is lit or blinking, wait until all the jobs are finished (i.e., COPY, PRINT, and SCAN), and that the Processing/Data indicator is turned off.
    3. Make sure that Error indicator (Red LED) on the operation panel is turned off. If Processing/Data indicator (Green LED) is lit and Error indicator (Red LED) is blinking at the same time, jobs are held in the printer memory due to an error, possible cause is out of toner or paper has run out, or toner cartridge is not installed. Check the LCD for and error message and refer to the documentation that came with the printer to resolve the error.
    4. Disconnect Fax line cable from the MF4150 to prevent Fax reception interruption during firmware update.
    5. Make sure the USB cable is directly connected to the MF4150 and your computer.
    • Do NOT use a USB hub to connect the cable, as it may lead to a connection error.
    • Make sure the machine is not in the Sleep mode (i.e., [Energy Saver] key on the operation panel is leit). To exit the Sleep mode, press [Energy Saver] and confirm that the Energy Saver light is off.
    • You need to log on as an administrator to perform this update.
    • Make sure that no other applications are running on your computer.
    6. If [Found New Hardware Wizard] appears on your PC screen, click [Cancel] to exit the screen.
    • [Found New Hardware Wizard] screen may be displayed multiple times. Cancel anytime you encounter this screen while performing this update.
    7. Double-click ?MF4150_FirmwareUpdateTool_V0xx.exe? that you downloaded and saved.
    8. . Double-click "MF4150_V0xx_FirmwareUST.exe" that is in the newly created folder as a result of uncompressed downloaded file.
    9. Confirm that the machine is in the ready status, and then click [Transfer]
    • If the printer is not detected: Check if the printer's power is turned on and the USB cable is properly connected. Then click [Retry] to proceed.
    10. The firmware is transferred to the printer.
    • Never turn of the power to the MF4150 while firmware is updating. If power interruption occurs while the firmware is being updated the control board will be damaged and will need to be replaced. The replacement of the control board and labor will not be covered under warranty.
    • If an error occurs while transferring the firmware: Check if USB cable is properly connected. Click [Retry] to proceed.
    11. When [Firmware transfer is complete] appears, click [Exit].
    The printer starts the update process automatically.
    appears on the printer's display while the existing firmware is being erased.
    Then printer's display shows while updating the firmware.
    When the firmware update is complete, the printer's display shows
    12. Turn printer's power switch OFF, wait 2 seconds then turn the power switch back ON. Check that there is no error on the printer display. Reconnect removed fax line cable.
  • Rylee Smith
    Rylee Smith Dec 20, 2009
    Hi Joseph,
    Yes you are right the firmware update can definitely solve the error E225.
    Thanks
    Rylee
2 Suggested Answers
worldvet
  • 859 Answers
SOURCE: Error Code E225 on Canon MF4150
Try this quickly to see if it helps and if it doesn't let me know as there is another trick we can try next.
With the Printer On:
Press and hold the Stop/Reset button for a full 6 seconds, using the one Mississippi method of counting or use a watch.
Release the button. Restart the Printer and try to print again.
Regards,
Worldvet
Posted on Oct 20, 2008
Error e225 is displayed on cannon imageclass mf4320d
the error E225 means that the SCANER UNIT is faulty.
You can call for tech for replacement or, if you have the expetise, you can do it your self with a brand new SCANER UNIT from CANON.
Nov 18, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
ERROR E225
system error e225 on canon mf4010
Jun 04, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
System error e225
This has worked before so gave it a go.
Canon imageCLASS MF4150 And ERROR E225 maybe others
Canon imageCLASS MF4150 Firmware Update V062 Windows 2000/XP/Vista/Windows 7(all x32/x64) from Canon Multifunction .
Hi there
This is because you need to update your Firmware,
So what I have don for you I have found the Update you need and I have put it on my website for you to download, this is a update for Vista / Win 7 / All 32Bit and 64 Bit.
Click Link = http://www.4all2sell.com/driver/Canon-MF4150_FirmwareUpdateTool_V062.exe
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website is only there foe a limited time.
Apr 19, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
System error e225
Hi there
Apr 16, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Canon mf4350d says error E225
ERROR E225 Canon imageCLASS MF4150 And maybe others
Hi there
Jan 13, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Mf3240 error E225
You can gave it a go.
Hi there
Oct 22, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Imfc 4122 laser printer print scan copy some error display E225
Ok try this I know not same number printer as yours but who knows may work.
Hi there
Dec 27, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Canon imageCLASS  MF4150 All-In-One Laser Printer Logo
442 people viewed this question
old marine
old marine
